[petsc-users] configure error
Mark Adams mfadams at lbl.gov
Sun May 16 10:26:10 CDT 2021
On Sun, May 16, 2021 at 9:58 AM Barry Smith <bsmith at petsc.dev> wrote:
>   Mark,
>     The kokkos-kernels did not get rebuilt so they will likely have a
> different geodearch.
>     I think you need to rm -rf arch-cori-gpu-opt-kokkos-gcc
Yes, of course, but did not help. I still get this error.
>     but
> was --with-mpi-dir=/usr/common/software/sles15_cgpu/openmpi/4.0.3/gcc built
> with CUDA aware MPI and a different gencodarch than is supported by the
> hardware?
I don't know. I use MPI very very little (and not timed) so I don't care
about it. This is just what I got to compile and work.
> If so, I guess you need to build PETSc using -with-cuda-gencodearch=70 if
> that is what the MPI was built with.
OK, that worked, thanks,
>   Barry
> On May 16, 2021, at 6:13 AM, Mark Adams <mfadams at lbl.gov> wrote:
> progress:
> 04:08 cgpu11 adams/cusparse-cpu-solve *= ~/petsc$ make
> PETSC_DIR=/global/homes/m/madams/petsc
> PETSC_ARCH=arch-cori-gpu-opt-kokkos-gcc check
> Running check examples to verify correct installation
> Using PETSC_DIR=/global/homes/m/madams/petsc and
> C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI process
> Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes
> See http://www.mcs.anl.gov/petsc/documentation/faq.html
> srun: error: Unable to create step for job 1921749: More processors
> requested than permitted
> 2,15c2,32
> <   0 SNES Function norm 2.391552133017e-01
> <     0 KSP Residual norm 2.325621076120e-01
> <     1 KSP Residual norm 1.654206318674e-02
> <     2 KSP Residual norm 7.202836119880e-04
> <     3 KSP Residual norm 1.796861424199e-05
> <     4 KSP Residual norm 2.461332992052e-07
> <   1 SNES Function norm 6.826585648929e-05
> <     0 KSP Residual norm 2.347339172985e-05
> <     1 KSP Residual norm 8.356798075993e-07
> <     2 KSP Residual norm 1.844045309619e-08
> <     3 KSP Residual norm 5.336386977405e-10
> <     4 KSP Residual norm 2.662608472862e-11
> <   2 SNES Function norm 6.549682264799e-11
> < Number of SNES iterations = 2
> > Kokkos::Cuda::initialize ERROR: likely mismatch of architecture
> > [cgpu11:39927] *** Process received signal ***
> > [cgpu11:39927] Signal: Aborted (6)
> > [cgpu11:39927] Signal code:  (-6)
> > [cgpu11:39927] [ 0] /lib64/libpthread.so.0(+0x12360)[0x2aab12731360]
> > [cgpu11:39927] [ 1] /lib64/libc.so.6(gsignal+0x110)[0x2aab12973160]
> > [cgpu11:39927] [ 2] /lib64/libc.so.6(abort+0x151)[0x2aab12974741]
> > [cgpu11:39927] [ 3]
> /global/homes/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/lib/libkokkoscore.so.3.4(+0x408e5)[0x2aaabbfb88e5]
> > [cgpu11:39927] [ 4]
> /global/homes/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/lib/libkokkoscore.so.3.4(_ZN6Kokkos4Impl12CudaInternal10initializeEiP11CUstream_st+0xb5c)[0x2aaabbfc762c]
> > [cgpu11:39927] [ 5]
> /global/homes/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/lib/libkokkoscore.so.3.4(_ZN6Kokkos4Impl16ExecSpaceManager17initialize_spacesERKNS_13InitArgumentsE+0x24)[0x2aaabbfa1224]
> > [cgpu11:39927] [ 6]
> /global/homes/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/lib/libkokkoscore.so.3.4(_ZN6Kokkos4Impl70_GLOBAL__N__46_tmpxft_00011209_00000000_7_Kokkos_Core_cpp1_ii_889c95a619initialize_internalERKNS_13InitArgumentsE+0x11)[0x2aaabbfa49d1]
> > [cgpu11:39927] [ 7]
> /global/homes/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/lib/libpetsc.so.3.015(PetscKokkosInitializeCheck+0x1f9)[0x2aaaaafad809]
> > [cgpu11:39927] [ 8]
> /global/homes/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/lib/libpetsc.so.3.015(+0x68541b)[0x2aaaab35841b]
> > [cgpu11:39927] [ 9]
> /global/homes/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/lib/libpetsc.so.3.015(+0x36a224)[0x2aaaab03d224]
> > [cgpu11:39927] [10]
> /global/homes/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/lib/libpetsc.so.3.015(+0x35f596)[0x2aaaab032596]
> > [cgpu11:39927] [11]
> /global/homes/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/lib/libpetsc.so.3.015(+0x2f9d94)[0x2aaaaafccd94]
> > [cgpu11:39927] [12]
> /global/homes/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/lib/libpetsc.so.3.015(PetscSFBcastWithMemTypeBegin+0x11f)[0x2aaaab04bc3f]
> > [cgpu11:39927] [13]
> /global/homes/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/lib/libpetsc.so.3.015(+0x37f53a)[0x2aaaab05253a]
> > [cgpu11:39927] [14]
> /global/homes/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/lib/libpetsc.so.3.015(VecScatterBegin+0x70)[0x2aaaab057b30]
> > [cgpu11:39927] [15]
> /global/homes/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/lib/libpetsc.so.3.015(DMGlobalToLocalBegin_DA+0x1f)[0x2aaaabc27a5f]
> > [cgpu11:39927] [16]
> /global/homes/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/lib/libpetsc.so.3.015(DMGlobalToLocalBegin+0x1dd)[0x2aaaabe61b3d]
> > [cgpu11:39927] [17]
> /global/homes/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/lib/libpetsc.so.3.015(+0x144567a)[0x2aaaac11867a]
> > [cgpu11:39927] [18]
> /global/homes/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/lib/libpetsc.so.3.015(SNESComputeFunction+0xf5)[0x2aaaac138ef5]
> > [cgpu11:39927] [19]
> /global/homes/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/lib/libpetsc.so.3.015(+0x14ad0de)[0x2aaaac1800de]
> > [cgpu11:39927] [20]
> /global/homes/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/lib/libpetsc.so.3.015(SNESSolve+0x821)[0x2aaaac146ed1]
> > [cgpu11:39927] [21]
> /global/u2/m/madams/petsc/src/snes/tutorials/./ex19[0x401a69]
> > [cgpu11:39927] [22]
> /lib64/libc.so.6(__libc_start_main+0xea)[0x2aab1295df8a]
> > [cgpu11:39927] [23]
> /global/u2/m/madams/petsc/src/snes/tutorials/./ex19[0x4021ba]
> > [cgpu11:39927] *** End of error message ***
> > srun: error: cgpu11: task 0: Aborted
> > srun: Terminating job step 1921749.6
> /global/homes/m/madams/petsc/src/snes/tutorials
> Possible problem with ex19 running with cuda, diffs above
> gmake[3]: [makefile:102: runex3k_kokkos] Error 1 (ignored)
> On Sun, May 16, 2021 at 12:31 AM Barry Smith <bsmith at petsc.dev> wrote:
>>   Looks like nvcc_wrapper gets confused when both -arch and -gencode are
>> used. But handles either of them separately correctly.
>>   Mark,
>>     PETSc configure now handles  the -arch and --with-kokkos-cuda-arch=
>>  business automatically so you do not, and generally shouldn't pass -arch
>> sm_70 in  --CUDAFLAGS anymore or use the --with-kokkos-cuda-arch option
>> anymore.
>>     If you need to set the -arch to something earlier than the system
>> supports (rare) you can now use -with-cuda-gencodearch to set that instead
>> of using CUDAFLAGS.
>>   Barry
>> $ NVCC_WRAPPER_DEFAULT_COMPILER=mpicxx
>> /home/bsmith/petsc/arch-main/bin/nvcc_wrapper --show --expt-extended-lambda
>> -c -Xcompiler -fPIC -g  -gencode arch=compute_70,code=sm_70
>> -I/home/bsmith/soft/gnu-mpich/include -Wno-deprecated-gpu-targets
>> -I/home/bsmith/petsc/include -I/home/bsmith/petsc/arch-main/include
>> -I/nfs/apps/spacks/2021-02-09/opt/spack/linux-centos7-x86_64/gcc-7.3.0/cuda-11.2.0-ikruu5mo6dtt3avvmwsejouqhxu4btdm/include
>>     /home/bsmith/petsc/src/ts/utils/dmplexlandau/kokkos/landau.kokkos.cxx
>> -o arch-main/obj/ts/utils/dmplexlandau/kokkos/landau.o
>> nvcc --expt-extended-lambda -gencode arch=compute_70,code=sm_70
>> -Wno-deprecated-gpu-targets -ccbin mpicxx -g
>> -I/home/bsmith/soft/gnu-mpich/include -I/home/bsmith/petsc/include
>> -Xcompiler -fPIC -x cu
>> /home/bsmith/petsc/src/ts/utils/dmplexlandau/kokkos/landau.kokkos.cxx -c -o
>> ~/petsc* (main=)* arch-main
>> -c -arch=sm_70 -Xcompiler -rdynamic -DLANDAU_DIM=2 -DLANDAU_MAX_SPECIES=10
>> -DPETSC_HAVE_CUDA_ATOMIC -DLANDAU_MAX_Q=4 -Xcompiler -fPIC -O3  -gencode
>> arch=compute_80,code=sm_80
>> -I/usr/common/software/sles15_cgpu/openmpi/4.0.3/gcc/include
>> nvcc --expt-extended-lambda -arch=sm_70 -Wno-deprecated-gpu-targets
>> -ccbin mpicxx -DLANDAU_DIM=2 -DLANDAU_MAX_SPECIES=10
>> -DPETSC_HAVE_CUDA_ATOMIC -DLANDAU_MAX_Q=4 -O3
>> -I/usr/common/software/sles15_cgpu/openmpi/4.0.3/gcc/include -Xcompiler
>> -rdynamic,-fPIC,arch=compute_80,code=sm_80 -c
>> -c -Xcompiler -fPIC -g -arch=sm_70 -gencode arch=compute_70,code=sm_70
>> -ccbin mpicxx -g -I/home/bsmith/soft/gnu-mpich/include
>> -Xcompiler -fPIC,arch=compute_70,code=sm_70 -x cu
>> On May 15, 2021, at 8:44 PM, Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>> Add --show to the failing nvcc_wrapper command and see how nvcc_wrapper
>> parses the options
>> PATH=/global/common/sw/cray/sles15/x86_64/zlib/1.2.11/gcc/8.2.0/pep2pal/bin:/global/common/sw/cray/cnl7/haswell/cmake/3.18.2/bin:/opt/cray/rca/2.2.20-7.0.1.1_4.62__g8e3fb5b.ari/bin:/opt/cray/alps/6.6.58-7.0.1.1_6.20__g437d88db.ari/sbin:/opt/cray/alps/default/bin:/opt/cray/job/2.2.4-7.0.1.1_3.48__g36b56f4.ari/bin:/opt/cray/pe/craype/2.6.2/bin:/usr/common/software/sles15_cgpu/openmpi/4.0.3/gcc/bin:/usr/common/software/sles15_cgpu/hpcsdk/20.11/Linux_x86_64/20.11/compilers/bin:/usr/common/software/sles15_cgpu/hpcsdk/20.11/Linux_x86_64/20.11/cuda/bin:/usr/common/software/sles15_cgpu/cuda/11.1.1/bin:/usr/common/software/sles15_cgpu/gcc/8.3.0/bin:/opt/esslurm/bin:/opt/cray/pe/modules/
>> 3.2.11.4/bin:/usr/common/software/bin:/usr/common/nsg/bin:/opt/ovis/bin:/opt/ovis/sbin:/usr/local/bin:/usr/bin:/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin:/opt/cray/pe/bin:`dirname
>> <http://3.2.11.4/bin:/usr/common/software/bin:/usr/common/nsg/bin:/opt/ovis/bin:/opt/ovis/sbin:/usr/local/bin:/usr/bin:/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin:/opt/cray/pe/bin:dirname> /usr/common/software/sles15_cgpu/cuda/11.1.1/bin/nvcc`
>> NVCC_WRAPPER_DEFAULT_COMPILER=/usr/common/software/sles15_cgpu/openmpi/4.0.3/gcc/bin/mpicxx
>> /global/homes/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/bin/nvcc_wrapper
>> --expt-extended-lambda -c -arch=sm_70 -Xcompiler -rdynamic -DLANDAU_DIM=2
>> -DLANDAU_MAX_SPECIES=10 -DPETSC_HAVE_CUDA_ATOMIC -DLANDAU_MAX_Q=4
>> -Xcompiler -fPIC -O3  -gencode arch=compute_80,code=sm_80
>> -Wno-deprecated-gpu-targets   -I/global/homes/m/madams/petsc/include
>> -I/global/homes/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/include
>> -I/usr/common/software/sles15_cgpu/cuda/11.1.1/include
>>  /global/u2/m/madams/petsc/src/sys/objects/kokkos/kinit.kokkos.cxx -o
>> arch-cori-gpu-opt-kokkos-gcc/obj/sys/objects/kokkos/kinit.o --show
>> --Junchao Zhang
>> On Sat, May 15, 2021 at 7:14 PM Mark Adams <mfadams at lbl.gov> wrote:
>>> Thanks,
>>> Now I get an error in make all. THis was working a few weeks ago.
>>> Make.log was empty but here is the output.
>>>        CC arch-cori-gpu-opt-kokkos-gcc/obj/sys/error/ftn-custom/zerrf.o
>>>           CC arch-cori-gpu-opt-kokkos-gcc/obj/sys/f90-src/f90_cwrap.o
>>>           CC arch-cori-gpu-opt-kokkos-gcc/obj/vec/is/utils/hdf5io.o
>>> g++: error: arch=compute_80: No such file or directory
>>> g++: error: code=sm_80: No such file or directory
>>> gmake[3]: *** [gmakefile:188:
>>> arch-cori-gpu-opt-kokkos-gcc/obj/sys/objects/kokkos/kinit.o] Error 1
>>> gmake[3]: *** Waiting for unfinished jobs....
>>>           CC arch-cori-gpu-opt-kokkos-gcc/obj/vec/is/utils/isio.o
>>>           CC
>>> arch-cori-gpu-opt-kokkos-gcc/obj/vec/is/utils/ftn-auto/pmapf.o
>>>           CC arch-cori-gpu-opt-kokkos-gcc/obj/vec/is/utils/pmap.o
>>>           CC arch-cori-gpu-opt-kokkos-gcc/obj/vec/is/utils/psort.o
>>>           CC arch-cori-gpu-opt-kokkos-gcc/obj/vec/is/utils/isltog.o
>>>           FC arch-cori-gpu-opt-kokkos-gcc/obj/vec/f90-mod/petscvecmod.o
>>>        CUDAC arch-cori-gpu-opt-kokkos-gcc/obj/sys/memory/cuda/mcudahost.o
>>>    CUDAC.dep arch-cori-gpu-opt-kokkos-gcc/obj/sys/memory/cuda/mcudahost.o
>>> gmake[2]: *** [/global/homes/m/madams/petsc/lib/petsc/conf/rules:50:
>>> libs] Error 2
>>> **************************ERROR*************************************
>>>   Error during compile, check
>>> arch-cori-gpu-opt-kokkos-gcc/lib/petsc/conf/make.log
>>>   Send it and arch-cori-gpu-opt-kokkos-gcc/lib/petsc/conf/configure.log
>>> to petsc-maint at mcs.anl.gov
>>> gmake[1]: *** [makefile:40: all] Error 1
>>> make: *** [GNUmakefile:9: all] Error 2
>>> On Sat, May 15, 2021 at 5:30 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>   Bitbucket is off-line. Do you need fortran stubs at this moment? If
>>>> not use  --with-fortran-interface=0
>>>> On May 15, 2021, at 2:51 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>> I can build a non-kokkos PETSc here (Cori/GPU) but I get this
>>>> error with Kokkos.
>>>> Any suggestions?
>>>> Thanks,
>>>> Mark
>>>>        Trying to
>>>> download git://https://bitbucket.org/petsc/pkg-sowing.git for SOWING
>>>>        Trying to
>>>>        Trying to
>>>> download https://bitbucket.org/petsc/pkg-sowing/get/v1.1.26-p1.tar.gz
>>>> for SOWING
>>>>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
>>>> for details):
>>>> Error during download/extract/detection of SOWING:
>>>> Unable to clone sowing
>>>> Could not execute "['git clone
>>>> /global/u2/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/externalpackages/git.sowing']":
>>>> Cloning into
>>>> '/global/u2/m/madams/petsc/arch-cori-gpu-opt-kokkos-gcc/externalpackages/git.sowing'...
>>>> fatal: unable to access 'https://bitbucket.org/petsc/pkg-sowing.git/':
>>>> The requested URL returned error: 503
>>>> Unable to download package SOWING from: git://
>>>> * If URL specified manually - perhaps there is a typo?
>>>> * If your network is disconnected - please reconnect and rerun
>>>> ./configure
>>>> * Or perhaps you have a firewall blocking the download
>>>> * You can run with --with-packages-download-dir=/adirectory and
>>>> ./configure will instruct you what packages to download manually
>>>> * or you can download the above URL manually, to /yourselectedlocation
>>>>   and use the configure option:
>>>>   --download-sowing=/yourselectedlocation
>>>> Cloning into
>>>> ./configure
>>>>     file could not be opened successfully
>>>> Downloaded package SOWING from:
>>>> https://bitbucket.org/petsc/pkg-sowing/get/v1.1.26-p1.tar.gz is not a
>>>> tarball.
>>>> [or installed python cannot process compressed files]
>>>> * If you are behind a firewall - please fix your proxy and rerun
>>>> ./configure
>>>>   For example at LANL you may need to set the environmental variable
>>>> http_proxy (or HTTP_PROXY?) to  http://proxyout.lanl.gov
>>>> /yourselectedlocation/v1.1.26-p1.tar.gz
>>>>   --download-sowing=/yourselectedlocation/v1.1.26-p1.tar.gz
>>>> <configure.log>
>> <make.log><configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210516/0d6a141c/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210516/0d6a141c/attachment-0001.obj>
