[petsc-users] Binary format in real vs. complex scalar type configurations
Pierre Jolivet pierre at joliv.et
Wed May 12 01:17:21 CDT 2021
> On 11 May 2021, at 6:26 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, May 11, 2021 at 12:03 PM Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>> wrote:
> Hello Frederico,
> I’m not sure that’s possible.
> Here is what I do, it makes me sick, but mixing precisions/scalar types with PETSc is difficult (crossing my fingers this will be better with future).
> In MATLAB (after putting petsc/share/petsc/matlab in the path):
> A = PetscBinaryRead('your_binary_mat_with_re+im.dat','complex',true); % scalar-type=complex
> PetscBinaryWrite('re.dat',real(A)); % scalar-type=real
> PetscBinaryWrite('im.dat',imag(A)); % scalar-type=real
> So what you want to happen is that MatLoad() looks at the datatype, sees that it is complex and PetscScalar is real, and returns two matrices with the real and imaginary parts?
> The hard part is that the MatLoad interface returns a single matrix.
There is Mat[Real,Imaginary]Part(), maybe there could be Mat[Real,Imaginary]PartLoad()?
It will be inefficient (complex Mat read twice in a very naive implementation), but functional and would not require tinkering with the options (but maybe you had something clear in mind).
Also, just for reference, https://gitlab.com/petsc/petsc/-/issues/901 <https://gitlab.com/petsc/petsc/-/issues/901>.
Frederico, as Barry wrote, it will work with Octave or Python. In fact, it will work in any code that does not include petsc.h or link to libpetsc.
If you want to stick to C, I think you could simply copy/paste the MatLoad_SeqAIJ_Binary() implementation https://www.mcs.anl.gov/petsc/petsc-3.15.0/src/mat/impls/aij/seq/aij.c.html#line4811 <https://www.mcs.anl.gov/petsc/petsc-current/src/mat/impls/aij/seq/aij.c.html#line4811> and replace PETSC_SCALAR line 4861 by PETSC_COMPLEX.
Then, as Matt wrote, instead of assembling a single Mat, assemble two Mats by splitting a->a in two PetscScalar arrays (remember that this is for your scalar-type=real configuration).
Pierre
> I guess we could have a flag that says what to do with complex numbers (read real, read imaginary, read norm, etc.)
> and you could read it twice. Would that work?
>   Thanks,
>      Matt
> Thanks,
> Pierre
>> On 11 May 2021, at 3:30 PM, Frederico Teixeira <teixeira at zmt.swiss <mailto:teixeira at zmt.swiss>> wrote:
>> Dear fellows,
>> I hope this message finds you safe and well.
>> I have a complex-valued matrix and its real/imaginary components in binary format. They were extracted from a solver that only works with "scalar-type=complex" configuration.
>> I am getting weird results when I load them into a small test program that's configured with "scalar-type=real", but I believe this is expected.
>> At the end of the day, I would like to have both real and imaginary components as real-valued matrices.
>> Is it possible to do it? I want to test preconditioners that are tailored for this sort of problem.
>> Regards,
>>  Frederico.
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210512/8ba31bed/attachment-0001.html>
