[petsc-users] reuse a real matrix for a second linear system with complex numbers
Matthew Knepley
knepley at gmail.com
Fri May 14 15:26:55 CDT 2021
On Fri, May 14, 2021 at 1:36 PM feng wang <snailsoar at hotmail.com> wrote:
> Yes, you are right. I can do row permutations to make them continuous. I
> will try this.
> could I re-use my KSP object from the 1st linear system in my 2nd system
> by simply changing the operators and setting new parameters? or I need a
> separate KSP object for the 2nd system?
I tink you want 2 KSP objects. You could reuse the settings of the first,
but since the system is a different size, all storage would have to be
deleted and recreated anyway.
Matt
> Thanks,
> Feng
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* 14 May 2021 15:20
> *To:* feng wang <snailsoar at hotmail.com>
> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *Subject:* Re: [petsc-users] reuse a real matrix for a second linear
> On Fri, May 14, 2021 at 10:36 AM feng wang <snailsoar at hotmail.com> wrote:
> Thanks for your comments. It is very helpful!
> I might try the 1st approach first. For the 2nd approach which uses an
> equivalent real-number system, I see potential issues when running in
> parallel. I have re-ordered my cells to allow each rank hold continuous
> rows in the first real system Ax=B. For the equivalent real-number system,
> each rank now holds (or can assign values to) two patches of continuous
> rows, which are separated by N rows, N is the size of square matrix A. I
> can't see a straightforward way to allow each rank hold continuous rows in
> this case. or petsc can handle these two patches of continuous rows with
> fixed row index difference in this case?
> I just wrote it that way for ease of typing. You can imagine permuting
> into 2x2 blocks with
> /a w\
> \-w a/
> for each entry.
> Thanks,
> Matt
> By the way, could I still re-use my KSP object in my second system by
> Thanks,
> Feng
> *Sent:* 14 May 2021 10:00
> On Fri, May 14, 2021 at 4:23 AM feng wang <snailsoar at hotmail.com> wrote:
> Dear All,
> I am solving a coupled system. One system is AX=B. A, X and B are all real
> numbers and it is solved with GMRES in petsc. Now I need to solve a second
> linear system, it can be represented as (A+i*w)*Z=C. i is the imaginary
> unit. Z and C are also complex numbers.
> So the Jacobian matrix of the second system is just A plus a diagonal
> contribution i*w. I would like solve the second system with GMRES, could
> petsc handle this? any comments are welcome.
> Mixing real and complex numbers in the same code is somewhat difficult
> now. You have two obvious choices:
> 1) Configure for complex numbers and solve your first system as complex
> but with 0 imaginary part. This will work fine, but uses more memory for
> that system. However, since you will already
> use that much memory for the second system, it does not seem like a
> big deal to me.
> 2) You could solve the second system in its equivalent real form
> / A w \ /Zr\ = /Cr\
> \ -w A / \Zi/ \Ci/
> This uses more memory for the second system, but does not require
> reconfiguring.
> THanks,
> Matt
> Thanks,
> Feng
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210514/acbb4c11/attachment-0001.html>
