[petsc-users] Re-ordering in DMPlexCreateFromCellListParallelPetsc
Nicolas Barral nicolas.barral at math.u-bordeaux.fr
Mon Mar 22 16:54:54 CDT 2021
Nicolas
On 22/03/2021 17:53, Matthew Knepley wrote:
> On Mon, Mar 22, 2021 at 12:20 PM Nicolas Barral
> <nicolas.barral at math.u-bordeaux.fr
> <mailto:nicolas.barral at math.u-bordeaux.fr>> wrote:
>     Thanks for your answers Matt.
>     On 22/03/2021 13:45, Matthew Knepley wrote:
>      > On Mon, Mar 22, 2021 at 6:22 AM Nicolas Barral
>     <mailto:nicolas.barral at math.u-bordeaux.fr>>> wrote:
>      >     On 21/03/2021 21:29, Matthew Knepley wrote:
>      >      > On Sat, Mar 20, 2021 at 10:07 AM Nicolas Barral
>      >      > <nicolas.barral at math.u-bordeaux.fr
>      >      > <mailto:nicolas.barral at math.u-bordeaux.fr
>     <mailto:nicolas.barral at math.u-bordeaux.fr>>>> wrote:
>      >      >     Hi all,
>      >      >     I'm building a plex from elements arrays using
>      >      >     DMPlexCreateFromCellListParallelPetsc. Once the plex
>     is built, I
>      >      >     need to
>      >      >     set up boundary labels. I have an array of faces
>     containing a
>      >     series of
>      >      >     3 vertex local indices. To rebuild boundary labels, I
>     need to
>      >     loop over
>      >      >     the array and get the join of 3 consecutive points to
>     find the
>      >      >     corresponding face point in the DAG.
>      >      > This is very common. We should have a built-in thing that
>     does this.
>      >     Ordering apart, it's not very complicated once you figure out
>     "join" is
>      >     the right operation to use. We need more doc on graph layout and
>      >     operations in DMPlex, I think I'm going to make pictures when
>     I'm done
>      >     with that code because I waste too much time every time. Is
>     there a
>      >     starting point you like ?
>      > I think the discussion in
>      > @article{LangeMitchellKnepleyGorman2015,
>      >    title     = {Efficient mesh management in {Firedrake} using
>      > {PETSc-DMPlex}},
>      >    author    = {Michael Lange and Lawrence Mitchell and Matthew G.
>      > Knepley and Gerard J. Gorman},
>      >    journal   = {SIAM Journal on Scientific Computing},
>      >    volume    = {38},
>      >    number    = {5},
>      >    pages     = {S143--S155},
>      >    eprint    = {http://arxiv.org/abs/1506.07749},
>      >    doi       = {10.1137/15M1026092},
>      >    year      = {2016}
>      > is pretty good.
>     It is, I'd just like to have something more complete (meet, join,
>     height, depth...) and with more 2D & 3D pictures. It's all information
>     available somewhere, but I would find it convenient to be all at the
>     same place. Are sources of the paper available somewhere ?
> I think the right answer is no, there is not a complete reference. I
> have some things in presentations,
> but no complete work has been written. Maybe it is time to do that. At
> this point, a book is probably
> possible :)
I'll gladly help with figures or coffees if it can speed up the process ;)
>      >      >     Problem, vertices get reordered by
>      >      >     so that locally owned vertices are before remote ones, so
>      >     local indices
>      >      >     are changed and the indices in the face array are not good
>      >     anymore.
>      >      > This is not exactly what happens. I will talk through the
>      >     algorithm so
>      >      > that maybe we can find a good
>      >      > interface. I can probably write the code quickly:
>      >      > 1) We take in cells[numCells, numCorners], which is a list
>     of all
>      >     the
>      >      > vertices in each cell
>      >      >       The vertex numbers do not have to be a contiguous
>     set. You can
>      >      > have any integers you want.
>      >      > 2) We create a sorted list of the unique vertex numbers on
>     each
>      >     process.
>      >      > The new local vertex numbers
>      >      >       are the locations in this list.
>      >     Ok It took me re-writing this email a couple times but I think I
>      >     understand. I was too focused on local/global indices. But if
>     I get
>      >     this
>      >     right, you still make an assumption: that the numVertices*dim
>      >     coordinates passed in vertexCoords are the coordinates of the
>      >     numvertices first vertices in the sorted list. Is that true ?
>      > No. It can be arbitrary. That is why we make the vertexSF, so we
>     can map
>      > those coordinates back to the right processes.
>     So how do you know which coordinates correspond to which vertex
>     since no
>     map is explicitly provided ?
> Ah, it is based on the input assumptions when everything is put
> together. You could call BuildParallel()
> with any old numbering of vertices. However, if you call
> CreateParallel(), so that you are also passing
> in an array for vertex coordinates. Now vertices are assumed to be
> numbered [0, Nv) to correspond to
> the input array. Now, that array of coordinates can be chopped up
> differently in parallel than the vertices
> for subdomains. The vertexSF can convert between the mappings.
So if on rank 0, I have numCells tets using say 10 different vertices,
and I pass a list of 7*2 coordinates, the coordinates will be assumed to
be those of the 7 first vertices in the sorted unique identifier list ?
Is this fool proof ? (meaning: if it works for me now, can I assume I
did the right thing or should I be careful and look twice ?)
>      >      > Here is my proposed interface. We preserve this list of unique
>      >     vertices,
>      >      > just as we preserve the vertexSF.
>      >      > Then after DMPlexCreateFromCellListParallelPetsc(), can
>      >      > DMPlexInterpolate(), you could call
>      >      >    DMPlexBuildFaceLabelsFromCellList(dm, numFaces, faces,
>     labelName,
>      >      > labelValues)
>      >      > Would that work for you? I think I could do that in a
>     couple of
>      >     hours.
>      >     So that function would be very helpful. But is it as simple
>     as you're
>      >     thinking ? The sorted list gives local index -> unique
>     identifier, but
>      >     what we need is the other way round, isn't it ?
>      > You get the other way using search.
>     Do you mean a linear search for each vertex ?
> Since it is sorted, it is a log search.
You are right. Are you opposed to hash tables though ? :)
Thanks
Nicolas
>    Thanks,
>       Matt
>     Thanks,
>     Nicolas
>      >    Thanks,
>      >       Matt
>      >     Once I understand better, I can have a first draft in my
>     plexadapt code
>      >     and we pull it out later.
>      >     Thanks
>      >     Nicolas
>      >      >    Thanks,
>      >      >       Matt
>      >      >     Is there a way to track this renumbering ? For owned
>      >     vertices, I can
>      >      >     find the local index from the global one (so do old local
>      >     index ->
>      >      >     global index -> new local index). For the remote ones, I'm
>      >     not sure. I
>      >      >     can hash global indices, but is there a more idiomatic
>     way ?
>      >      >     Thanks,
>      >      >     Nicolas
>      >      > What most experimenters take for granted before they begin
>     their
>      >      > experiments is infinitely more interesting than any
>     results to which
>      >      > their experiments lead.
>      >      > -- Norbert Wiener
>      >      > https://www.cse.buffalo.edu/~knepley/
>      >     <http://www.cse.buffalo.edu/~knepley/>
>      > What most experimenters take for granted before they begin their
>      > experiments is infinitely more interesting than any results to which
>      > -- Norbert Wiener
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
