[petsc-users] Help needed with MUMPS solver
Karl Yang
y.juntao at hotmail.com
Sun May 23 10:16:51 CDT 2021
Hello,
I am using MUMPS direct solver for my project. I used the following options for solving my problem and it works in most cases. But for some cases I encounter a divergence error. But I think it is actually error due to MUMPS?
I'm not sure how to debug the error. It is appreciated if anyone familiar with MUMPS solver to offer me some guidance.
regards
Juntao
MUMPS options:
PetscOptionsSetValue(NULL, "-ksp_type", "preonly");
PetscOptionsSetValue(NULL, "-pc_type", "cholesky");
PetscOptionsSetValue(NULL, "-pc_factor_mat_solver_type", "mumps");
PetscOptionsSetValue(NULL, "-mat_mumps_icntl_1", "1");
PetscOptionsSetValue(NULL, "-mat_mumps_icntl_2", "1");
PetscOptionsSetValue(NULL, "-mat_mumps_icntl_3", "1");
PetscOptionsSetValue(NULL, "-mat_mumps_icntl_4", "3");
PetscOptionsSetValue(NULL, "-mat_mumps_icntl_28", "1");
PetscOptionsSetValue(NULL, "-mat_mumps_icntl_7", "2");
PetscOptionsSetValue(NULL, "-mat_mumps_icntl_24", "1");
Log output from MUMPS and error message from PETSC at the bottom
Entering DMUMPS 5.2.1 from C interface with JOB, N, NNZ = 1 240 2448
executing #MPI = 1, without OMP
MUMPS compiled with option -Dmetis
MUMPS compiled with option -Dptscotch
MUMPS compiled with option -Dscotch
This MUMPS version includes code for SAVE_RESTORE
L D L^T Solver for general symmetric matrices
Type of parallelism: Working host
****** ANALYSIS STEP ********
Scaling will be computed during analysis
Compute maximum matching (Maximum Transversal): 5
... JOB = 5: MAXIMIZE PRODUCT DIAGONAL AND SCALE
Entering analysis phase with ...
N NNZ LIW INFO(1)
240 2448 5137 0
Matrix entries: IRN() ICN()
1 1 1 2 1 3
1 4 1 5 1 6
1 7 1 8 1 9
1 10
Average density of rows/columns = 18
Ordering based on AMF
Constrained Ordering based on AMF
NFSIZ(.) = 0 38 14 0 33 33 0 0 0 0
FILS (.) = 0 148 4 -96 224 163 20 -43 8 1
FRERE(.) = 241 -5 -6 241 0 -2 241 241 241 241
Leaving analysis phase with ...
INFOG(1) = 0
INFOG(2) = 0
-- (20) Number of entries in factors (estim.) = 3750
-- (3) Real space for factors (estimated) = 4641
-- (4) Integer space for factors (estimated) = 2816
-- (5) Maximum frontal size (estimated) = 38
-- (6) Number of nodes in the tree = 56
-- (32) Type of analysis effectively used = 1
-- (7) Ordering option effectively used = 2
ICNTL(6) Maximum transversal option = 0
ICNTL(7) Pivot order option = 2
ICNTL(14) Percentage of memory relaxation = 20
Number of level 2 nodes = 0
Number of split nodes = 0
RINFOG(1) Operations during elimination (estim)= 7.137D+04
Ordering compressed/constrained (ICNTL(12)) = 3
MEMORY ESTIMATIONS ...
Estimations with standard Full-Rank (FR) factorization:
Total space in MBytes, IC factorization (INFOG(17)): 0
Total space in MBytes, OOC factorization (INFOG(27)): 0
Elapsed time in analysis driver= 0.0016
Entering DMUMPS 5.2.1 from C interface with JOB, N, NNZ = 2 240 2448
****** FACTORIZATION STEP ********
GLOBAL STATISTICS PRIOR NUMERICAL FACTORIZATION ...
Number of working processes = 1
ICNTL(22) Out-of-core option = 0
ICNTL(35) BLR activation (eff. choice) = 0
ICNTL(14) Memory relaxation = 20
INFOG(3) Real space for factors (estimated)= 4641
INFOG(4) Integer space for factors (estim.)= 2816
Memory allowed (MB -- 0: N/A ) = 0
Memory provided by user, sum of LWK_USER = 0
Relative threshold for pivoting, CNTL(1) = 0.1000D-01
ZERO PIVOT DETECTION ON, THRESHOLD = 2.8931920285365730E-020
INFINITE FIXATION
Effective size of S (based on INFO(39))= 7981
Elapsed time to reformat/distribute matrix = 0.0001
** Memory allocated, total in Mbytes (INFOG(19)): 0
** Memory effectively used, total in Mbytes (INFOG(22)): 0
** Memory dynamically allocated for CB, total in Mbytes : 0
Elapsed time for factorization = 0.0006
Leaving factorization with ...
RINFOG(2) Operations in node assembly = 5.976D+03
------(3) Operations in node elimination = 1.197D+05
INFOG (9) Real space for factors = 6193
INFOG(10) Integer space for factors = 3036
INFOG(11) Maximum front size = 42
INFOG(29) Number of entries in factors = 4896
INFOG(12) Number of negative pivots = 79
INFOG(13) Number of delayed pivots = 110
Number of 2x2 pivots in type 1 nodes = 1
Number of 2X2 pivots in type 2 nodes = 0
Nb of null pivots detected by ICNTL(24) = 0
INFOG(28) Estimated deficiency = 0
INFOG(14) Number of memory compress = 0
Elapsed time in factorization driver= 0.0009
Entering DMUMPS 5.2.1 from C interface with JOB, N, NNZ = 3 240 2448
****** SOLVE & CHECK STEP ********
GLOBAL STATISTICS PRIOR SOLVE PHASE ...........
Number of right-hand-sides = 1
Blocking factor for multiple rhs = 1
ICNTL (9) = 1
--- (10) = 0
--- (11) = 0
--- (20) = 0
--- (21) = 0
--- (30) = 0
--- (35) = 0
Vector solution for column 1
RHS
-7.828363D-02 -3.255337D+00 1.054729D+00 1.379822D-01 -3.892113D-01
1.433990D-01 1.089250D+00 2.252611D+00 3.215399D+00 -6.788806D-02
** Space in MBYTES used for solve : 0
Leaving solve with ...
Time to build/scatter RHS = 0.000003
Time in solution step (fwd/bwd) = 0.000167
.. Time in forward (fwd) step = 0.000053
.. Time in backward (bwd) step = 0.000093
Time to gather solution(cent.sol)= 0.000000
Time to copy/scale dist. solution= 0.000000
Elapsed time in solve driver= 0.0004
*** Warning: Verbose output for PETScKrylovSolver not implemented, calling PETSc KSPView directly.
KSP Object: 1 MPI processes
type: preonly
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
left preconditioning
using NONE norm type for convergence test
PC Object: 1 MPI processes
type: cholesky
out-of-place factorization
tolerance for zero pivot 2.22045e-14
matrix ordering: natural
factor fill ratio given 0., needed 0.
Factored matrix follows:
Mat Object: 1 MPI processes
type: mumps
rows=240, cols=240
package used to perform factorization: mumps
total: nonzeros=3750, allocated nonzeros=3750
total number of mallocs used during MatSetValues calls=0
MUMPS run parameters:
SYM (matrix type): 2
PAR (host participation): 1
ICNTL(1) (output for error): 1
ICNTL(2) (output of diagnostic msg): 1
ICNTL(3) (output for global info): 6
ICNTL(4) (level of printing): 3
ICNTL(5) (input mat struct): 0
ICNTL(6) (matrix prescaling): 7
ICNTL(7) (sequential matrix ordering):2
ICNTL(8) (scaling strategy): 77
ICNTL(10) (max num of refinements): 0
ICNTL(11) (error analysis): 0
ICNTL(12) (efficiency control): 0
ICNTL(13) (efficiency control): 1
ICNTL(14) (percentage of estimated workspace increase): 20
ICNTL(18) (input mat struct): 0
ICNTL(19) (Schur complement info): 0
ICNTL(20) (rhs sparse pattern): 0
ICNTL(21) (solution struct): 0
ICNTL(22) (in-core/out-of-core facility): 0
ICNTL(23) (max size of memory can be allocated locally):0
ICNTL(24) (detection of null pivot rows): 1
ICNTL(25) (computation of a null space basis): 0
ICNTL(26) (Schur options for rhs or solution): 0
ICNTL(27) (experimental parameter): -32
ICNTL(28) (use parallel or sequential ordering): 1
ICNTL(29) (parallel ordering): 0
ICNTL(30) (user-specified set of entries in inv(A)): 0
ICNTL(31) (factors is discarded in the solve phase): 0
ICNTL(33) (compute determinant): 0
ICNTL(35) (activate BLR based factorization): 0
ICNTL(36) (choice of BLR factorization variant): 0
ICNTL(38) (estimated compression rate of LU factors): 333
CNTL(1) (relative pivoting threshold): 0.01
CNTL(2) (stopping criterion of refinement): 1.49012e-08
CNTL(3) (absolute pivoting threshold): 0.
CNTL(4) (value of static pivoting): -1.
CNTL(5) (fixation for null pivots): 0.
CNTL(7) (dropping parameter for BLR): 0.
RINFO(1) (local estimated flops for the elimination after analysis):
[0] 71368.
RINFO(2) (local estimated flops for the assembly after factorization):
[0] 5976.
RINFO(3) (local estimated flops for the elimination after factorization):
[0] 119716.
INFO(15) (estimated size of (in MB) MUMPS internal data for running numerical factorization):
[0] 0
INFO(16) (size of (in MB) MUMPS internal data used during numerical factorization):
[0] 0
INFO(23) (num of pivots eliminated on this processor after factorization):
[0] 240
RINFOG(1) (global estimated flops for the elimination after analysis): 71368.
RINFOG(2) (global estimated flops for the assembly after factorization): 5976.
RINFOG(3) (global estimated flops for the elimination after factorization): 119716.
(RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant): (0.,0.)*(2^0)
INFOG(3) (estimated real workspace for factors on all processors after analysis): 4641
INFOG(4) (estimated integer workspace for factors on all processors after analysis): 2816
INFOG(5) (estimated maximum front size in the complete tree): 38
INFOG(6) (number of nodes in the complete tree): 56
INFOG(7) (ordering option effectively use after analysis): 2
INFOG(8) (structural symmetry in percent of the permuted matrix after analysis): 100
INFOG(9) (total real/complex workspace to store the matrix factors after factorization): 6193
INFOG(10) (total integer space store the matrix factors after factorization): 3036
INFOG(11) (order of largest frontal matrix after factorization): 42
INFOG(12) (number of off-diagonal pivots): 79
INFOG(13) (number of delayed pivots after factorization): 110
INFOG(14) (number of memory compress after factorization): 0
INFOG(15) (number of steps of iterative refinement after solution): 0
INFOG(16) (estimated size (in MB) of all MUMPS internal data for factorization after analysis: value on the most memory consuming processor): 0
INFOG(17) (estimated size of all MUMPS internal data for factorization after analysis: sum over all processors): 0
INFOG(18) (size of all MUMPS internal data allocated during factorization: value on the most memory consuming processor): 0
INFOG(19) (size of all MUMPS internal data allocated during factorization: sum over all processors): 0
INFOG(20) (estimated number of entries in the factors): 3750
INFOG(21) (size in MB of memory effectively used during factorization - value on the most memory consuming processor): 0
INFOG(22) (size in MB of memory effectively used during factorization - sum over all processors): 0
INFOG(23) (after analysis: value of ICNTL(6) effectively used): 5
INFOG(24) (after analysis: value of ICNTL(12) effectively used): 3
INFOG(25) (after factorization: number of pivots modified by static pivoting): 0
INFOG(28) (after factorization: number of null pivots encountered): 0
INFOG(29) (after factorization: effective number of entries in the factors (sum over all processors)): 4896
INFOG(30, 31) (after solution: size in Mbytes of memory used during solution phase): 0, 0
INFOG(32) (after analysis: type of analysis done): 1
INFOG(33) (value used for ICNTL(8)): -2
INFOG(34) (exponent of the determinant if determinant is requested): 0
INFOG(35) (after factorization: number of entries taking into account BLR factor compression - sum over all processors): 4896
INFOG(36) (after analysis: estimated size of all MUMPS internal data for running BLR in-core - value on the most memory consuming processor): 0
INFOG(37) (after analysis: estimated size of all MUMPS internal data for running BLR in-core - sum over all processors): 0
INFOG(38) (after analysis: estimated size of all MUMPS internal data for running BLR out-of-core - value on the most memory consuming processor): 0
INFOG(39) (after analysis: estimated size of all MUMPS internal data for running BLR out-of-core - sum over all processors): 0
linear system matrix = precond matrix:
type: seqaij
rows=240, cols=240
total: nonzeros=4656, allocated nonzeros=4656
using I-node routines: found 167 nodes, limit used is 5
Entering DMUMPS 5.2.1 from C interface with JOB = -2
rank: 0 coefficient: 0.132368
Entering DMUMPS 5.2.1 from C interface with JOB, N, NNZ = 1 960 9792
N NNZ LIW INFO(1)
960 9792 20545 0
1 1 1 2 1 3
1 4 1 5 1 6
1 7 1 8 1 9
1 10
NFSIZ(.) = 0 0 0 58 0 0 0 73 14 0
FILS (.) = 0 -747 -80 922 146 5 6 669 3 1
FRERE(.) = 961 961 961 0 961 961 961 -4 -69 961
INFOG(1) = 0
INFOG(2) = 0
-- (20) Number of entries in factors (estim.) = 20336
-- (3) Real space for factors (estimated) = 24094
-- (4) Integer space for factors (estimated) = 12143
-- (5) Maximum frontal size (estimated) = 80
-- (6) Number of nodes in the tree = 227
RINFOG(1) Operations during elimination (estim)= 6.966D+05
Total space in MBytes, IC factorization (INFOG(17)): 1
Total space in MBytes, OOC factorization (INFOG(27)): 1
Elapsed time in analysis driver= 0.0066
Entering DMUMPS 5.2.1 from C interface with JOB, N, NNZ = 2 960 9792
INFOG(3) Real space for factors (estimated)= 24094
INFOG(4) Integer space for factors (estim.)= 12143
ZERO PIVOT DETECTION ON, THRESHOLD = 2.9434468577175697E-020
INFINITE FIXATION
Effective size of S (based on INFO(39))= 31314
Elapsed time to reformat/distribute matrix = 0.0006
** Memory allocated, total in Mbytes (INFOG(19)): 1
** Memory effectively used, total in Mbytes (INFOG(22)): 1
Elapsed time for (failed) factorization = 0.0032
RINFOG(2) Operations in node assembly = 3.366D+04
------(3) Operations in node elimination = 9.346D+05
INFOG (9) Real space for factors = 26980
INFOG(10) Integer space for factors = 13047
INFOG(11) Maximum front size = 84
INFOG(29) Number of entries in factors = 24047
INFOG(12) Number of negative pivots = 294
INFOG(13) Number of delayed pivots = 452
Number of 2x2 pivots in type 1 nodes = 0
INFOG(14) Number of memory compress = 1
Elapsed time in factorization driver= 0.0042
On return from DMUMPS, INFOG(1)= -9
On return from DMUMPS, INFOG(2)= 22
terminate called after throwing an instance of 'std::runtime_error'
what():
*** DOLFIN encountered an error. If you are not able to resolve this issue
*** using the information listed below, you can ask for help at
*** fenics-support at googlegroups.com
*** Remember to include the error message listed below and, if possible,
*** include a *minimal* running example to reproduce the error.
*** Error: Unable to solve linear system using PETSc Krylov solver.
*** Reason: Solution failed to converge in 0 iterations (PETSc reason DIVERGED_PC_FAILED, residual norm ||r|| = 0.000000e+00).
*** Where: This error was encountered inside PETScKrylovSolver.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: 74d7efe1e84d65e9433fd96c50f1d278fa3e3f3f
Aborted (core dumped)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210523/124e03c3/attachment-0001.html>
