[petsc-users] CUDA MatSetValues test
Barry Smith bsmith at petsc.dev
Fri May 28 11:45:55 CDT 2021
~/petsc/src/mat/tutorials (barry/2021-05-28/robustify-cuda-gencodearch-check=) arch-robustify-cuda-gencodearch-check
$ ./ex5cu
terminate called after throwing an instance of 'thrust::system::system_error'
  what():  fill_n: failed to synchronize: cudaErrorIllegalAddress: an illegal memory access was encountered
Aborted (core dumped)
        requires: cuda !define(PETSC_USE_CTABLE)
  CI does not test with CUDA and no ctable.  The code is still broken as it was six months ago in the discussion Stefano pointed to. It is clear why just no one has had the time to clean things up.
  Barry
> On May 28, 2021, at 11:13 AM, Mark Adams <mfadams at lbl.gov> wrote:
> On Fri, May 28, 2021 at 11:57 AM Stefano Zampini <stefano.zampini at gmail.com <mailto:stefano.zampini at gmail.com>> wrote:
> If you are referring to your device set values, I guess it is not currently tested
> No. There is a test for that (ex5cu).
> I have a user that is getting a segv in MatSetValues with aijcusparse. I suspect there is memory corruption but I'm trying to cover all the bases.
> I have added a cuda test to ksp/ex56 that works. I can do an MR for it if such a test does not exist.
> See the discussions here https://gitlab.com/petsc/petsc/-/merge_requests/3411 <https://gitlab.com/petsc/petsc/-/merge_requests/3411>
> I started cleaning up the code to prepare for testing but we never finished it https://gitlab.com/petsc/petsc/-/commits/stefanozampini/simplify-setvalues-device/ <https://gitlab.com/petsc/petsc/-/commits/stefanozampini/simplify-setvalues-device/>
>> On May 28, 2021, at 6:53 PM, Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>> Is there a test with MatSetValues and CUDA?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210528/9a012d57/attachment.html>
