[petsc-users] MatChop
Emmanuel Ayala
juaneah at gmail.com
Fri May 21 11:15:50 CDT 2021
Hi Pierre,
Your suggestion works fine for me.
Thanks.
El vie, 21 de may. de 2021 a la(s) 11:03, Stefano Zampini (
stefano.zampini at gmail.com) escribió:
> Emmanuel
> thanks for reporting this.
> I believe we have a regression in MatChop from
> https://gitlab.com/petsc/petsc/-/commit/038df967165af8ac6c3de46a36f650566a7db07c
> (cc'ing Pierre)
> We call MatAssemblyBegin/End within the row loop. Also. I don't understand
> why we need to check for r < rend herre
> https://gitlab.com/petsc/petsc/-/blob/038df967165af8ac6c3de46a36f650566a7db07c/src/mat/utils/axpy.c#L513.
> nor why we need to allocate newCols (can use cols)
> Pierre, can you take a look?
> Il giorno ven 21 mag 2021 alle ore 18:49 Emmanuel Ayala <juaneah at gmail.com>
> ha scritto:
>> Hi everybody,
>> I just updated petsc from version 13 to 15. Before the update everything
>> works well, then my code give me an error:
>> [9]PETSC ERROR: --------------------- Error Message
>> [9]PETSC ERROR: Invalid argument
>> [9]PETSC ERROR: Setting off process row 53484 even though
>> MatSetOption(,MAT_NO_OFF_PROC_ENTRIES,PETSC_TRUE) was set
>> [9]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> [9]PETSC ERROR: Petsc Release Version 3.15.0, Mar 30, 2021
>> [9]PETSC ERROR: ./comp on a arch-linux-c-opt-O2-superlud_mumps_hyp named
>> eayala by ayala Fri May 21 10:40:36 2021
>> [9]PETSC ERROR: Configure options --with-debugging=0 COPTFLAGS="-O2
>> -march=native -mtune=native" CXXOPTFLAGS="-O2 -march=native -mtune=native"
>> FOPTFLAGS="-O2 -march=native -mtune=native" --download-mpich
>> --download-hypre --download-mumps --download-scalapack --download-parmetis
>> --download-metis --download-superlu_dist --download-cmake
>> --download-fblaslapack=1 --with-cxx-dialect=C++11
>> The error appears after a matrix assembly, the matrix was created with
>> DMCreateMatrix and updated with MatSetValuesLocal.
>> A Little work around I found the solution, avoid using MatChop on this
>> matrix, but I still need to use MatChop. There is any reason to have this
>> problem?
>> Thanks in advance.
> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210521/d57a1f54/attachment.html>
