[petsc-users] Did CUDA break again?
Junchao Zhang
junchao.zhang at gmail.com
Wed May 26 21:10:02 CDT 2021
On Wed, May 26, 2021 at 6:13 PM Barry Smith <bsmith at petsc.dev> wrote:
> What is HOST=cori09 Does it have GPUs?
> https://docs.nvidia.com/cuda/cuda-runtime-api/structcudaDeviceProp.html#structcudaDeviceProp_164490976c8e07e028a8f1ce1f5cd42d6
> Seems to clearly state
> int cudaDeviceProp
> <https://docs.nvidia.com/cuda/cuda-runtime-api/structcudaDeviceProp.html#structcudaDeviceProp>
> ::major
> <https://docs.nvidia.com/cuda/cuda-runtime-api/structcudaDeviceProp.html#structcudaDeviceProp_164490976c8e07e028a8f1ce1f5cd42d6>
> [inherited]
> Major compute capability
> Mark, please compile and run this program on the machine you are running
> configure on
> #include <stdio.h>
> #include <cuda.h>
> #include <cuda_runtime.h>
> #include <cuda_runtime_api.h>
> #include <cuda_device_runtime_api.h>
> int main(int arg,char **args)
> struct cudaDeviceProp dp;
> cudaGetDeviceProperties(&dp, 0);
> printf("%d\n",10*dp.major+dp.minor);
> int major,minor;
> cuDeviceGetAttribute(&major, CU_DEVICE_ATTRIBUTE_COMPUTE_CAPABILITY_MAJOR,
> 0);
> cuDeviceGetAttribute(&minor, CU_DEVICE_ATTRIBUTE_COMPUTE_CAPABILITY_MINOR,
> 0);
> printf("%d\n",10*major+minor);
> return(0);
Probably, you need to check the return code of these two function calls to
make sure they are correct.
> This is what I get
> $ nvcc mytest.c -lcuda
> ~/petsc* (main=)* arch-main
> $ ./a.out
> 70
> 70
> Which is exactly what it is suppose to do.
> Barry
> On May 26, 2021, at 5:31 PM, Barry Smith <bsmith at petsc.dev> wrote:
> Yes, this code which I guess never got hit before
> cudaDeviceProp dp; cudaGetDeviceProperties(&dp, 0);
> return(0);;
> is using the wrong property for the generation.
> Back to the CUDA documentation for the correct information.
> On May 26, 2021, at 3:47 PM, Jacob Faibussowitsch <jacob.fai at gmail.com>
> wrote:
> 1120 sounds suspiciously like some CUDA version rather than architecture
> or compute capability…
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> Cell: +1 (312) 694-3391
> On May 26, 2021, at 22:29, Mark Adams <mfadams at lbl.gov> wrote:
> I started to get this error today on Cori.
> nvcc fatal : Unsupported gpu architecture 'compute_1120'
> I am pretty sure I had a clean build but I can redo it if you don't know
> where this is from.
> Thanks,
> Mark
> <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210526/5b6bfb76/attachment-0001.html>
