[petsc-users] Parallel TS for ODE
Matthew Knepley
knepley at gmail.com
Wed Mar 31 09:18:53 CDT 2021
On Wed, Mar 31, 2021 at 10:15 AM Francesco Brarda <brardafrancesco at gmail.com>
wrote:
> Thank you for your advices.
> I wrote what seems to me a very basic code, but I got this error when I
> run it with more than 1 processor:
> Clearly the result 299. is wrong but I do not understand what am doing
> wrong. With 1 processor it works fine.
My guess is that you do VecGetArray() and index the array using global
indices rather than local indices, because
there memory corruption with a Vec array.
Matt
> steps 150, ftime 15.
> Vec Object: 2 MPI processes
> type: mpi
> Process [0]
> 16.5613
> 2.91405
> Process [1]
> 299.
> [0]PETSC ERROR: PetscTrFreeDefault() called from VecDestroy_MPI() line 21
> in /home/fbrarda/petsc/src/vec/vec/impls/mpi/pdvec.c
> [0]PETSC ERROR: Block [id=0(16)] at address 0x15812a0 is corrupted
> (probably write past end of array)
> [0]PETSC ERROR: Block allocated in VecCreate_MPI_Private() line 514
> in /home/fbrarda/petsc/src/vec/vec/impls/mpi/pbvec.c
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Memory corruption:
> https://www.mcs.anl.gov/petsc/documentation/installation.html#valgrind
> [0]PETSC ERROR: Corrupted memory
> [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.14.4, unknown
> [0]PETSC ERROR: ./par_sir_model on a arch-debug named srvulx13 by fbrarda
> Wed Mar 31 16:05:22 2021
> [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
> --with-fc=gfortran --with-openblas-dir=/opt/packages/openblas/0.2.13-gcc
> --download-mpich PETSC_ARCH=arch-debug
> [0]PETSC ERROR: #1 PetscTrFreeDefault() line 310
> in /home/fbrarda/petsc/src/sys/memory/mtr.c
> [0]PETSC ERROR: #2 VecDestroy_MPI() line 21
> [0]PETSC ERROR: #3 VecDestroy() line 396
> in /home/fbrarda/petsc/src/vec/vec/interface/vector.c
> [0]PETSC ERROR: #4 SNESLineSearchReset() line 284
> in /home/fbrarda/petsc/src/snes/linesearch/interface/linesearch.c
> [0]PETSC ERROR: #5 SNESReset() line 3229 in
> /home/fbrarda/petsc/src/snes/interface/snes.c
> [0]PETSC ERROR: #6 TSReset() line 2800 in
> /home/fbrarda/petsc/src/ts/interface/ts.c
> [0]PETSC ERROR: #7 TSDestroy() line 2856 in
> [0]PETSC ERROR: #8 main() line 256 in par_sir_model.c
> [0]PETSC ERROR: No PETSc Option Table entries
> [0]PETSC ERROR: ----------------End of Error Message -------send entire
> error message to petsc-maint at mcs.anl.gov----------
> application called MPI_Abort(MPI_COMM_SELF, 256001) - process 0
> [1]PETSC ERROR: PetscTrFreeDefault() called from VecDestroy_MPI() line 21
> [1]PETSC ERROR: Block [id=0(16)] at address 0xbd9520 is corrupted
> [1]PETSC ERROR: Block allocated in VecCreate_MPI_Private() line 514
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: Memory corruption:
> [1]PETSC ERROR: Corrupted memory
> [1]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> [1]PETSC ERROR: Petsc Release Version 3.14.4, unknown
> [1]PETSC ERROR: ./par_sir_model on a arch-debug named srvulx13 by fbrarda
> [1]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
> [1]PETSC ERROR: #1 PetscTrFreeDefault() line 310
> [1]PETSC ERROR: #2 VecDestroy_MPI() line 21
> [1]PETSC ERROR: #3 VecDestroy() line 396
> [1]PETSC ERROR: #4 TSReset() line 2806 in
> [1]PETSC ERROR: #5 TSDestroy() line 2856 in
> [1]PETSC ERROR: #6 main() line 256 in par_sir_model.c
> [1]PETSC ERROR: No PETSc Option Table entries
> [1]PETSC ERROR: ----------------End of Error Message -------send entire
> Il giorno 31 mar 2021, alle ore 12:06, Matthew Knepley <knepley at gmail.com>
> ha scritto:
> On Wed, Mar 31, 2021 at 3:54 AM Francesco Brarda <
> brardafrancesco at gmail.com> wrote:
> Hi everyone!
> I am trying to solve a system of 3 ODEs (a basic SIR model) with TS.
> Sequentially works pretty well, but I need to switch it into a
> parallel version.
> I started working with TS not very long time ago, there are few questions
> I’d like to share with you and if you have any advices I’d be happy to hear.
> First of all, do I need to use a DM object even if the model is only time
> dependent? All the examples I found were using that object for the other
> variable when solving PDEs.
> You do not need one. We use it in examples because it makes it easy to
> create the data.
> When I preallocate the space for the Jacobian matrix, is it better to
> decide the local or global space?
> Since you are producing all the Jacobian values, it is whatever is easier
> in your code I think.
> THanks,
> Matt
> Best,
> Francesco
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210331/c72f9d2e/attachment-0001.html>
