[petsc-users] MatChop
Pierre Jolivet
pierre at joliv.et
Fri May 21 11:02:09 CDT 2021
Hello Emmanuel,
I broke that, so I’ll fix it.
I think you can bypass the error by explicitly resetting the appropriate option after your call to MatChop()?
ierr = MatChop(A, tol);CHKERRQ(ierr);
ierr = MatSetOption(A, MAT_NO_OFF_PROC_ENTRIES, PETSC_FALSE);CHKERRQ(ierr);
Pierre
> On 21 May 2021, at 5:49 PM, Emmanuel Ayala <juaneah at gmail.com> wrote:
> Hi everybody,
> I just updated petsc from version 13 to 15. Before the update everything works well, then my code give me an error:
> [9]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [9]PETSC ERROR: Invalid argument
> [9]PETSC ERROR: Setting off process row 53484 even though MatSetOption(,MAT_NO_OFF_PROC_ENTRIES,PETSC_TRUE) was set
> [9]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html <https://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble shooting.
> [9]PETSC ERROR: Petsc Release Version 3.15.0, Mar 30, 2021
> [9]PETSC ERROR: ./comp on a arch-linux-c-opt-O2-superlud_mumps_hyp named eayala by ayala Fri May 21 10:40:36 2021
> [9]PETSC ERROR: Configure options --with-debugging=0 COPTFLAGS="-O2 -march=native -mtune=native" CXXOPTFLAGS="-O2 -march=native -mtune=native" FOPTFLAGS="-O2 -march=native -mtune=native" --download-mpich --download-hypre --download-mumps --download-scalapack --download-parmetis --download-metis --download-superlu_dist --download-cmake --download-fblaslapack=1 --with-cxx-dialect=C++11
> The error appears after a matrix assembly, the matrix was created with DMCreateMatrix and updated with MatSetValuesLocal.
> A Little work around I found the solution, avoid using MatChop on this matrix, but I still need to use MatChop. There is any reason to have this problem?
> Thanks in advance.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210521/a2672078/attachment.html>
