[petsc-users] DMPlex tetrahedra facets orientation
Nicolas Barral nicolas.barral at math.u-bordeaux.fr
Mon Mar 8 03:02:31 CST 2021
On 07/03/2021 22:56, Matthew Knepley wrote:
> On Sun, Mar 7, 2021 at 4:51 PM Nicolas Barral
> <nicolas.barral at math.u-bordeaux.fr
> <mailto:nicolas.barral at math.u-bordeaux.fr>> wrote:
>     On 07/03/2021 22:30, Matthew Knepley wrote:
>      > On Sun, Mar 7, 2021 at 4:13 PM Nicolas Barral
>     <mailto:nicolas.barral at math.u-bordeaux.fr>>> wrote:
>      >     On 07/03/2021 16:54, Matthew Knepley wrote:
>      >      > On Sun, Mar 7, 2021 at 8:52 AM Nicolas Barral
>      >      > <nicolas.barral at math.u-bordeaux.fr
>      >      > <mailto:nicolas.barral at math.u-bordeaux.fr
>     <mailto:nicolas.barral at math.u-bordeaux.fr>>>> wrote:
>      >      >     Matt,
>      >      >     Thanks for your answer.
>      >      >     However, DMPlexComputeCellGeometryFVM does not compute
>     what I
>      >     need
>      >      >     (normals of height 1 entities). I can't find any
>     function doing
>      >      >     that, is
>      >      >     there one ?
>      >      > The normal[] in DMPlexComputeCellGeometryFVM() is exactly what
>      >     you want.
>      >      > What does not look right to you?
>      >     So it turns out it's not what I want because I need
>     non-normalized
>      >     normals. It doesn't seem like I can easily retrieve the norm,
>     can I?
>      > You just want area-weighted normals I think, which means that you
>     just
>      > multiply by the area,
>      > which comes back in the same function.
>     Ah by the area times 2, of course, my bad.
>     Do you order height-1 elements in a certain way ? I need to access the
>     facet (resp. edge) opposite to a vertex in a tet (resp. triangle).
> Yes. Now that I have pretty much settled on it, I will put it in the
> manual. It is currently here:
> https://gitlab.com/petsc/petsc/-/blob/main/src/dm/impls/plex/plexinterpolate.c#L56
> All normals are outward facing, but hopefully the ordering in the sourse
> file makes sense.
Thanks Matt, but I'm not sure I understand well. What I do so far is:
ierr = DMPlexGetCone(dm, c, &cone);CHKERRQ(ierr);
   for (i=0; i<dim+1; ++i) {
     f = cone[i];
     ierr = DMPlexComputeCellGeometryFVM(dm, f, &area, NULL,
&vn[i*dim]);CHKERRQ(ierr);
     if (dim == 3) { area *= 2; }
     for (j=0; j<dim; ++j) { vn[i*dim+j] *= area; }
So in 3D, it seems that:
(vn[9],vn[10],vn[11]) is the inward normal to the facet opposing vertex0
(vn[6],vn[7],vn[8])             "                    "                 1
(vn[3],vn[4],vn[5])             "                    "                 2
(vn[0],vn[1],vn[2])             "                    "                 3
in 2D:
(vn[2],vn[3]) is a normal to the edge opposing vertex 0
(vn[4],vn[5])          "                  "           1
(vn[0],vn[1])          "                  "           2
Yet in 2D, whether the normals are inward or outward does not seem
consistent across elements.
What am I wrongly assuming ?
Nicolas
>    Thanks,
>      Matt
>     Thanks
>     Nicolas
>      >    Thanks,
>      >      Matt
>      >     If not, I'll fallback to computing them by hand for now. Is the
>      >     following assumption safe or do I have to use
>     DMPlexGetOrientedFace?
>      >       >  if I call P0P1P2P3 a tet and note x the cross product,
>      >       >  P3P2xP3P1 is the outward normal to face P1P2P3
>      >       >  P0P2xP0P3              "                P0P2P3
>      >       >  P3P1xP3P0              "                P0P1P3
>      >       >  P0P1xP0P2              "                P0P1P2
>      >     Thanks
>      >     Nicolas
>      >      >    Thanks,
>      >      >      Matt
>      >      >     So far I've been doing it by hand, and after a lot of
>      >     experimenting the
>      >      >     past weeks, it seems that if I call P0P1P2P3 a tetrahedron
>      >     and note x
>      >      >     the cross product,
>      >      >     Have I been lucky but can't expect it to be true ?
>      >      >     (Alternatively, there is a link between the normals
>     and the
>      >     element
>      >      >     Jacobian, but I don't know the formula and can  find them)
>      >      >     Thanks,
>      >      >     Nicolas
>      >      >     On 08/02/2021 15:19, Matthew Knepley wrote:
>      >      >      > On Mon, Feb 8, 2021 at 6:01 AM Nicolas Barral
>      >      >      > <nicolas.barral at math.u-bordeaux.fr
>      >      >      > <mailto:nicolas.barral at math.u-bordeaux.fr
>     <mailto:nicolas.barral at math.u-bordeaux.fr>>>>> wrote:
>      >      >      >     Hi all,
>      >      >      >     Can I make any assumption on the orientation of
>     triangular
>      >      >     facets in a
>      >      >      >     tetrahedral plex ? I need the inward facet
>     normals. Do
>      >     I need
>      >      >     to use
>      >      >      >     DMPlexGetOrientedFace or can I rely on either
>     the tet
>      >     vertices
>      >      >      >     ordering,
>      >      >      >     or the faces ordering ? Could
>      >     DMPlexGetRawFaces_Internal be
>      >      >     enough ?
>      >      >      > You can do it by hand, but you have to account for
>     the face
>      >      >     orientation
>      >      >      > relative to the cell. That is what
>      >      >      > DMPlexGetOrientedFace() does. I think it would be
>     easier
>      >     to use the
>      >      >      > function below.
>      >      >      >     Alternatively, is there a function that
>     computes the
>      >     normals
>      >      >     - without
>      >      >      >     bringing out the big guns ?
>      >      >      > This will compute the normals
>     https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMPLEX/DMPlexComputeCellGeometryFVM.html
>      >      >      > Should not be too heavy weight.
>      >      >      >    THanks,
>      >      >      >      Matt
>      >      >      >     Thanks
>      >      >      >     Nicolas
>      >      >      > What most experimenters take for granted before
>     they begin
>      >     their
>      >      >      > experiments is infinitely more interesting than any
>      >     results to which
>      >      >      > their experiments lead.
>      >      >      > -- Norbert Wiener
>      >      >      > https://www.cse.buffalo.edu/~knepley/
>      >      >     <http://www.cse.buffalo.edu/~knepley/>
>      >      > What most experimenters take for granted before they begin
>     their
>     results to which
>      >      > -- Norbert Wiener
>      > What most experimenters take for granted before they begin their
>      > experiments is infinitely more interesting than any results to which
>      > -- Norbert Wiener
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
