[petsc-users] strange segv
Barry Smith bsmith at petsc.dev
Sat May 29 18:48:53 CDT 2021
   I don't see why it is not running the Kokkos check. Here is the rule right below the CUDA rule that is apparently running.
check_build:
	- at echo "Running check examples to verify correct installation"
	- at echo "Using PETSC_DIR=${PETSC_DIR} and PETSC_ARCH=${PETSC_ARCH}"
	+ at cd src/snes/tutorials >/dev/null; ${OMAKE_SELF} PETSC_ARCH=${PETSC_ARCH}  PETSC_DIR=${PETSC_DIR} clean-legacy
	+ at cd src/snes/tutorials >/dev/null; ${OMAKE_SELF} PETSC_ARCH=${PETSC_ARCH}  PETSC_DIR=${PETSC_DIR} testex19
	+ at if [ "${HYPRE_LIB}" != "" ] && [ "${PETSC_WITH_BATCH}" = "" ] &&  [ "${PETSC_SCALAR}" = "real" ]; then \
          cd src/snes/tutorials >/dev/null; ${OMAKE_SELF} PETSC_ARCH=${PETSC_ARCH}  PETSC_DIR=${PETSC_DIR} DIFF=${PETSC_DIR}/lib/petsc/bin/petscdiff runex19_hypre; \
         fi;
	+ at if [ "${CUDA_LIB}" != "" ] && [ "${PETSC_WITH_BATCH}" = "" ] &&  [ "${PETSC_SCALAR}" = "real" ]; then \
          cd src/snes/tutorials >/dev/null; ${OMAKE_SELF} PETSC_ARCH=${PETSC_ARCH}  PETSC_DIR=${PETSC_DIR} DIFF=${PETSC_DIR}/lib/petsc/bin/petscdiff runex19_cuda; \
         fi;
	+ at if [ "${KOKKOS_KERNELS_LIB}" != "" ] && [ "${PETSC_WITH_BATCH}" = "" ] &&  [ "${PETSC_SCALAR}" = "real" ] && [ "${PETSC_PRECISION}" = "double" ] && [ "${MPI_IS_MPIUNI}" = "0" ]; then \
          cd src/snes/tutorials >/dev/null; ${OMAKE_SELF} PETSC_ARCH=${PETSC_ARCH}  PETSC_DIR=${PETSC_DIR} DIFF=${PETSC_DIR}/lib/petsc/bin/petscdiff runex3k_kokkos; \
         fi;
  Regarding the debugging, if it is just one MPI rank (or even more) with GDB it will trap the error and show the exact line of source code where the error occurred and you can poke around at variables to see if they look corrupt or wrong (for example crazy address in a pointer), I don't know why your debugger is not giving more useful information.
  Barry
> On May 29, 2021, at 2:16 PM, Mark Adams <mfadams at lbl.gov> wrote:
> I am running on Summit with Kokkos-CUDA and I am getting a segv that looks like some sort of a compile/link mismatch. I also have a user with a C++ code that is getting strange segvs when calling MatSetValues with CUDA (I know MatSetValues is not a cupsarse method, but that is the report that I have). I have no idea if these are related but they both involve C -- C++ calls ...
> I started with a clean build (attached) and I ran in DDT. DDT stopped at the call in plexland.c to the KokkosLanau operator. I stepped into this function and then took this screenshot of the stack, with the Kokkos call and PETSc signal handler.
> Make check does not seem to be running Kokkos tests:
> 15:02 adams/landau-mass-opt *= /gpfs/alpine/csc314/scratch/adams/petsc$ make PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc PETSC_ARCH=arch-summit-opt-gnu-kokkos-notpl-cuda10 check
> Using PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc and PETSC_ARCH=arch-summit-opt-gnu-kokkos-notpl-cuda10
> C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI process
> C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI processes
> C/C++ example src/snes/tutorials/ex19 run successfully with cuda
> Completed test examples
> Also, I ran this AM with another branch that had not been rebased with main as recently as this branch (adams/landau-mass-opt).
> Any ideas?
> <make.log><configure.log><Screen Shot 2021-05-29 at 2.51.00 PM.png>
