[petsc-users] DMPlex in Firedrake: scaling of mesh distribution
Jed Brown jed at jedbrown.org
Sun Mar 7 18:40:00 CST 2021
There is some use of Iscatterv in SF implementations (though it looks like perhaps not PetscSFBcast where the root nodes are consolidated on a root rank).
We should perhaps have a function that analyzes the graph to set the type rather than requiring the caller to PetscSFSetType.
Barry Smith <bsmith at petsc.dev> writes:
>    Mark,
>    Thanks for the numbers.
>    Extremely problematic. DMPlexDistribute takes 88 percent of the total run time, SFBcastOpEnd takes 80 percent.
>    Probably Matt is right, PetscSF is flooding the network which it cannot handle. IMHO fixing PetscSF would be a far better route than writing all kinds of fancy DMPLEX hierarchical distributors.   PetscSF needs to detect that it  is sending too many messages together and do the messaging in appropriate waves; at the moment PetscSF is as dumb as stone it just shoves everything out as fast as it can. Junchao needs access to this machine. If everything in PETSc will depend on PetscSF then it simply has to scale on systems where you cannot just flood the network with MPI.
>   Barry
> Mesh Partition         1 1.0 5.0133e+02 1.0 0.00e+00 0.0 1.3e+05 2.7e+02 6.0e+00 15  0  0  0  0  15  0  0  0  1     0
> Mesh Migration         1 1.0 1.5494e+03 1.0 0.00e+00 0.0 7.3e+05 1.9e+02 2.4e+01 45  0  0  0  1  46  0  0  0  2     0
> DMPlexPartStrtSF       1 1.0 4.9474e+023520.8 0.00e+00 0.0 3.3e+04 4.3e+00.0e+00 14  0  0  0  0  15  0  0  0  0     0
> DMPlexPointSF          1 1.0 9.8750e+021264.8 0.00e+00 0.0 6.6e+04 5.4e+00.0e+00 28  0  0  0  0  29  0  0  0  0     0
> DMPlexDistribute       1 1.0 3.0000e+03 1.5 0.00e+00 0.0 9.3e+05 2.3e+02 3.0e+01 88  0  0  0  2  90  0  0  0  3     0
> DMPlexDistCones        1 1.0 1.0688e+03 2.6 0.00e+00 0.0 1.8e+05 3.1e+02 1.0e+00 31  0  0  0  0  31  0  0  0  0     0
> DMPlexDistLabels       1 1.0 2.9172e+02 1.0 0.00e+00 0.0 3.1e+05 1.9e+02 2.1e+01  9  0  0  0  1   9  0  0  0  2     0
> DMPlexDistField        1 1.0 1.8688e+02 1.2 0.00e+00 0.0 2.1e+05 9.3e+01 1.0e+00  5  0  0  0  0   5  0  0  0  0     0
> SFSetUp               62 1.0 7.3283e+0213.6 0.00e+00 0.0 2.0e+07 2.7e+04 0.0e+00  5  0  1  3  0   5  0  6  9  0     0
> SFBcastOpBegin       107 1.0 1.5770e+00452.5 0.00e+00 0.0 2.1e+07 1.8e+04 0.0e+00 0  0  1  2  0   0  0  6  6  0     0
> SFBcastOpEnd         107 1.0 2.9430e+03 4.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 80  0  0  0  0  82  0  0  0  0     0
> SFDistSection          9 1.0 4.4325e+02 1.5 0.00e+00 0.0 2.8e+06 1.1e+04 9.0e+00 11  0  0  0  0  11  0  1  1  1     0
> SFSectionSF           11 1.0 2.3898e+02 4.7 0.00e+00 0.0 9.2e+05 1.7e+05 0.0e+00  5  0  0  1  0   5  0  0  2  0     0
>> On Mar 7, 2021, at 7:35 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> And this data puts one cell per process, distributes, and then refines 5 (or 2,3,4 in plot) times.
>> On Sun, Mar 7, 2021 at 8:27 AM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>> FWIW, Here is the output from ex13 on 32K processes (8K Fugaku nodes/sockets, 4 MPI/node, which seems recommended) with 128^3 vertex mesh (64^3 Q2 3D Laplacian).
>> Almost an hour.
>> Attached is solver scaling.
>>   0 SNES Function norm 3.658334849208e+00
>>   Linear solve converged due to CONVERGED_RTOL iterations 22
>>   1 SNES Function norm 1.609000373074e-12
>> Nonlinear solve converged due to CONVERGED_ITS iterations 1
>> ***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
>> ---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
>> ../ex13 on a  named i07-4008c with 32768 processors, by a04199 Fri Feb 12 23:27:13 2021
>> Using Petsc Development GIT revision: v3.14.4-579-g4cb72fa  GIT Date: 2021-02-05 15:19:40 +0000
>>                          Max       Max/Min     Avg       Total
>> Time (sec):           3.373e+03     1.000   3.373e+03
>> Objects:              1.055e+05    14.797   7.144e+03
>> Flop:                 5.376e+10     1.176   4.885e+10  1.601e+15
>> Flop/sec:             1.594e+07     1.176   1.448e+07  4.745e+11
>> MPI Messages:         6.048e+05    30.010   8.833e+04  2.894e+09
>> MPI Message Lengths:  1.127e+09     4.132   6.660e+03  1.928e+13
>> MPI Reductions:       1.824e+03     1.000
>> Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
>>                             e.g., VecAXPY() for real vectors of length N --> 2N flop
>>                             and VecAXPY() for complex vectors of length N --> 8N flop
>> Summary of Stages:   ----- Time ------  ----- Flop ------  --- Messages ---  -- Message Lengths --  -- Reductions --
>>                         Avg     %Total     Avg     %Total    Count   %Total     Avg         %Total    Count   %Total
>>  0:      Main Stage: 3.2903e+03  97.5%  2.4753e+14  15.5%  3.538e+08  12.2%  1.779e+04       32.7%  9.870e+02  54.1%
>>  1:         PCSetUp: 4.3062e+01   1.3%  1.8160e+13   1.1%  1.902e+07   0.7%  3.714e+04        3.7%  1.590e+02   8.7%
>>  2:  KSP Solve only: 3.9685e+01   1.2%  1.3349e+15  83.4%  2.522e+09  87.1%  4.868e+03       63.7%  6.700e+02  36.7%
>> See the 'Profiling' chapter of the users' manual for details on interpreting output.
>> Phase summary info:
>>    Count: number of times phase was executed
>>    Time and Flop: Max - maximum over all processors
>>                   Ratio - ratio of maximum to minimum over all processors
>>    Mess: number of messages sent
>>    AvgLen: average message length (bytes)
>>    Reduct: number of global reductions
>>    Global: entire computation
>>    Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
>>       %T - percent time in this phase         %F - percent flop in this phase
>>       %M - percent messages in this phase     %L - percent message lengths in this phase
>>       %R - percent reductions in this phase
>>    Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over all processors)
>> Event                Count      Time (sec)     Flop                              --- Global ---  --- Stage ----  Total
>>                    Max Ratio  Max     Ratio   Max  Ratio  Mess   AvgLen  Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
>> --- Event Stage 0: Main Stage
>> PetscBarrier           5 1.0 1.9907e+00 2.2 0.00e+00 0.0 3.8e+06 7.7e+01 2.0e+01  0  0  0  0  1   0  0  1  0  2     0
>> BuildTwoSided         62 1.0 7.3272e+0214.1 0.00e+00 0.0 6.7e+06 8.0e+00 0.0e+00  5  0  0  0  0   5  0  2  0  0     0
>> BuildTwoSidedF        59 1.0 3.1132e+01 7.4 0.00e+00 0.0 4.8e+06 2.5e+05 0.0e+00  0  0  0  6  0   0  0  1 19  0     0
>> SNESSolve              1 1.0 1.7468e+02 1.0 7.83e+09 1.3 3.4e+08 1.3e+04 8.8e+02  5 13 12 23 48   5 85 96 70 89 1205779
>> SNESSetUp              1 1.0 2.4195e+01 1.0 0.00e+00 0.0 3.7e+06 3.7e+05 1.3e+01  1  0  0  7  1   1  0  1 22  1     0
>> SNESFunctionEval       3 1.0 1.1359e+01 1.2 1.17e+09 1.0 1.6e+06 1.4e+04 2.0e+00  0  2  0  0  0   0 15  0  0  0 3344744
>> SNESJacobianEval       2 1.0 1.6829e+02 1.0 1.52e+09 1.0 1.1e+06 8.3e+05 0.0e+00  5  3  0  5  0   5 20  0 14  0 293588
>> DMCreateMat            1 1.0 2.4107e+01 1.0 0.00e+00 0.0 3.7e+06 3.7e+05 1.3e+01  1  0  0  7  1   1  0  1 22  1     0
>> DMPlexPartSelf         1 1.0 1.1498e+002367.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> DMPlexPartLblInv       1 1.0 3.6698e+00 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> DMPlexPartLblSF        1 1.0 2.8522e-01 1.7 0.00e+00 0.0 4.9e+04 1.5e+02 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> DMPlexPartStrtSF       1 1.0 4.9474e+023520.8 0.00e+00 0.0 3.3e+04 4.3e+02 0.0e+00 14  0  0  0  0  15  0  0  0  0     0
>> DMPlexPointSF          1 1.0 9.8750e+021264.8 0.00e+00 0.0 6.6e+04 5.4e+02 0.0e+00 28  0  0  0  0  29  0  0  0  0     0
>> DMPlexInterp          84 1.0 4.3219e-0158.6 0.00e+00 0.0 0.0e+00 0.0e+00 5.0e+00  0  0  0  0  0   0  0  0  0  1     0
>> DMPlexStratify       118 1.0 6.2852e+023280.9 0.00e+00 0.0 0.0e+00 0.0e+00 1.6e+01  1  0  0  0  1   1  0  0  0  2     0
>> DMPlexSymmetrize     118 1.0 6.7634e-02 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> DMPlexPrealloc         1 1.0 2.3741e+01 1.0 0.00e+00 0.0 3.7e+06 3.7e+05 1.1e+01  1  0  0  7  1   1  0  1 22  1     0
>> DMPlexResidualFE       3 1.0 1.0634e+01 1.2 1.16e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0 15  0  0  0 3569848
>> DMPlexJacobianFE       2 1.0 1.6809e+02 1.0 1.51e+09 1.0 6.5e+05 1.4e+06 0.0e+00  5  3  0  5  0   5 20  0 14  0 293801
>> SFSetGraph            87 1.0 2.7673e-03 3.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> SFReduceBegin         12 1.0 2.4825e-01172.8 0.00e+00 0.0 2.4e+06 2.0e+05 0.0e+00  0  0  0  2  0   0  0  1  8  0     0
>> SFReduceEnd           12 1.0 3.8286e+014865.8 3.74e+04 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0    31
>> SFFetchOpBegin         2 1.0 2.4497e-0390.2 0.00e+00 0.0 4.3e+05 3.5e+05 0.0e+00  0  0  0  1  0   0  0  0  2  0     0
>> SFFetchOpEnd           2 1.0 6.1349e-0210.9 0.00e+00 0.0 4.3e+05 3.5e+05 0.0e+00  0  0  0  1  0   0  0  0  2  0     0
>> SFCreateEmbed          3 1.0 3.6800e+013261.5 0.00e+00 0.0 4.7e+05 1.7e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> SFRemoteOff            2 1.0 3.2868e-0143.1 0.00e+00 0.0 8.7e+05 8.2e+03 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> SFPack              1023 1.0 2.5215e-0176.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> SFUnpack            1025 1.0 5.1600e-0216.8 5.62e+0521.3 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 54693
>> MatMult            1549525.4 3.4810e+00 1.3 4.35e+09 1.1 2.2e+08 6.1e+03 0.0e+00  0  8  8  7  0   0 54 62 21  0 38319208
>> MatMultAdd           132 1.0 6.9168e-01 3.0 7.97e+07 1.2 2.8e+07 4.6e+02 0.0e+00  0  0  1  0  0   0  1  8  0  0 3478717
>> MatMultTranspose     132 1.0 5.9967e-01 1.6 8.00e+07 1.2 3.0e+07 4.5e+02 0.0e+00  0  0  1  0  0   0  1  9  0  0 4015214
>> MatSolve              22 0.0 6.8431e-04 0.0 7.41e+05 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1082
>> MatLUFactorSym         1 1.0 5.9569e-0433.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> MatLUFactorNum         1 1.0 1.6236e-03773.2 1.46e+06 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   897
>> MatConvert             6 1.0 1.4290e-01 1.2 0.00e+00 0.0 3.0e+06 3.7e+03 0.0e+00  0  0  0  0  0   0  0  1  0  0     0
>> MatScale              18 1.0 3.7962e-01 1.3 4.11e+07 1.2 2.0e+06 5.5e+03 0.0e+00  0  0  0  0  0   0  0  1  0  0 3253392
>> MatResidual          132 1.0 6.8256e-01 1.4 8.27e+08 1.2 4.4e+07 5.5e+03 0.0e+00  0  2  2  1  0   0 10 13  4  0 36282014
>> MatAssemblyBegin     244 1.0 3.1181e+01 6.6 0.00e+00 0.0 4.8e+06 2.5e+05 0.0e+00  0  0  0  6  0   0  0  1 19  0     0
>> MatAssemblyEnd       244 1.0 6.3232e+00 1.9 3.17e+06 6.9 0.0e+00 0.0e+00 1.4e+02  0  0  0  0  8   0  0  0  0 15  7655
>> MatGetRowIJ            1 0.0 2.5780e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> MatCreateSubMat       10 1.0 1.5162e+00 1.0 0.00e+00 0.0 1.6e+05 3.4e+05 1.3e+02  0  0  0  0  7   0  0  0  1 13     0
>> MatGetOrdering         1 0.0 1.0899e-04 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> MatCoarsen             6 1.0 3.5837e-01 1.3 0.00e+00 0.0 1.6e+07 1.2e+04 3.9e+01  0  0  1  1  2   0  0  5  3  4     0
>> MatZeroEntries         8 1.0 5.3730e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> MatAXPY                6 1.0 2.6245e-01 1.1 2.66e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 33035
>> MatTranspose          12 1.0 3.0731e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> MatMatMultSym         18 1.0 2.1398e+00 1.4 0.00e+00 0.0 6.1e+06 5.5e+03 4.8e+01  0  0  0  0  3   0  0  2  1  5     0
>> MatMatMultNum          6 1.0 1.1243e+00 1.0 3.76e+07 1.2 2.0e+06 5.5e+03 0.0e+00  0  0  0  0  0   0  0  1  0  0 1001203
>> MatPtAPSymbolic        6 1.0 1.7280e+01 1.0 0.00e+00 0.0 1.2e+07 3.2e+04 4.2e+01  1  0  0  2  2   1  0  3  6  4     0
>> MatPtAPNumeric         6 1.0 1.8047e+01 1.0 1.49e+09 5.1 2.8e+06 1.1e+05 2.4e+01  1  1  0  2  1   1  5  1  5  2 663675
>> MatTrnMatMultSym       1 1.0 3.0221e+01 1.0 0.00e+00 0.0 2.4e+06 5.8e+05 1.1e+01  1  0  0  7  1   1  0  1 22  1     0
>> MatGetLocalMat        19 1.0 1.3904e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> MatGetBrAoCol         18 1.0 1.9926e-01 5.0 0.00e+00 0.0 1.4e+07 2.3e+04 0.0e+00  0  0  0  2  0   0  0  4  5  0     0
>> MatGetSymTrans         2 1.0 1.8996e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> VecTDot              176 1.0 7.0632e-01 4.5 3.48e+07 1.0 0.0e+00 0.0e+00 1.8e+02  0  0  0  0 10   0  0  0  0 18 1608728
>> VecNorm               60 1.0 1.4074e+0012.2 1.58e+07 1.0 0.0e+00 0.0e+00 6.0e+01  0  0  0  0  3   0  0  0  0  6 366467
>> VecCopy              422 1.0 5.1259e-02 3.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> VecSet               653 1.0 2.3974e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> VecAXPY              165 1.0 6.5622e-03 1.3 3.42e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 170485467
>> VecAYPX              861 1.0 7.8529e-02 1.2 6.21e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 25785252
>> VecAXPBYCZ           264 1.0 4.1343e-02 1.5 5.85e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 46135592
>> VecAssemblyBegin      21 1.0 2.3463e-01 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> VecAssemblyEnd        21 1.0 1.4457e-04 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> VecPointwiseMult     600 1.0 5.7510e-02 1.2 2.66e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 15075754
>> VecScatterBegin      902 1.0 5.1188e-01 1.2 0.00e+00 0.0 2.9e+08 5.3e+03 0.0e+00  0  0 10  8  0   0  0 82 25  0     0
>> VecScatterEnd        902 1.0 1.2143e+00 3.2 5.50e+0537.9 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1347
>> VecSetRandom           6 1.0 2.6354e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> DualSpaceSetUp         7 1.0 5.3467e-0112.0 4.26e+03 1.0 0.0e+00 0.0e+00 1.3e+01  0  0  0  0  1   0  0  0  0  1   261
>> FESetUp                7 1.0 1.7541e-01128.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> KSPSetUp              15 1.0 2.7470e-01 1.1 2.04e+08 1.2 1.0e+07 5.5e+03 1.3e+02  0  0  0  0  7   0  2  3  1 13 22477233
>> KSPSolve               1 1.0 4.3257e+00 1.0 4.33e+09 1.1 2.5e+08 4.8e+03 6.6e+01  0  8  9  6  4   0 54 72 20  7 30855976
>> PCGAMGGraph_AGG        6 1.0 5.0969e+00 1.0 3.76e+07 1.2 5.1e+06 4.4e+03 4.8e+01  0  0  0  0  3   0  0  1  0  5 220852
>> PCGAMGCoarse_AGG       6 1.0 3.1121e+01 1.0 0.00e+00 0.0 2.5e+07 6.9e+04 5.5e+01  1  0  1  9  3   1  0  7 27  6     0
>> PCGAMGProl_AGG         6 1.0 5.8196e-01 1.0 0.00e+00 0.0 6.6e+06 9.3e+03 7.2e+01  0  0  0  0  4   0  0  2  1  7     0
>> PCGAMGPOpt_AGG         6 1.0 3.2414e+00 1.0 2.42e+08 1.2 2.1e+07 5.3e+03 1.6e+02  0  0  1  1  9   0  3  6  2 17 2256493
>> GAMG: createProl       6 1.0 4.0042e+01 1.0 2.80e+08 1.2 5.8e+07 3.3e+04 3.4e+02  1  1  2 10 19   1  3 16 31 34 210778
>>   Graph               12 1.0 5.0926e+00 1.0 3.76e+07 1.2 5.1e+06 4.4e+03 4.8e+01  0  0  0  0  3   0  0  1  0  5 221038
>>   MIS/Agg              6 1.0 3.5850e-01 1.3 0.00e+00 0.0 1.6e+07 1.2e+04 3.9e+01  0  0  1  1  2   0  0  5  3  4     0
>>   SA: col data         6 1.0 3.0509e-01 1.0 0.00e+00 0.0 5.4e+06 9.2e+03 2.4e+01  0  0  0  0  1   0  0  2  1  2     0
>>   SA: frmProl0         6 1.0 2.3467e-01 1.1 0.00e+00 0.0 1.3e+06 9.5e+03 2.4e+01  0  0  0  0  1   0  0  0  0  2     0
>>   SA: smooth           6 1.0 2.7855e+00 1.0 4.14e+07 1.2 8.1e+06 5.5e+03 6.3e+01  0  0  0  0  3   0  1  2  1  6 446491
>> GAMG: partLevel        6 1.0 3.7266e+01 1.0 1.49e+09 5.1 1.5e+07 4.9e+04 3.2e+02  1  1  1  4 17   1  5  4 12 32 321395
>>   repartition          5 1.0 2.0343e+00 1.1 0.00e+00 0.0 4.0e+05 1.4e+05 2.5e+02  0  0  0  0 14   0  0  0  1 25     0
>>   Invert-Sort          5 1.0 1.5021e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+01  0  0  0  0  2   0  0  0  0  3     0
>>   Move A               5 1.0 1.1548e+00 1.0 0.00e+00 0.0 1.6e+05 3.4e+05 7.0e+01  0  0  0  0  4   0  0  0  1  7     0
>>   Move P               5 1.0 4.2799e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 7.5e+01  0  0  0  0  4   0  0  0  0  8     0
>> PCGAMG Squ l00         1 1.0 3.0221e+01 1.0 0.00e+00 0.0 2.4e+06 5.8e+05 1.1e+01  1  0  0  7  1   1  0  1 22  1     0
>> PCGAMG Gal l00         1 1.0 8.7411e+00 1.0 2.93e+08 1.1 5.4e+06 4.5e+04 1.2e+01  0  1  0  1  1   0  4  2  4  1 1092355
>> PCGAMG Opt l00         1 1.0 1.9734e+00 1.0 3.36e+07 1.1 3.2e+06 1.2e+04 9.0e+00  0  0  0  0  0   0  0  1  1  1 555327
>> PCGAMG Gal l01         1 1.0 1.0153e+00 1.0 3.50e+07 1.4 5.9e+06 3.9e+04 1.2e+01  0  0  0  1  1   0  0  2  4  1 1079887
>> PCGAMG Opt l01         1 1.0 7.4812e-02 1.0 5.35e+05 1.2 3.2e+06 1.1e+03 9.0e+00  0  0  0  0  0   0  0  1  0  1 232542
>> PCGAMG Gal l02         1 1.0 1.8063e+00 1.0 7.43e+07 0.0 3.0e+06 5.9e+04 1.2e+01  0  0  0  1  1   0  0  1  3  1 593392
>> PCGAMG Opt l02         1 1.0 1.1580e-01 1.1 6.93e+05 0.0 1.6e+06 1.3e+03 9.0e+00  0  0  0  0  0   0  0  0  0  1 93213
>> PCGAMG Gal l03         1 1.0 6.1075e+00 1.0 2.72e+08 0.0 2.6e+05 9.2e+04 1.1e+01  0  0  0  0  1   0  0  0  0  1 36155
>> PCGAMG Opt l03         1 1.0 8.0836e-02 1.0 1.55e+06 0.0 1.4e+05 1.4e+03 8.0e+00  0  0  0  0  0   0  0  0  0  1 18229
>> PCGAMG Gal l04         1 1.0 1.6203e+01 1.0 9.44e+08 0.0 1.4e+04 3.0e+05 1.1e+01  0  0  0  0  1   0  0  0  0  1  2366
>> PCGAMG Opt l04         1 1.0 1.2663e-01 1.0 2.01e+06 0.0 6.9e+03 2.2e+03 8.0e+00  0  0  0  0  0   0  0  0  0  1   817
>> PCGAMG Gal l05         1 1.0 1.4800e+00 1.0 3.16e+08 0.0 9.0e+01 1.6e+05 1.1e+01  0  0  0  0  1   0  0  0  0  1   796
>> PCGAMG Opt l05         1 1.0 8.1763e-02 1.1 2.50e+06 0.0 4.8e+01 4.6e+03 8.0e+00  0  0  0  0  0   0  0  0  0  1   114
>> PCSetUp                2 1.0 7.7969e+01 1.0 1.97e+09 2.8 8.3e+07 3.3e+04 8.1e+02  2  2  3 14 44   2 11 23 43 82 341051
>> PCSetUpOnBlocks       22 1.0 2.4609e-0317.2 1.46e+06 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   592
>> PCApply               22 1.0 3.6455e+00 1.1 3.57e+09 1.2 2.4e+08 4.3e+03 0.0e+00  0  7  8  5  0   0 43 67 16  0 29434967
>> --- Event Stage 1: PCSetUp
>> BuildTwoSided          4 1.0 1.5980e-01 2.7 0.00e+00 0.0 2.1e+05 8.0e+00 0.0e+00  0  0  0  0  0   0  0  1  0  0     0
>> BuildTwoSidedF         6 1.0 1.3169e+01 5.5 0.00e+00 0.0 1.9e+06 1.9e+05 0.0e+00  0  0  0  2  0  28  0 10 51  0     0
>> SFSetGraph             5 1.0 4.9640e-0519.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> SFSetUp                4 1.0 1.6038e-01 2.3 0.00e+00 0.0 6.4e+05 9.1e+02 0.0e+00  0  0  0  0  0   0  0  3  0  0     0
>> SFPack                30 1.0 3.3376e-04 4.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> SFUnpack              30 1.0 1.2101e-05 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> MatMult               30 1.0 1.5544e-01 1.5 1.87e+08 1.2 1.0e+07 5.5e+03 0.0e+00  0  0  0  0  0   0 31 53  8  0 35930640
>> MatAssemblyBegin      43 1.0 1.3201e+01 4.7 0.00e+00 0.0 1.9e+06 1.9e+05 0.0e+00  0  0  0  2  0  28  0 10 51  0     0
>> MatAssemblyEnd        43 1.0 1.1159e+01 1.0 2.77e+07705.7 0.0e+00 0.0e+00 2.0e+01  0  0  0  0  1  26  0  0  0 13  1036
>> MatZeroEntries         6 1.0 4.7315e-0410.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> MatTranspose          12 1.0 2.5142e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> MatMatMultSym         10 1.0 5.8783e-0117.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> MatPtAPSymbolic        5 1.0 1.4489e+01 1.0 0.00e+00 0.0 6.2e+06 3.6e+04 3.5e+01  0  0  0  1  2  34  0 32 31 22     0
>> MatPtAPNumeric         6 1.0 2.8457e+01 1.0 1.50e+09 5.1 2.7e+06 1.6e+05 2.0e+01  1  1  0  2  1  66 66 14 61 13 421190
>> MatGetLocalMat         6 1.0 9.8574e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> MatGetBrAoCol          6 1.0 3.7669e-01 2.3 0.00e+00 0.0 5.1e+06 3.8e+04 0.0e+00  0  0  0  1  0   0  0 27 28  0     0
>> VecTDot               66 1.0 6.5271e-02 4.1 5.85e+06 1.0 0.0e+00 0.0e+00 6.6e+01  0  0  0  0  4   0  1  0  0 42 2922260
>> VecNorm               36 1.0 1.1226e-02 3.2 3.19e+06 1.0 0.0e+00 0.0e+00 3.6e+01  0  0  0  0  2   0  1  0  0 23 9268067
>> VecCopy               12 1.0 1.2805e-03 3.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> VecSet                11 1.0 6.6620e-05 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> VecAXPY               60 1.0 1.0763e-03 1.5 5.32e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 161104914
>> VecAYPX               24 1.0 2.0581e-03 1.3 2.13e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 33701038
>> VecPointwiseMult      36 1.0 3.5709e-03 1.3 1.60e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 14567861
>> VecScatterBegin       30 1.0 2.9079e-03 7.8 0.00e+00 0.0 1.0e+07 5.5e+03 0.0e+00  0  0  0  0  0   0  0 53  8  0     0
>> VecScatterEnd         30 1.0 3.7015e-0263.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> KSPSetUp               7 1.0 2.3165e-01 1.0 2.04e+08 1.2 1.0e+07 5.5e+03 1.0e+02  0  0  0  0  6   1 34 53  8 64 26654598
>> PCGAMG Gal l00         1 1.0 4.7415e+00 1.0 2.94e+08 1.1 1.8e+06 7.8e+04 0.0e+00  0  1  0  1  0  11 53  9 20  0 2015623
>> PCGAMG Gal l01         1 1.0 1.2103e+00 1.0 3.50e+07 1.4 4.8e+06 6.2e+04 1.2e+01  0  0  0  2  1   3  6 25 41  8 905938
>> PCGAMG Gal l02         1 1.0 3.4334e+00 1.0 7.41e+07 0.0 2.2e+06 8.7e+04 1.2e+01  0  0  0  1  1   8  6 11 27  8 312184
>> PCGAMG Gal l03         1 1.0 9.6062e+00 1.0 2.71e+08 0.0 1.9e+05 1.3e+05 1.1e+01  0  0  0  0  1  22  1  1  4  7 22987
>> PCGAMG Gal l04         1 1.0 2.2482e+01 1.0 9.43e+08 0.0 8.7e+03 4.8e+05 1.1e+01  1  0  0  0  1  52  0  0  1  7  1705
>> PCGAMG Gal l05         1 1.0 1.5961e+00 1.1 3.16e+08 0.0 6.8e+01 2.2e+05 1.1e+01  0  0  0  0  1   4  0  0  0  7   738
>> PCSetUp                1 1.0 4.3191e+01 1.0 1.70e+09 3.6 1.9e+07 3.7e+04 1.6e+02  1  1  1  4  9 100100100100100 420463
>> --- Event Stage 2: KSP Solve only
>> SFPack              8140 1.0 7.4247e-02 4.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> SFUnpack            8140 1.0 1.2905e-02 5.2 5.50e+0637.9 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 1267207
>> MatMult             5500 1.0 2.9994e+01 1.2 3.98e+10 1.1 2.0e+09 6.1e+03 0.0e+00  1 76 68 62  0  70 92 78 98  0 40747181
>> MatMultAdd          1320 1.0 6.2192e+00 2.7 7.97e+08 1.2 2.8e+08 4.6e+02 0.0e+00  0  2 10  1  0  14  2 11  1  0 3868976
>> MatMultTranspose    1320 1.0 4.0304e+00 1.7 8.00e+08 1.2 2.8e+08 4.6e+02 0.0e+00  0  2 10  1  0   7  2 11  1  0 5974153
>> MatSolve             220 0.0 6.7366e-03 0.0 7.41e+06 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1100
>> MatLUFactorSym         1 1.0 5.8691e-0435.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> MatLUFactorNum         1 1.0 1.5955e-03756.2 1.46e+06 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   913
>> MatResidual         1320 1.0 6.4920e+00 1.3 8.27e+09 1.2 4.4e+08 5.5e+03 0.0e+00  0 15 15 13  0  14 19 18 20  0 38146350
>> MatGetRowIJ            1 0.0 2.7820e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> MatGetOrdering         1 0.0 9.6940e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> VecTDot              440 1.0 4.6162e+00 6.9 2.31e+08 1.0 0.0e+00 0.0e+00 4.4e+02  0  0  0  0 24   5  1  0  0 66 1635124
>> VecNorm              230 1.0 3.9605e-02 1.6 1.21e+08 1.0 0.0e+00 0.0e+00 2.3e+02  0  0  0  0 13   0  0  0  0 34 99622387
>> VecCopy             3980 1.0 5.4166e-01 4.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> VecSet              4640 1.0 1.4216e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> VecAXPY              440 1.0 4.2829e-02 1.3 2.31e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 176236363
>> VecAYPX             8130 1.0 7.3998e-01 1.2 5.78e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   2  1  0  0  0 25489392
>> VecAXPBYCZ          2640 1.0 3.9974e-01 1.5 5.85e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   1  1  0  0  0 47716315
>> VecPointwiseMult    5280 1.0 5.9845e-01 1.5 2.34e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  1  0  0  0 12748927
>> VecScatterBegin     8140 1.0 4.9231e-01 5.9 0.00e+00 0.0 2.5e+09 4.9e+03 0.0e+00  0  0 87 64  0   1  0100100  0     0
>> VecScatterEnd       8140 1.0 1.0172e+01 3.6 5.50e+0637.9 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0  13  0  0  0  0  1608
>> KSPSetUp               1 1.0 9.5996e-07 3.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>> KSPSolve              10 1.0 3.9685e+01 1.0 4.33e+10 1.1 2.5e+09 4.9e+03 6.7e+02  1 83 87 64 37 100100100100100 33637495
>> PCSetUp                1 1.0 2.4149e-0318.1 1.46e+06 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   603
>> PCSetUpOnBlocks      220 1.0 2.6945e-03 8.9 1.46e+06 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   540
>> PCApply              220 1.0 3.2921e+01 1.1 3.57e+10 1.2 2.3e+09 4.3e+03 0.0e+00  1 67 81 53  0  81 80 93 82  0 32595360
>> Memory usage is given in bytes:
>> Object Type          Creations   Destructions     Memory  Descendants' Mem.
>> Reports information only for process 0.
>>            Container   112            112        69888     0.
>>                 SNES     1              1         1532     0.
>>               DMSNES     1              1          720     0.
>>     Distributed Mesh   449            449     30060888     0.
>>             DM Label   790            790       549840     0.
>>           Quadrature   579            579       379824     0.
>>            Index Set 100215          100210    361926232     0.
>>    IS L to G Mapping     8             13      4356552     0.
>>              Section   771            771       598296     0.
>>    Star Forest Graph   897            897      1053640     0.
>>      Discrete System   521            521       533512     0.
>>     GraphPartitioner   118            118        91568     0.
>>               Matrix   432            462   2441805304     0.
>>       Matrix Coarsen     6              6         4032     0.
>>               Vector   354            354     65492968     0.
>>         Linear Space     7              7         5208     0.
>>           Dual Space   111            111       113664     0.
>>             FE Space     7              7         5992     0.
>>        Field over DM     6              6         4560     0.
>>        Krylov Solver    21             21        37560     0.
>>      DMKSP interface     1              1          704     0.
>>       Preconditioner    21             21        21632     0.
>>               Viewer     2              1          896     0.
>>          PetscRandom    12             12         8520     0.
>>            Index Set    10             15     85367336     0.
>>    IS L to G Mapping     5              0            0     0.
>>    Star Forest Graph     5              5         6600     0.
>>               Matrix    50             20     73134024     0.
>>               Vector    28             28      6235096     0.
>>            Index Set     5              5         8296     0.
>>               Matrix     1              1       273856     0.
>> Average time to get PetscTime(): 6.40051e-08
>> Average time for MPI_Barrier(): 8.506e-06
>> Average time for zero size MPI_Send(): 6.6027e-06
>> #PETSc Option Table entries:
>> -benchmark_it 10
>> -dm_distribute
>> -dm_plex_box_dim 3
>> -dm_plex_box_faces 32,32,32
>> -dm_plex_box_lower 0,0,0
>> -dm_plex_box_simplex 0
>> -dm_plex_box_upper 1,1,1
>> -dm_refine 5
>> -ksp_converged_reason
>> -ksp_max_it 150
>> -ksp_norm_type unpreconditioned
>> -ksp_rtol 1.e-12
>> -ksp_type cg
>> -log_view
>> -matptap_via scalable
>> -mg_levels_esteig_ksp_max_it 5
>> -mg_levels_esteig_ksp_type cg
>> -mg_levels_ksp_max_it 2
>> -mg_levels_ksp_type chebyshev
>> -mg_levels_pc_type jacobi
>> -pc_gamg_agg_nsmooths 1
>> -pc_gamg_coarse_eq_limit 2000
>> -pc_gamg_coarse_grid_layout_type spread
>> -pc_gamg_esteig_ksp_max_it 5
>> -pc_gamg_esteig_ksp_type cg
>> -pc_gamg_process_eq_limit 500
>> -pc_gamg_repartition false
>> -pc_gamg_reuse_interpolation true
>> -pc_gamg_square_graph 1
>> -pc_gamg_threshold 0.01
>> -pc_gamg_threshold_scale .5
>> -pc_gamg_type agg
>> -pc_type gamg
>> -petscpartitioner_simple_node_grid 8,8,8
>> -petscpartitioner_simple_process_grid 4,4,4
>> -petscpartitioner_type simple
>> -potential_petscspace_degree 2
>> -snes_converged_reason
>> -snes_max_it 1
>> -snes_monitor
>> -snes_rtol 1.e-8
>> -snes_type ksponly
>> #End of PETSc Option Table entries
>> Compiled without FORTRAN kernels
>> Compiled with 64 bit PetscInt
>> Compiled with full precision matrices (default)
>> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 8
>> Configure options: CC=mpifccpx CXX=mpiFCCpx CFLAGS="-L /opt/FJSVxtclanga/tcsds-1.2.29/lib64 -lfjlapack" CXXFLAGS="-L /opt/FJSVxtclanga/tcsds-1.2.29/lib64 -lfjlapack" COPTFLAGS=-Kfast CXXOPTFLAGS=-Kfast --with-fc=0 --package-prefix-hash=/home/ra010009/a04199/petsc-hash-pkgs --with-batch=1 --with-shared-libraries=yes --with-debugging=no --with-64-bit-indices=1 PETSC_ARCH=arch-fugaku-fujitsu
>> Libraries compiled on 2021-02-12 02:27:41 on fn01sv08
>> Machine characteristics: Linux-3.10.0-957.27.2.el7.x86_64-x86_64-with-redhat-7.6-Maipo
>> Using PETSc directory: /home/ra010009/a04199/petsc
>> Using PETSc arch:
>> Using C compiler: mpifccpx -L /opt/FJSVxtclanga/tcsds-1.2.29/lib64 -lfjlapack -fPIC -Kfast
>> Using include paths: -I/home/ra010009/a04199/petsc/include -I/home/ra010009/a04199/petsc/arch-fugaku-fujitsu/include
>> Using C linker: mpifccpx
>> Using libraries: -Wl,-rpath,/home/ra010009/a04199/petsc/lib -L/home/ra010009/a04199/petsc/lib -lpetsc -Wl,-rpath,/opt/FJSVxos/devkit/aarch64/lib/gcc/aarch64-linux-gnu/8 -L/opt/FJSVxos/devkit/aarch64/lib/gcc/aarch64-linux-gnu/8 -Wl,-rpath,/opt/FJSVxtclanga/tcsds-1.2.29/lib64 -L/opt/FJSVxtclanga/tcsds-1.2.29/lib64 -Wl,-rpath,/opt/FJSVxtclanga/.common/MELI022/lib64 -L/opt/FJSVxtclanga/.common/MELI022/lib64 -Wl,-rpath,/opt/FJSVxos/devkit/aarch64/aarch64-linux-gnu/lib64 -L/opt/FJSVxos/devkit/aarch64/aarch64-linux-gnu/lib64 -Wl,-rpath,/opt/FJSVxos/devkit/aarch64/rfs/usr/lib64 -L/opt/FJSVxos/devkit/aarch64/rfs/usr/lib64 -Wl,-rpath,/opt/FJSVxos/devkit/aarch64/rfs/opt/FJSVxos/mmm/lib64 -L/opt/FJSVxos/devkit/aarch64/rfs/opt/FJSVxos/mmm/lib64 -Wl,-rpath,/opt/FJSVxtclanga/tcsds-1.2.29/lib64/nofjobj -L/opt/FJSVxtclanga/tcsds-1.2.29/lib64/nofjobj -lX11 -lfjprofmpi -lfjlapack -ldl -lmpi_cxx -lmpi -lfjstring_internal -lfj90i -lfj90fmt_sve -lfj90f -lfjsrcinfo -lfjcrt -lfjprofcore -lfjprofomp -lfjc++ -lfjc++abi -lfjdemgl -lmpg -lm -lrt -lpthread -lelf -lz -lgcc_s -ldl
