[petsc-users] Code hangs when calling PetscIntView (MPI, fortran)
dazza simplythebest
sayosale at hotmail.com
Thu May 20 04:32:26 CDT 2021
Dear Jose,
Many thanks for the prompt explanation - that would definitely explain what is going on,
I will adjust my code accordingly .
Thanks again,
Dan.
Sent: Thursday, May 20, 2021 9:06 AM
To: dazza simplythebest <sayosale at hotmail.com>
Cc: PETSc users list <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Code hangs when calling PetscIntView (MPI, fortran)
If you look at the manpage https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscIntView.html you will see that PetscIntView() is collective. This means that all MPI processes must call this function, so it is forbidden to call it within an IF rank==...
Jose
> El 20 may 2021, a las 10:25, dazza simplythebest <sayosale at hotmail.com> escribió:
> Dear All,
> As part of preparing a code to call the SLEPC eigenvalue solving library,
> I am constructing a matrix in sparse CSR format row-by-row. Just for debugging
> purposes I write out the column values for a given row, which are stored in a
> PetscInt allocatable vector, using PetscIntView.
> Everything works fine when the number of MPI processes exactly divide the
> number of rows of the matrix, and so each process owns the same number of rows.
> However, when the number of MPI processes does not exactly divide the
> number of rows of the matrix, and so each process owns a different number of rows,
> the code hangs when it reaches the line that calls PetscIntView.
> To be precise the code hangs on the final row that a process, other than root, owns.
> If I however comment out the call to PetscIntView the code completes without error,
> and produces the correct eigenvalues (hence we are not missing a row / miswriting a row).
> Note also that a simple direct writeout of this same array using a plain fortran command
> will write out the array without problem.
> I have attached below a small code that reproduces the problem.
> For this code we have nominally assigned 200 rows to our matrix. The code runs without
> problem using 1,2,4,5,8 or 10 MPI processes, all of which precisely divide 200,
> but will hang for 3 MPI processes for example.
> For the case of 3 MPI processes the subroutine WHOSE_ROW_IS_IT allocates the rows
> to each process as :
> process no first row last row no. of rows
> 0 1 66 66
> 1 67 133 67
> 2 134 200 67
> The code will hang when process 1 calls PetscIntView for its last row, row 133 for example.
> One piece of additional information that may be relevant is that the code does run to completion
> without hanging if I comment out the final slepc/MPI finalisation command
> CALL SlepcFinalize(ierr_pets)
> (I of course I get ' bad termination' errors, but the otherwise the run is successful.)
> I would appreciate it if anyone has any ideas on what is going wrong!
> Many thanks,
> Dan.
> code:
> MODULE ALL_STAB_ROUTINES
> IMPLICIT NONE
> CONTAINS
> SUBROUTINE WHOSE_ROW_IS_IT(ROW_NO, TOTAL_NO_ROWS, NO_PROCESSES, &
> & OWNER)
> ! THIS ROUTINE ALLOCATES ROWS EVENLY BETWEEN mpi PROCESSES
> #include <slepc/finclude/slepceps.h>
> use slepceps
> IMPLICIT NONE
> PetscInt, INTENT(IN) :: ROW_NO, TOTAL_NO_ROWS, NO_PROCESSES
> PetscInt, INTENT(OUT) :: OWNER
> PetscInt :: P, REM
> P = TOTAL_NO_ROWS / NO_PROCESSES ! NOTE INTEGER DIVISION
> REM = TOTAL_NO_ROWS - P*NO_PROCESSES
> IF (ROW_NO < (NO_PROCESSES - REM)*P + 1 ) THEN
> OWNER = (ROW_NO - 1)/P ! NOTE INTEGER DIVISION
> ELSE
> OWNER = ( ROW_NO + NO_PROCESSES - REM -1 )/(P+1) ! NOTE INTEGER DIVISION
> ENDIF
> END SUBROUTINE WHOSE_ROW_IS_IT
> END MODULE ALL_STAB_ROUTINES
> PROGRAM trialer
> USE MPI
> use slepceps
> USE ALL_STAB_ROUTINES
> IMPLICIT NONE
> PetscMPIInt rank3, total_mpi_size
> PetscInt nl3, code, PROC_ROW, ISTATUS, jm, N_rows,NO_A_ENTRIES
> PetscInt, ALLOCATABLE, DIMENSION(:) :: JALOC
> PetscInt, PARAMETER :: ZERO = 0 , ONE = 1, TWO = 2, THREE = 3
> PetscErrorCode ierr_pets
> ! Initialise sleps/mpi
> call SlepcInitialize(PETSC_NULL_CHARACTER,ierr_pets) ! note that this initialises MPI
> call MPI_COMM_SIZE(MPI_COMM_WORLD, total_mpi_size, ierr_pets) !! find total no of MPI processes
> nL3= total_mpi_size
> call MPI_COMM_RANK(MPI_COMM_WORLD,rank3,ierr_pets) !! find my overall rank -> rank3
> write(*,*)'Welcome: PROCESS NO , TOTAL NO. OF PROCESSES = ',rank3, nl3
> N_rows = 200 ! NUMBER OF ROWS OF A NOTIONAL MATRIX
> NO_A_ENTRIES = 12 ! NUMBER OF ENTRIES FOR JALOC
> ! LOOP OVER ROWS
> do jm = 1, N_rows
> CALL whose_row_is_it(JM, N_rows , NL3, PROC_ROW) ! FIND OUT WHICH PROCESS OWNS ROW
> if (rank3 == PROC_ROW) then ! IF mpi PROCESS OWNS THIS ROW THEN ..
> ! ALLOCATE jaloc ARRAY AND INITIALISE
> allocate(jaloc(NO_A_ENTRIES), STAT=ISTATUS )
> jaloc = three
> WRITE(*,*)'JALOC',JALOC ! THIS SIMPLE PLOT ALWAYS WORKS
> write(*,*)'calling PetscIntView: PROCESS NO. ROW NO.',rank3, jm
> ! THIS CALL TO PetscIntView CAUSES CODE TO HANG WHEN E.G. total_mpi_size=3, JM=133
> call PetscIntView(NO_A_ENTRIES,JALOC(1:NO_A_ENTRIES), &
> & PETSC_VIEWER_STDOUT_WORLD, ierr_pets)
> CHKERRA(ierr_pets)
> deallocate(jaloc)
> endif
> enddo
> end program trialer
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210520/5dbb192e/attachment-0001.html>
