[petsc-users] Nested SNES in FormFunction
Matthew Knepley
knepley at gmail.com
Fri May 21 09:01:19 CDT 2021
On Fri, May 21, 2021 at 9:34 AM Pierre Bernigaud <pierrebernigaudl at gmail.com>
wrote:
> Greetings,
> I am currently working on a CFD solver using PETSc. I have a non linear
> system which is solved using 2D_DMDA/SNES, and submitted to boundary
> conditions that are treated implicitly and updated in the FormFunction. The
> calculation of one of these boundary conditions requires the resolution of
> an other non linear system.
> I am hence using a nested 1D_DMDA/SNES system within the FormFunction of
> my main SNES solver to solve for this boundary condition. This is working
> fine, but doing a scalability study we found out that this causes the code
> to show sub-par acceleration properties.
> Have you ever encountered this kind of nested SNES application, and are
> there some critical points to be aware of in order to avoid a loss of
> performances?
> For instance, the sub 1D_DMDA/SNES objects are created and destroyed at
> each update of the boundary, hence at each call to FormFunction, which
> results in an important number of object manipulation. Could this be a
> problem?
Yes. You should keep this subsolver around for as long as the outer solver
lives.
> Furthermore, the use of a sub 1D_DMDA/SNES allows to use multiple
> processors to solve for the boundary condition, composed of say N cells.
> When running the code with M > N processors, everything is working great,
> but I am curious about the state of the (M-N) processors which aren’t
> working on boundary condition problem. Do they just stay idle?
Yes, they are idle. You could try to fold the boundary condition into the
same system as the bulk, but this is not a clear win since you will still
have load imbalance.
What percentage of time does the boundary solve take?
Matt
> Thank you for your help.
> Respectfully,
> Pierre Bernigaud
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210521/56ee6421/attachment.html>
