[petsc-users] Runtime error
Jorti, Zakariae
zjorti at lanl.gov
Fri Mar 19 19:49:54 CDT 2021
I have a PETSc code which works in some cases circumstances whereas in others it gives me the error message below.
The code works on my machine when I compile PETSc with debug flag on:
./configure PETSC_DIR=/Users/zjorti/software/petsc-3.14.5 PETSC_ARCH=macx --with-fc=0 --with-mpi-dir=$HOME/.brew --download-hypre --with-debugging=1 --with-cxx-dialect=C++11
It does not work however when I compile Petsc with debug flag off:
./configure PETSC_DIR=/Users/zjorti/software/petsc-3.14.5 PETSC_ARCH=macx --with-fc=0 --with-mpi-dir=$HOME/.brew --download-hypre --with-debugging=0 --with-cxx-dialect=C++11
I asked a colleague to test this same code.
He compiles PETSc with debug flag off, runs the code and it works for him. He has an older machine but we both use the same version PETSc version which is 3.14.5.
As I do not have any debugger I could not identify the cause of this runtime error.
One more thing: We did not run the code in parallel.
Is this a hardware related issue or is it something else?
Zakariae
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
[0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
[0]PETSC ERROR: to get more information on the crash.
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Signal received
[0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
[0]PETSC ERROR: ./mimeticcurleuler2 on a macx named pn2032683.lanl.gov by zjorti Fri Mar 19 16:07:03 2021
[0]PETSC ERROR: Configure options PETSC_DIR=/Users/zjorti/software/petsc-3.14.5 PETSC_ARCH=macx --with-fc=0 --with-mpi-dir=/Users/zjorti/.brew --download-hypre --with-debugging=0 --with-cxx-dialect=C++11
[0]PETSC ERROR: #1 User provided function() line 0 in unknown file
[0]PETSC ERROR: Run with -malloc_debug to check if memory corruption is causing the crash.
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 50176059.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210320/a1c783e6/attachment-0001.html>
