[petsc-users] Outputting cell data in stead of point data while writing .vtr file
Matthew Knepley
knepley at gmail.com
Thu Mar 11 07:54:05 CST 2021
On Thu, Mar 11, 2021 at 8:17 AM Smit Thijs <thijs.smit at hest.ethz.ch> wrote:
> Hi Matt,
> Actually I have two 3D DMDA’s, one for the nodal data, where the FEM is
> solved on. The other DMDA is a cell centered one for the volume data, like
> the density of a particular voxel. Ideally I would like to write both point
> data (displacement field) and cell data (density) to the vtr.
> Code for DMDA.
> DMBoundaryType bx = DM_BOUNDARY_NONE;
> DMBoundaryType by = DM_BOUNDARY_NONE;
> DMBoundaryType bz = DM_BOUNDARY_NONE;
> DMDAStencilType stype = DMDA_STENCIL_BOX;
> PetscInt stencilwidth = 1;
> // Create the nodal mesh
> ierr = DMDACreate3d(PETSC_COMM_WORLD, bx, by, bz, stype, nx, ny, nz,
> PETSC_DECIDE, PETSC_DECIDE, PETSC_DECIDE,
> numnodaldof, stencilwidth, 0, 0, 0, &(da_nodes));
> CHKERRQ(ierr);
> DMSetFromOptions(da_nodes);
> DMSetUp(da_nodes);
> ierr = DMDASetUniformCoordinates(da_nodes, xmin, xmax, ymin, ymax,
> zmin, zmax);
> CHKERRQ(ierr);
> ierr = DMDASetElementType(da_nodes, DMDA_ELEMENT_Q1);
> CHKERRQ(ierr);
When I wrote the original version which output to ASCII VTK, we allowed
switching between point data and cell data. It is
fragile since you have to assure that the different grids match properly.
When the viewer was rewritten to use the XML,
all output was point data. It looks like it would take code changes to get
this done.
Matt
> Best, Thijs
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* 11 March 2021 14:08
> *To:* Smit Thijs <thijs.smit at hest.ethz.ch>
> *Cc:* petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] Outputting cell data in stead of point data
> What kind of DM is it?
> Thanks,
> Matt
> On Thu, Mar 11, 2021 at 3:36 AM Smit Thijs <thijs.smit at hest.ethz.ch>
> wrote:
> Hi All,
> I am outputting several vectors to a .vtr file successfully for viewing in
> Paraview. At this moment the information is written to point data. How can
> I change this and make sure the data is written to cell data?
> The code I am currently using for outputting:
> PetscViewer viewer;
> ierr = PetscViewerVTKOpen(PETSC_COMM_WORLD, “test.vtr”, FILE_MODE_WRITE,
> &viewer);
> CHKERRQ(ierr);
> ierr = DMView(nd, viewer);
> CHKERRQ(ierr);
> PetscObjectSetName((PetscObject)xPhys,"xPhys");
> ierr = VecView(xPhys, viewer);
> CHKERRQ(ierr);
> PetscObjectSetName((PetscObject)S,"SvonMises");
> ierr = VecView(S, viewer);
> CHKERRQ(ierr);
> ierr = PetscViewerDestroy(&viewer);
> CHKERRQ(ierr);
> Best regards,
> Thijs Smit
> PhD Candidate
> ETH Zurich
> Institute for Biomechanics
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210311/e0606aef/attachment.html>
