[petsc-users] Code speedup after upgrading
Jed Brown jed at jedbrown.org
Sun Mar 28 22:11:35 CDT 2021
It's an option that he would have set explicitly via MatSetOption, following Lawrence's suggestion. He can either not call that function or use PETSC_FALSE to unset it.
Junchao Zhang <junchao.zhang at gmail.com> writes:
> Is there an option to turn off MAT_SUBSET_OFF_PROC_ENTRIES for Mohammad to
> try?
> --Junchao Zhang
> On Sun, Mar 28, 2021 at 3:34 PM Jed Brown <jed at jedbrown.org> wrote:
>> I take it this was using MAT_SUBSET_OFF_PROC_ENTRIES. I implemented that
>> to help performance of PHASTA and other applications that assemble matrices
>> that are relatively cheap to solve (so assembly cost is significant
>> compared to preconditioner setup and KSPSolve) and I'm glad it helps so
>> much here.
>> I don't have an explanation for why you're observing local vector
>> operations like VecScale and VecMAXPY running over twice as fast in the new
>> code. These consist of simple code that has not changed, and which are
>> normally memory bandwidth limited (though some of your problem sizes might
>> fit in cache).
>> Mohammad Gohardoust <gohardoust at gmail.com> writes:
>> > Here is the plot of run time in old and new petsc using 1,2,4,8, and 16
>> > CPUs (in logarithmic scale):
>> > [image: Screenshot from 2021-03-28 10-48-56.png]
>> > On Thu, Mar 25, 2021 at 12:51 PM Mohammad Gohardoust <
>> > wrote:
>> >> That's right, these loops also take roughly half time as well. If I am
>> not
>> >> mistaken, petsc (MatSetValue) is called after doing some calculations
>> over
>> >> each tetrahedral element.
>> >> Thanks for your suggestion. I will try that and will post the results.
>> >> Mohammad
>> >> On Wed, Mar 24, 2021 at 3:23 PM Junchao Zhang <junchao.zhang at gmail.com>
>> >> wrote:
>> >>> On Wed, Mar 24, 2021 at 2:17 AM Mohammad Gohardoust <
>> >>> wrote:
>> >>>> So the code itself is a finite-element scheme and in stage 1 and 3
>> there
>> >>>> are expensive loops over entire mesh elements which consume a lot of
>> time.
>> >>> So these expensive loops must also take half time with newer petsc?
>> And
>> >>> these loops do not call petsc routines?
>> >>> I think you can build two PETSc versions with the same configuration
>> >>> options, then run your code with one MPI rank to see if there is a
>> >>> difference.
>> >>> If they give the same performance, then scale to 2, 4, ... ranks and
>> see
>> >>> what happens.
>> >>>> Mohammad
>> >>>> On Tue, Mar 23, 2021 at 6:08 PM Junchao Zhang <
>> >>>> wrote:
>> >>>>> In the new log, I saw
>> >>>>> Summary of Stages:   ----- Time ------  ----- Flop ------  ---
>> Messages ---  -- Message Lengths --  -- Reductions --
>> >>>>>                         Avg     %Total     Avg     %Total    Count
>>  %Total     Avg         %Total    Count   %Total
>> >>>>>  0:      Main Stage: 5.4095e+00   2.3%  4.3700e+03   0.0%
>> 4.764e+05   3.0%  3.135e+02        1.0%  2.244e+04  12.6% 1:
>> Solute_Assembly: 1.3977e+02  59.4%  7.3353e+09   4.6%  3.263e+06  20.7%
>> 1.278e+03       26.9%  1.059e+04   6.0%
>> >>>>> But I didn't see any event in this stage had a cost close to 140s.
>> What
>> >>>>> happened?
>> >>>>>  --- Event Stage 1: Solute_Assembly
>> >>>>> BuildTwoSided       3531 1.0 2.8025e+0026.3 0.00e+00 0.0 3.6e+05
>> 4.0e+00 3.5e+03  1  0  2  0  2   1  0 11  0 33     0
>> >>>>> BuildTwoSidedF      3531 1.0 2.8678e+0013.2 0.00e+00 0.0 7.1e+05
>> 3.6e+03 3.5e+03  1  0  5 17  2   1  0 22 62 33     0
>> >>>>> VecScatterBegin     7062 1.0 7.1911e-02 1.9 0.00e+00 0.0 7.1e+05
>> 3.5e+02 0.0e+00  0  0  5  2  0   0  0 22  6  0     0
>> >>>>> VecScatterEnd       7062 1.0 2.1248e-01 3.0 1.60e+06 2.7 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0    73
>> >>>>> SFBcastOpBegin      3531 1.0 2.6516e-02 2.4 0.00e+00 0.0 3.6e+05
>> 3.5e+02 0.0e+00  0  0  2  1  0   0  0 11  3  0     0
>> >>>>> SFBcastOpEnd        3531 1.0 9.5041e-02 4.7 0.00e+00 0.0 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> >>>>> SFReduceBegin       3531 1.0 3.8955e-02 2.1 0.00e+00 0.0 3.6e+05
>> >>>>> SFReduceEnd         3531 1.0 1.3791e-01 3.9 1.60e+06 2.7 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   112
>> >>>>> SFPack              7062 1.0 6.5591e-03 2.5 0.00e+00 0.0 0.0e+00
>> >>>>> SFUnpack            7062 1.0 7.4186e-03 2.1 1.60e+06 2.7 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  2080
>> >>>>> MatAssemblyBegin    3531 1.0 4.7846e+00 1.1 0.00e+00 0.0 7.1e+05
>> 3.6e+03 3.5e+03  2  0  5 17  2   3  0 22 62 33     0
>> >>>>> MatAssemblyEnd      3531 1.0 1.5468e+00 2.7 1.68e+07 2.7 0.0e+00
>> 0.0e+00 0.0e+00  0  0  0  0  0   1  2  0  0  0   104
>> >>>>> MatZeroEntries      3531 1.0 3.0998e-02 1.2 0.00e+00 0.0 0.0e+00
>> >>>>> --Junchao Zhang
>> >>>>> On Tue, Mar 23, 2021 at 5:24 PM Mohammad Gohardoust <
>> >>>>> gohardoust at gmail.com> wrote:
>> >>>>>> Thanks Dave for your reply.
>> >>>>>> For sure PETSc is awesome :D
>> >>>>>> Yes, in both cases petsc was configured with --with-debugging=0 and
>> >>>>>> fortunately I do have the old and new -log-veiw outputs which I
>> attached.
>> >>>>>> Best,
>> >>>>>> Mohammad
>> >>>>>> On Tue, Mar 23, 2021 at 1:37 AM Dave May <dave.mayhem23 at gmail.com>
>> >>>>>> wrote:
>> >>>>>>> Nice to hear!
>> >>>>>>> The answer is simple, PETSc is awesome :)
>> >>>>>>> Jokes aside, assuming both petsc builds were configured with
>> >>>>>>> —with-debugging=0, I don’t think there is a definitive answer to
>> your
>> >>>>>>> question with the information you provided.
>> >>>>>>> It could be as simple as one specific implementation you use was
>> >>>>>>> improved between petsc releases. Not being an Ubuntu expert, the
>> change
>> >>>>>>> might be associated with using a different compiler, and or a more
>> >>>>>>> efficient BLAS implementation (non threaded vs threaded). However
>> I doubt
>> >>>>>>> this is the origin of your 2x performance increase.
>> >>>>>>> If you really want to understand where the performance improvement
>> >>>>>>> originated from, you’d need to send to the email list the result of
>> >>>>>>> -log_view from both the old and new versions, running the exact
>> same
>> >>>>>>> problem.
>> >>>>>>> From that info, we can see what implementations in PETSc are being
>> >>>>>>> used and where the time reduction is occurring. Knowing that, it
>> should be
>> >>>>>>> clearer to provide an explanation for it.
>> >>>>>>> Thanks,
>> >>>>>>> Dave
>> >>>>>>> On Tue 23. Mar 2021 at 06:24, Mohammad Gohardoust <
>> >>>>>>>> Hi,
>> >>>>>>>> I am using a code which is based on petsc (and also parmetis).
>> >>>>>>>> Recently I made the following changes and now the code is running
>> about two
>> >>>>>>>> times faster than before:
>> >>>>>>>>    - Upgraded Ubuntu 18.04 to 20.04
>> >>>>>>>>    - Upgraded petsc 3.13.4 to 3.14.5
>> >>>>>>>>    - This time I installed parmetis and metis directly via petsc
>> by
>> >>>>>>>>    --download-parmetis --download-metis flags instead of
>> installing them
>> >>>>>>>>    separately and using --with-parmetis-include=... and
>> >>>>>>>>    --with-parmetis-lib=... (the version of installed parmetis was
>> 4.0.3 before)
>> >>>>>>>> I was wondering what can possibly explain this speedup? Does
>> anyone
>> >>>>>>>> have any suggestions?
>> >>>>>>>> Thanks,
>> >>>>>>>> Mohammad
