[petsc-users] Collect Trajectories components
Francesco Brarda
brardafrancesco at gmail.com
Wed May 26 05:20:17 CDT 2021
Hi!
I solved an ODE system with TS. Now I would like to save one of the trajectories in specific times. To do so, I used TSTrajectoryGetVecs.
The values of the variable I am interested in is on one processor. I want to collect these values in a parallel vector, but I had the error:
[0]PETSC ERROR: Invalid argument
[0]PETSC ERROR: Real value must be same on all processes, argument # 2
[0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.14.4, unknown
[0]PETSC ERROR: ./petsc_sir on a arch-debug named srvulx13 by fbrarda Wed May 26 12:00:42 2021
[0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --with-openblas-dir=/opt/packages/openblas/0.2.13-gcc --download-mpich PETSC_ARCH=arch-debug
[0]PETSC ERROR: #1 TSHistoryGetLocFromTime() line 134 in /home/fbrarda/petsc/src/ts/interface/tshistory.c
[0]PETSC ERROR: #2 TSTrajectoryReconstruct_Private() line 55 in /home/fbrarda/petsc/src/ts/trajectory/utils/reconstruct.c
[0]PETSC ERROR: #3 TSTrajectoryGetVecs() line 239 in /home/fbrarda/petsc/src/ts/trajectory/interface/traj.c
Is there any specific routine I can use to overcome this issue? Should I use VecScatter?
I hope I made myself clear.
Best,
Francesco
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210526/8989ba86/attachment.html>
