[petsc-users] CUDA MatSetValues test
    Mark Adams
    mfadams at lbl.gov
    Fri May 28 12:24:16 CDT 2021
I am fixing rebasing this branch over main.
On Fri, May 28, 2021 at 1:16 PM Stefano Zampini <stefano.zampini at gmail.com>
wrote:
> Or probably remove —download-openmpi ? Or, just for the moment, why can’t
> we just tell configure that mpi is a weak dependence of cuda.py, so that it
> will be forced to be configured later?
> On May 28, 2021, at 8:12 PM, Stefano Zampini <stefano.zampini at gmail.com>
> wrote:
> That branch provides a fix for MatSetValuesDevice but it never got merged
> because of the CI issues with the —download-openmpi. We can probably try to
> skip the test in that specific configuration?
> On May 28, 2021, at 7:45 PM, Barry Smith <bsmith at petsc.dev> wrote:
> ~/petsc/src/mat/tutorials*
> (barry/2021-05-28/robustify-cuda-gencodearch-check=)*
> arch-robustify-cuda-gencodearch-check
> $ ./ex5cu
> terminate called after throwing an instance of
> 'thrust::system::system_error'
>   what():  fill_n: failed to synchronize: cudaErrorIllegalAddress: an
> illegal memory access was encountered
> Aborted (core dumped)
>         requires: cuda !define(PETSC_USE_CTABLE)
>   CI does not test with CUDA and no ctable.  The code is still broken as
> it was six months ago in the discussion Stefano pointed to. It is clear why
> just no one has had the time to clean things up.
>   Barry
> On May 28, 2021, at 11:13 AM, Mark Adams <mfadams at lbl.gov> wrote:
> On Fri, May 28, 2021 at 11:57 AM Stefano Zampini <
> stefano.zampini at gmail.com> wrote:
>> If you are referring to your device set values, I guess it is not
>> currently tested
> No. There is a test for that (ex5cu).
> I have a user that is getting a segv in MatSetValues with aijcusparse. I
> suspect there is memory corruption but I'm trying to cover all the bases.
> I have added a cuda test to ksp/ex56 that works. I can do an MR for it if
> such a test does not exist.
>> See the discussions here
>> https://gitlab.com/petsc/petsc/-/merge_requests/3411
>> I started cleaning up the code to prepare for testing but we never
>> finished it
>> https://gitlab.com/petsc/petsc/-/commits/stefanozampini/simplify-setvalues-device/
>> On May 28, 2021, at 6:53 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> Is there a test with MatSetValues and CUDA?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210528/f14ae549/attachment.html>
