[petsc-users] Using SNES to solve Non linear elasticity, passing matrix to form function
Jed Brown
jed at jedbrown.org
Wed May 19 12:50:21 CDT 2021
You may be interested in discussion of computing and representing Newton linearizations for hyperelasticity starting here:
https://libceed.readthedocs.io/en/latest/examples/solids/#id4
Kaushik Vijaykumar <kaushikv318 at gmail.com> writes:
> Thanks Matt, for pointing me in the right direction.
> On Wed, May 19, 2021 at 1:42 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Wed, May 19, 2021 at 1:30 PM Kaushik Vijaykumar <kaushikv318 at gmail.com>
>> wrote:
>>> Matt,
>>> Thanks for the comment, I see your point now. I was using the linear
>>> elastic [K] from the previous load step as the guess for the jacobian. The
>>> stiffness matrix was being built outside formfunction using displacements
>>> from the previous load step. What is the best approach, Build [K] abd {F}
>>> inside the form function and compute the residual [K]_{i}{U}_{i} - {F}_{i},
>>> where i designates the iterated matrices and vector for a given load step ?
>> Yes, exactly. You want the residual
>> F(U) = 0
>> which for you sounds like
>> K(U) U - F = 0
>> and then the Jacobian callback builds
>> K(U)
>> from the input U.
>> Thanks,
>> Matt
>>> Thanks
>>> Kaushik
>>> On Wed, May 19, 2021 at 11:51 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Wed, May 19, 2021 at 11:48 AM Kaushik Vijaykumar <
>>>> kaushikv318 at gmail.com> wrote:
>>>>> Barry,
>>>>> Thanks for your response. I am trying to copy K into Kloc, the purpose
>>>>> of doing that is to calculate the residual in formfunction - Residual =
>>>>> [Kloc]{X} - {Floc}, where Kloc and Floc are the copies of assembled global
>>>>> K matrix and F vector, and X is the current iterated solution. This is the
>>>>> reason that I need to access the global stiffness matrix and force vector
>>>>> in formfunction.
>>>>> I agree that formjacobian only needs access to global stiffness matrix
>>>>> K to form the jacobian and does not need to access the force vector.
>>>>> Therefore, to be able to pass both K and F to formfunction, I defined a
>>>>> struct that contains a vector F and matrix K and populated them in the
>>>>> main().
>>>>> Please let me know, if this unclear and I can clarify with more details
>>>> This still does not make sense. If you have a nonlinear problem, how can
>>>> you know the Jacobian up front? It changes with the input point.
>>>> Thanks,
>>>> Matt
>>>>> Thanks
>>>>> Kaushik
>>>>> On Wed, May 19, 2021 at 11:25 AM Barry Smith <bsmith at petsc.dev> wrote:
>>>>>> *ierr = MatSeqAIJGetArray(ptr->K,&Kc);CHKERRQ(ierr); *
>>>>>> *ierr = MatGetLocalSize(ptr->K,&m,&n); CHKERRQ(ierr);*
>>>>>> *for(i=0;i<m;i++) { for(j=0;j<n;j++) { v = *(Kc
>>>>>> + (i*n+j)); ierr =
>>>>>> MatSetValues(Kloc,1,&i,1,&j,&v,INSERT_VALUES);CHKERRQ(ierr); }*
>>>>>> I don't understand the purpose of this code fragment. Are you wanting
>>>>>> to copy your K into Kloc? What is the purpose of Kloc? With standard usage
>>>>>> of SNES one only needs to provide PETSc a global matrix, one does not need
>>>>>> to work with "ghosted" matrices at all.
>>>>>> Also normally one fills the f vector in FormFunction and the Jacobian
>>>>>> in FormJacobian and there is no need to access the Jacobians at all in SNES
>>>>>> https://www.mcs.anl.gov/petsc/documentation/faq.html#functionjacobian
>>>>>> nor do you need to pass into FormFunction in the context the F or Jacobian
>>>>>> matrix.
>>>>>> Maybe if you explained your use case a bit more we could make
>>>>>> suggestions on how to accomplish it.
>>>>>> Barry
>>>>>> On May 19, 2021, at 10:00 AM, Kaushik Vijaykumar <
>>>>>> Hi everyone,
>>>>>> We are in the process of integrating nonlinear solution to our FE code
>>>>>> through SNES. The first steps that I understood that need to be done is to
>>>>>> be able to pass the assembled stiffness matrix K and force vector F to the "
>>>>>> *formfunction*" to calculate the residual and "*formjacobian*" to
>>>>>> calculate the tangent stiffness matrix. To do so, I have defined a struct:
>>>>>> *extern PetscErrorCode FormJacobian(SNES,Vec,Mat,Mat,void*);extern
>>>>>> PetscErrorCode FormFunction(SNES,Vec,Vec,void*);*
>>>>>> // define a struct type to pass K and f as "user context"
>>>>>> *typedef struct { Mat K; Vec f; } K_and_f;*
>>>>>> In the main program, the struct is declared
>>>>>> *int main()*
>>>>>> *K_and_f main_K_and_f;* // declare the struct
>>>>>> // SNES - Populate K and f into the struct
>>>>>> *main_K_and_f.K = K;* // K matrix
>>>>>> *main_K_and_f.f = f; *// f vector
>>>>>> In form function
>>>>>> *PetscErrorCode FormFunction(SNES snes, Vec x, Vec F, void* ctx) {
>>>>>> PetscErrorCode ierr; PetscReal *ax,*c; PetscReal *aF; PetscScalar
>>>>>> *Kc,v; PetscInt nlocal,m,n,i,j,index[100000]; * // Create local
>>>>>> Vec and Mat
>>>>>> * Mat Kloc;*
>>>>>> * Vec Floc, Uloc, KUloc, resloc;*
>>>>>> * K_and_f* ptr = (K_and_f*) ctx; *// cast the pointer to void into
>>>>>> pointer to struct
>>>>>> // Get local F array, FLOC
>>>>>> * ierr = VecGhostGetLocalForm(ptr->f,&Floc);CHKERRQ(ierr);*
>>>>>> I am able to get the f array from the main program using "
>>>>>> VecGhostGetLocalForm" and the vec is correct. However, I am having trouble
>>>>>> with reading the K matrix in formfunction.
>>>>>> The following trial gives me incorrect K values in Kloc:
>>>>>> + (i*n+j)); ierr =
>>>>>> When I compare K and Kloc, they are not identical
>>>>>> Please let me know if there is an equivalent function like
>>>>>> *VecGhostGetLocalForm()* for Matrices. If not, is there a better way
>>>>>> to do this.
>>>>>> Any guidance/help is greatly appreciated.
>>>>>> Thanks
>>>>>> Kaushik
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
