[petsc-users] CUDA MatSetValues test
Mark Adams
mfadams at lbl.gov
Fri May 28 13:51:52 CDT 2021
I am getting messed up in trying to resolve conflicts in rebasing over main.
Is there a better way of doing this?
Can I just tell git to use Barry's version and then test it?
Or should I just try it again?
On Fri, May 28, 2021 at 2:15 PM Mark Adams <mfadams at lbl.gov> wrote:
> I am rebasing over main and its a bit of a mess. I must have missed
> something. I get this. I think the _n_SplitCSRMat must be wrong.
> In file included from
> /autofs/nccs-svm1_home1/adams/petsc/src/vec/is/sf/impls/basic/sfbasic.c:128:0:
> /ccs/home/adams/petsc/include/petscmat.h:1976:32: error: conflicting types
> for 'PetscSplitCSRDataStructure'
> typedef struct _n_SplitCSRMat *PetscSplitCSRDataStructure;
> /ccs/home/adams/petsc/include/petscmat.h:1922:31: note: previous
> declaration of 'PetscSplitCSRDataStructure' was here
> typedef struct _p_SplitCSRMat PetscSplitCSRDataStructure;
> CC arch-summit-opt-gnu-cuda/obj/vec/vec/impls/seq/dvec2.o
> On Fri, May 28, 2021 at 1:50 PM Stefano Zampini <stefano.zampini at gmail.com>
> wrote:
>> OpenMPI.py depends on cuda.py in that, if cuda is present, configures
>> using cuda. MPI.py or MPICH.py do not depend on cuda.py (MPICH, only
>> weakly, it adds a print if cuda is present)
>> Since eventually the MPI distro will only need a hint to be configured
>> with CUDA, why not removing the dependency at all and add only a flag
>> —download-openmpi-use-cuda?
>> On May 28, 2021, at 8:44 PM, Barry Smith <bsmith at petsc.dev> wrote:
>> Stefano, who has a far better memory than me, wrote
>> > Or probably remove —download-openmpi ? Or, just for the moment, why
>> can’t we just tell configure that mpi is a weak dependence of cuda.py, so
>> that it will be forced to be configured later?
>> MPI.py depends on cuda.py so we cannot also have cuda.py depend on
>> MPI.py using the generic dependencies of configure/packages
>> but perhaps we can just hardwire the rerunning of cuda.py when the MPI
>> compilers are reset. I will try that now and if I can get it to work we
>> should be able to move those old fix branches along as MR.
>> Barry
>> On May 28, 2021, at 12:41 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> OK, I will try to rebase and test Barry's branch.
>> On Fri, May 28, 2021 at 1:26 PM Stefano Zampini <
>> stefano.zampini at gmail.com> wrote:
>>> Yes, it is the branch I was using before force pushing to
>>> Barry’s barry/2020-11-11/cleanup-matsetvaluesdevice
>>> You can use both I guess
>>> On May 28, 2021, at 8:25 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> Is this the correct branch? It conflicted with ex5cu so I assume it is.
>>> stefanozampini/simplify-setvalues-device
>>> <https://gitlab.com/petsc/petsc/-/tree/stefanozampini/simplify-setvalues-device>
>>> On Fri, May 28, 2021 at 1:24 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>> I am fixing rebasing this branch over main.
>>>> On Fri, May 28, 2021 at 1:16 PM Stefano Zampini <
>>>>> On May 28, 2021, at 8:12 PM, Stefano Zampini <
>>>>> That branch provides a fix for MatSetValuesDevice but it never got
>>>>> merged because of the CI issues with the —download-openmpi. We can probably
>>>>> try to skip the test in that specific configuration?
>>>>> On May 28, 2021, at 7:45 PM, Barry Smith <bsmith at petsc.dev> wrote:
>>>>> ~/petsc/src/mat/tutorials*
>>>>> (barry/2021-05-28/robustify-cuda-gencodearch-check=)*
>>>>> arch-robustify-cuda-gencodearch-check
>>>>> $ ./ex5cu
>>>>> terminate called after throwing an instance of
>>>>> 'thrust::system::system_error'
>>>>> what(): fill_n: failed to synchronize: cudaErrorIllegalAddress: an
>>>>> illegal memory access was encountered
>>>>> Aborted (core dumped)
>>>>> requires: cuda !define(PETSC_USE_CTABLE)
>>>>> CI does not test with CUDA and no ctable. The code is still broken
>>>>> as it was six months ago in the discussion Stefano pointed to. It is clear
>>>>> why just no one has had the time to clean things up.
>>>>> Barry
>>>>> On May 28, 2021, at 11:13 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>> On Fri, May 28, 2021 at 11:57 AM Stefano Zampini <
>>>>>> If you are referring to your device set values, I guess it is not
>>>>>> currently tested
>>>>> No. There is a test for that (ex5cu).
>>>>> I have a user that is getting a segv in MatSetValues with aijcusparse.
>>>>> I suspect there is memory corruption but I'm trying to cover all the bases.
>>>>> I have added a cuda test to ksp/ex56 that works. I can do an MR for it
>>>>> if such a test does not exist.
>>>>>> See the discussions here
>>>>>> https://gitlab.com/petsc/petsc/-/merge_requests/3411
>>>>>> I started cleaning up the code to prepare for testing but we never
>>>>>> finished it
>>>>>> https://gitlab.com/petsc/petsc/-/commits/stefanozampini/simplify-setvalues-device/
>>>>>> On May 28, 2021, at 6:53 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>> Is there a test with MatSetValues and CUDA?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210528/8da28d9f/attachment-0001.html>
