[petsc-users] CUDA MatSetValues test
Mark Adams mfadams at lbl.gov
Sun May 30 15:46:01 CDT 2021
On Sun, May 30, 2021 at 12:55 PM Barry Smith <bsmith at petsc.dev> wrote:
>    I believe I have finally successfully rebased the branch barry/2020-11-11/cleanup-matsetvaluesdevice
> against main and cleaned up all the issues. Please read the commit message.
>   I have submitted a CI pipeline with ctables turned off temporarily for
> testing of the MatSetValuesDevice(). If it works hopefully Mark can maybe
> run a few additional tests of his Landau code that are not in the usual
> testing to verify and we can finally get the branch into main.
If ex2_[cuda|kokkos] pass then you are fine.
Thanks for doing this, and Stefano, this needed to be looked at by someone
that knows what they are doing.
>   Mark,
>      Since this change is involved, it is likely your Landau mass matrix
> branch may not rebase cleanly.
Oh ya, you touched a lot of landau code, but it does not look hard. You
removed * from  PetscSplitCSRDataStructure *d_mat=NULL; and the rest look
like it will be easy to pick your version.
> Let me know if you would like me to do the rebase and testing of your
> Landau mass matrix branch. I can get it ready to work with the results of
> barry/2020-11-11/cleanup-matsetvaluesdevice and then hand it back to you
> for further development.
I will remove my changes to petscaijdevice.h. All I (Peng) did was protect
printf statements with DEBUG, because printf takes up register(s) and
registers are the limiting resource in Landau.
So I guess you can merge and I will rebase over main.
>   Barry
> On May 29, 2021, at 11:32 AM, Barry Smith <bsmith at petsc.dev> wrote:
>   I am working away on this branch, making some progress, also cleaning
> things up with some small simplifications. Hope I can succeed, a bunch of
> stuff got moved around and some structs had changes, the merge could not
> handle some of these so I have to do a good amount of code wrangling to fix
> it.
>   I'll let you know as I progress.
>   Barry
> On May 28, 2021, at 10:53 PM, Barry Smith <bsmith at petsc.dev> wrote:
>   I have rebased and tried to fix everything. I am now fixing the issues
> of --download-openmpi and cuda, once that is done I will test, rebase with
> main again if needed and restart the MR and get it into main.
>   Barry
> I was stupid to let the MR lay fallow, I should have figured out a
> solution to the openmpi and cuda issue instead of punting and waiting for a
> dream fix.
> On May 28, 2021, at 2:39 PM, Mark Adams <mfadams at lbl.gov> wrote:
> Thanks,
> I did not intend to make any (real) changes.
> The only thing that I did not intend to use from Barry's branch, that
> conflicted, was the help and comment block at the top of ex5cu.cu
> * I ended up with two declarations of PetscSplitCSRDataStructure
> * I added some includes to fix errors like this:
> /ccs/home/adams/petsc/include/../src/mat/impls/aij/seq/seqcusparse/cusparsematimpl.h(263):
> error: incomplete type is not allowed
> * I end ended not having csr2csc_i in Mat_SeqAIJCUSPARSE so I get:
> /autofs/nccs-svm1_home1/adams/petsc/src/mat/impls/aij/seq/seqcusparse/
> aijcusparse.cu(1348): error: class "Mat_SeqAIJCUSPARSE" has no member
> "csr2csc_i"
> On Fri, May 28, 2021 at 3:13 PM Stefano Zampini <stefano.zampini at gmail.com>
> wrote:
>> I can take a quick look at it tomorrow, what are the main changes you
>> made since then?
>> On May 28, 2021, at 9:51 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> I am getting messed up in trying to resolve conflicts in rebasing over
>> main.
>> Is there a better way of doing this?
>> Can I just tell git to use Barry's version and then test it?
>> Or should I just try it again?
>> On Fri, May 28, 2021 at 2:15 PM Mark Adams <mfadams at lbl.gov> wrote:
>>> I am rebasing over main and its a bit of a mess. I must have missed
>>> something. I get this. I think the _n_SplitCSRMat must be wrong.
>>> In file included from
>>> /autofs/nccs-svm1_home1/adams/petsc/src/vec/is/sf/impls/basic/sfbasic.c:128:0:
>>> /ccs/home/adams/petsc/include/petscmat.h:1976:32: error: conflicting
>>> types for 'PetscSplitCSRDataStructure'
>>>  typedef struct _n_SplitCSRMat *PetscSplitCSRDataStructure;
>>> /ccs/home/adams/petsc/include/petscmat.h:1922:31: note: previous
>>> declaration of 'PetscSplitCSRDataStructure' was here
>>>  typedef struct _p_SplitCSRMat PetscSplitCSRDataStructure;
>>>           CC arch-summit-opt-gnu-cuda/obj/vec/vec/impls/seq/dvec2.o
>>> On Fri, May 28, 2021 at 1:50 PM Stefano Zampini <
>>> stefano.zampini at gmail.com> wrote:
>>>> OpenMPI.py depends on cuda.py in that, if cuda is present, configures
>>>> using cuda. MPI.py or MPICH.py do not depend on cuda.py (MPICH, only
>>>> weakly, it adds a print if cuda is present)
>>>> Since eventually the MPI distro will only need a hint to be configured
>>>> with CUDA, why not removing the dependency at all and add only a flag
>>>> —download-openmpi-use-cuda?
>>>> On May 28, 2021, at 8:44 PM, Barry Smith <bsmith at petsc.dev> wrote:
>>>>  Stefano, who has a far better memory than me, wrote
>>>> > Or probably remove —download-openmpi ? Or, just for the moment, why
>>>> can’t we just tell configure that mpi is a weak dependence of cuda.py, so
>>>> that it will be forced to be configured later?
>>>>   MPI.py depends on cuda.py so we cannot also have cuda.py depend on
>>>> MPI.py using the generic dependencies of configure/packages
>>>>   but perhaps we can just hardwire the rerunning of cuda.py when the
>>>> MPI compilers are reset. I will try that now and if I can get it to work we
>>>> should be able to move those old fix branches along as MR.
>>>>   Barry
>>>> On May 28, 2021, at 12:41 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>> OK, I will try to rebase and test Barry's branch.
>>>> On Fri, May 28, 2021 at 1:26 PM Stefano Zampini <
>>>>> Yes, it is the branch I was using before force pushing to
>>>>> Barry’s barry/2020-11-11/cleanup-matsetvaluesdevice
>>>>> You can use both I guess
>>>>> On May 28, 2021, at 8:25 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>> Is this the correct branch? It conflicted with ex5cu so I assume it is.
>>>>> stefanozampini/simplify-setvalues-device
>>>>> <https://gitlab.com/petsc/petsc/-/tree/stefanozampini/simplify-setvalues-device>
>>>>> On Fri, May 28, 2021 at 1:24 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>> I am fixing rebasing this branch over main.
>>>>>> On Fri, May 28, 2021 at 1:16 PM Stefano Zampini <
>>>>>>> On May 28, 2021, at 8:12 PM, Stefano Zampini <
>>>>>>> That branch provides a fix for MatSetValuesDevice but it never got
>>>>>>> merged because of the CI issues with the —download-openmpi. We can probably
>>>>>>> try to skip the test in that specific configuration?
>>>>>>> On May 28, 2021, at 7:45 PM, Barry Smith <bsmith at petsc.dev> wrote:
>>>>>>> ~/petsc/src/mat/tutorials*
>>>>>>> (barry/2021-05-28/robustify-cuda-gencodearch-check=)*
>>>>>>> arch-robustify-cuda-gencodearch-check
>>>>>>> $ ./ex5cu
>>>>>>> terminate called after throwing an instance of
>>>>>>> 'thrust::system::system_error'
>>>>>>>   what():  fill_n: failed to synchronize: cudaErrorIllegalAddress:
>>>>>>> an illegal memory access was encountered
>>>>>>> Aborted (core dumped)
>>>>>>>         requires: cuda !define(PETSC_USE_CTABLE)
>>>>>>>   CI does not test with CUDA and no ctable.  The code is still
>>>>>>> broken as it was six months ago in the discussion Stefano pointed to. It is
>>>>>>> clear why just no one has had the time to clean things up.
>>>>>>>   Barry
>>>>>>> On May 28, 2021, at 11:13 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>> On Fri, May 28, 2021 at 11:57 AM Stefano Zampini <
>>>>>>>> If you are referring to your device set values, I guess it is not
>>>>>>>> currently tested
>>>>>>> No. There is a test for that (ex5cu).
>>>>>>> I have a user that is getting a segv in MatSetValues with
>>>>>>> aijcusparse. I suspect there is memory corruption but I'm trying to cover
>>>>>>> all the bases.
>>>>>>> I have added a cuda test to ksp/ex56 that works. I can do an MR for
>>>>>>> it if such a test does not exist.
>>>>>>>> See the discussions here
>>>>>>>> https://gitlab.com/petsc/petsc/-/merge_requests/3411
>>>>>>>> I started cleaning up the code to prepare for testing but we never
>>>>>>>> finished it
>>>>>>>> https://gitlab.com/petsc/petsc/-/commits/stefanozampini/simplify-setvalues-device/
>>>>>>>> On May 28, 2021, at 6:53 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>> Is there a test with MatSetValues and CUDA?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210530/62d6c62a/attachment.html>
