[petsc-users] Using SNES to solve Non linear elasticity, passing matrix to form function
Matthew Knepley
knepley at gmail.com
Wed May 19 10:50:49 CDT 2021
On Wed, May 19, 2021 at 11:48 AM Kaushik Vijaykumar <kaushikv318 at gmail.com>
wrote:
> Barry,
> Thanks for your response. I am trying to copy K into Kloc, the purpose of
> doing that is to calculate the residual in formfunction - Residual =
> [Kloc]{X} - {Floc}, where Kloc and Floc are the copies of assembled global
> K matrix and F vector, and X is the current iterated solution. This is the
> reason that I need to access the global stiffness matrix and force vector
> in formfunction.
> I agree that formjacobian only needs access to global stiffness matrix K
> to form the jacobian and does not need to access the force vector.
> Therefore, to be able to pass both K and F to formfunction, I defined a
> struct that contains a vector F and matrix K and populated them in the
> main().
> Please let me know, if this unclear and I can clarify with more details
This still does not make sense. If you have a nonlinear problem, how can
you know the Jacobian up front? It changes with the input point.
Matt
> Thanks
> Kaushik
> On Wed, May 19, 2021 at 11:25 AM Barry Smith <bsmith at petsc.dev> wrote:
>> *ierr = MatSeqAIJGetArray(ptr->K,&Kc);CHKERRQ(ierr); *
>> *ierr = MatGetLocalSize(ptr->K,&m,&n); CHKERRQ(ierr);*
>> *for(i=0;i<m;i++) { for(j=0;j<n;j++) { v = *(Kc +
>> (i*n+j)); ierr =
>> MatSetValues(Kloc,1,&i,1,&j,&v,INSERT_VALUES);CHKERRQ(ierr); }*
>> I don't understand the purpose of this code fragment. Are you wanting to
>> copy your K into Kloc? What is the purpose of Kloc? With standard usage of
>> SNES one only needs to provide PETSc a global matrix, one does not need to
>> work with "ghosted" matrices at all.
>> Also normally one fills the f vector in FormFunction and the Jacobian in
>> FormJacobian and there is no need to access the Jacobians at all in SNES
>> https://www.mcs.anl.gov/petsc/documentation/faq.html#functionjacobian
>> nor do you need to pass into FormFunction in the context the F or Jacobian
>> matrix.
>> Maybe if you explained your use case a bit more we could make suggestions
>> on how to accomplish it.
>> Barry
>> On May 19, 2021, at 10:00 AM, Kaushik Vijaykumar <kaushikv318 at gmail.com>
>> wrote:
>> Hi everyone,
>> We are in the process of integrating nonlinear solution to our FE code
>> through SNES. The first steps that I understood that need to be done is to
>> be able to pass the assembled stiffness matrix K and force vector F to the "
>> *formfunction*" to calculate the residual and "*formjacobian*" to
>> calculate the tangent stiffness matrix. To do so, I have defined a struct:
>> *extern PetscErrorCode FormJacobian(SNES,Vec,Mat,Mat,void*);extern
>> PetscErrorCode FormFunction(SNES,Vec,Vec,void*);*
>> // define a struct type to pass K and f as "user context"
>> *typedef struct { Mat K; Vec f; } K_and_f;*
>> In the main program, the struct is declared
>> *int main()*
>> *K_and_f main_K_and_f;* // declare the struct
>> // SNES - Populate K and f into the struct
>> *main_K_and_f.K = K;* // K matrix
>> *main_K_and_f.f = f; *// f vector
>> In form function
>> *PetscErrorCode FormFunction(SNES snes, Vec x, Vec F, void* ctx) {
>> PetscErrorCode ierr; PetscReal *ax,*c; PetscReal *aF; PetscScalar
>> *Kc,v; PetscInt nlocal,m,n,i,j,index[100000]; * // Create local
>> Vec and Mat
>> * Mat Kloc;*
>> * Vec Floc, Uloc, KUloc, resloc;*
>> * K_and_f* ptr = (K_and_f*) ctx; *// cast the pointer to void into
>> pointer to struct
>> // Get local F array, FLOC
>> * ierr = VecGhostGetLocalForm(ptr->f,&Floc);CHKERRQ(ierr);*
>> I am able to get the f array from the main program using "
>> VecGhostGetLocalForm" and the vec is correct. However, I am having trouble
>> with reading the K matrix in formfunction.
>> The following trial gives me incorrect K values in Kloc:
>> (i*n+j)); ierr =
>> When I compare K and Kloc, they are not identical
>> Please let me know if there is an equivalent function like
>> *VecGhostGetLocalForm()* for Matrices. If not, is there a better way to
>> do this.
>> Any guidance/help is greatly appreciated.
>> Thanks
>> Kaushik
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210519/766b2a3f/attachment.html>
