[petsc-users] DMPlex in Firedrake: scaling of mesh distribution
Stefano Zampini
stefano.zampini at gmail.com
Sun Mar 7 14:27:24 CST 2021
Being an MPI issue, you should run with -log_sync
From your log the problem seems with SFSetup that is called many times (62), with timings associated mostly to the SF revealing ranks phase.
DMPlex abuses of the embedded SF, that can be optimized further I presume. It should run (someone has to write the code) a cheaper operation, since the communication graph of the embedded SF is a subgraph of the original .
> On Mar 7, 2021, at 10:01 PM, Barry Smith <bsmith at petsc.dev> wrote:
> Mark,
> Thanks for the numbers.
> Extremely problematic. DMPlexDistribute takes 88 percent of the total run time, SFBcastOpEnd takes 80 percent.
> Probably Matt is right, PetscSF is flooding the network which it cannot handle. IMHO fixing PetscSF would be a far better route than writing all kinds of fancy DMPLEX hierarchical distributors. PetscSF needs to detect that it is sending too many messages together and do the messaging in appropriate waves; at the moment PetscSF is as dumb as stone it just shoves everything out as fast as it can. Junchao needs access to this machine. If everything in PETSc will depend on PetscSF then it simply has to scale on systems where you cannot just flood the network with MPI.
> Barry
> Mesh Partition 1 1.0 5.0133e+02 1.0 0.00e+00 0.0 1.3e+05 2.7e+02 6.0e+00 15 0 0 0 0 15 0 0 0 1 0
> Mesh Migration 1 1.0 1.5494e+03 1.0 0.00e+00 0.0 7.3e+05 1.9e+02 2.4e+01 45 0 0 0 1 46 0 0 0 2 0
> DMPlexPartStrtSF 1 1.0 4.9474e+023520.8 0.00e+00 0.0 3.3e+04 4.3e+00.0e+00 14 0 0 0 0 15 0 0 0 0 0
> DMPlexPointSF 1 1.0 9.8750e+021264.8 0.00e+00 0.0 6.6e+04 5.4e+00.0e+00 28 0 0 0 0 29 0 0 0 0 0
> DMPlexDistribute 1 1.0 3.0000e+03 1.5 0.00e+00 0.0 9.3e+05 2.3e+02 3.0e+01 88 0 0 0 2 90 0 0 0 3 0
> DMPlexDistCones 1 1.0 1.0688e+03 2.6 0.00e+00 0.0 1.8e+05 3.1e+02 1.0e+00 31 0 0 0 0 31 0 0 0 0 0
> DMPlexDistLabels 1 1.0 2.9172e+02 1.0 0.00e+00 0.0 3.1e+05 1.9e+02 2.1e+01 9 0 0 0 1 9 0 0 0 2 0
> DMPlexDistField 1 1.0 1.8688e+02 1.2 0.00e+00 0.0 2.1e+05 9.3e+01 1.0e+00 5 0 0 0 0 5 0 0 0 0 0
> SFSetUp 62 1.0 7.3283e+0213.6 0.00e+00 0.0 2.0e+07 2.7e+04 0.0e+00 5 0 1 3 0 5 0 6 9 0 0
> SFBcastOpBegin 107 1.0 1.5770e+00452.5 0.00e+00 0.0 2.1e+07 1.8e+04 0.0e+00 0 0 1 2 0 0 0 6 6 0 0
> SFBcastOpEnd 107 1.0 2.9430e+03 4.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 80 0 0 0 0 82 0 0 0 0 0
> SFDistSection 9 1.0 4.4325e+02 1.5 0.00e+00 0.0 2.8e+06 1.1e+04 9.0e+00 11 0 0 0 0 11 0 1 1 1 0
> SFSectionSF 11 1.0 2.3898e+02 4.7 0.00e+00 0.0 9.2e+05 1.7e+05 0.0e+00 5 0 0 1 0 5 0 0 2 0 0
>> On Mar 7, 2021, at 7:35 AM, Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>> And this data puts one cell per process, distributes, and then refines 5 (or 2,3,4 in plot) times.
>> On Sun, Mar 7, 2021 at 8:27 AM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>> FWIW, Here is the output from ex13 on 32K processes (8K Fugaku nodes/sockets, 4 MPI/node, which seems recommended) with 128^3 vertex mesh (64^3 Q2 3D Laplacian).
>> Almost an hour.
>> Attached is solver scaling.
>> 0 SNES Function norm 3.658334849208e+00
>> Linear solve converged due to CONVERGED_RTOL iterations 22
>> 1 SNES Function norm 1.609000373074e-12
>> Nonlinear solve converged due to CONVERGED_ITS iterations 1
>> *** WIDEN YOUR WINDOW TO 120 CHARACTERS. Use 'enscript -r -fCourier9' to print this document ***
>> ---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
>> ../ex13 on a named i07-4008c with 32768 processors, by a04199 Fri Feb 12 23:27:13 2021
>> Using Petsc Development GIT revision: v3.14.4-579-g4cb72fa GIT Date: 2021-02-05 15:19:40 +0000
>> Max Max/Min Avg Total
>> Time (sec): 3.373e+03 1.000 3.373e+03
>> Objects: 1.055e+05 14.797 7.144e+03
>> Flop: 5.376e+10 1.176 4.885e+10 1.601e+15
>> Flop/sec: 1.594e+07 1.176 1.448e+07 4.745e+11
>> MPI Messages: 6.048e+05 30.010 8.833e+04 2.894e+09
>> MPI Message Lengths: 1.127e+09 4.132 6.660e+03 1.928e+13
>> MPI Reductions: 1.824e+03 1.000
>> Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
>> e.g., VecAXPY() for real vectors of length N --> 2N flop
>> and VecAXPY() for complex vectors of length N --> 8N flop
>> Summary of Stages: ----- Time ------ ----- Flop ------ --- Messages --- -- Message Lengths -- -- Reductions --
>> Avg %Total Avg %Total Count %Total Avg %Total Count %Total
>> 0: Main Stage: 3.2903e+03 97.5% 2.4753e+14 15.5% 3.538e+08 12.2% 1.779e+04 32.7% 9.870e+02 54.1%
>> 1: PCSetUp: 4.3062e+01 1.3% 1.8160e+13 1.1% 1.902e+07 0.7% 3.714e+04 3.7% 1.590e+02 8.7%
>> 2: KSP Solve only: 3.9685e+01 1.2% 1.3349e+15 83.4% 2.522e+09 87.1% 4.868e+03 63.7% 6.700e+02 36.7%
>> See the 'Profiling' chapter of the users' manual for details on interpreting output.
>> Phase summary info:
>> Count: number of times phase was executed
>> Time and Flop: Max - maximum over all processors
>> Ratio - ratio of maximum to minimum over all processors
>> Mess: number of messages sent
>> AvgLen: average message length (bytes)
>> Reduct: number of global reductions
>> Global: entire computation
>> Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
>> %T - percent time in this phase %F - percent flop in this phase
>> %M - percent messages in this phase %L - percent message lengths in this phase
>> %R - percent reductions in this phase
>> Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over all processors)
>> Event Count Time (sec) Flop --- Global --- --- Stage ---- Total
>> Max Ratio Max Ratio Max Ratio Mess AvgLen Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
>> --- Event Stage 0: Main Stage
>> PetscBarrier 5 1.0 1.9907e+00 2.2 0.00e+00 0.0 3.8e+06 7.7e+01 2.0e+01 0 0 0 0 1 0 0 1 0 2 0
>> BuildTwoSided 62 1.0 7.3272e+0214.1 0.00e+00 0.0 6.7e+06 8.0e+00 0.0e+00 5 0 0 0 0 5 0 2 0 0 0
>> BuildTwoSidedF 59 1.0 3.1132e+01 7.4 0.00e+00 0.0 4.8e+06 2.5e+05 0.0e+00 0 0 0 6 0 0 0 1 19 0 0
>> SNESSolve 1 1.0 1.7468e+02 1.0 7.83e+09 1.3 3.4e+08 1.3e+04 8.8e+02 5 13 12 23 48 5 85 96 70 89 1205779
>> SNESSetUp 1 1.0 2.4195e+01 1.0 0.00e+00 0.0 3.7e+06 3.7e+05 1.3e+01 1 0 0 7 1 1 0 1 22 1 0
>> SNESFunctionEval 3 1.0 1.1359e+01 1.2 1.17e+09 1.0 1.6e+06 1.4e+04 2.0e+00 0 2 0 0 0 0 15 0 0 0 3344744
>> SNESJacobianEval 2 1.0 1.6829e+02 1.0 1.52e+09 1.0 1.1e+06 8.3e+05 0.0e+00 5 3 0 5 0 5 20 0 14 0 293588
>> DMCreateMat 1 1.0 2.4107e+01 1.0 0.00e+00 0.0 3.7e+06 3.7e+05 1.3e+01 1 0 0 7 1 1 0 1 22 1 0
>> DMPlexPartSelf 1 1.0 1.1498e+002367.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> DMPlexPartLblInv 1 1.0 3.6698e+00 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> DMPlexPartLblSF 1 1.0 2.8522e-01 1.7 0.00e+00 0.0 4.9e+04 1.5e+02 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> DMPlexPartStrtSF 1 1.0 4.9474e+023520.8 0.00e+00 0.0 3.3e+04 4.3e+02 0.0e+00 14 0 0 0 0 15 0 0 0 0 0
>> DMPlexPointSF 1 1.0 9.8750e+021264.8 0.00e+00 0.0 6.6e+04 5.4e+02 0.0e+00 28 0 0 0 0 29 0 0 0 0 0
>> DMPlexInterp 84 1.0 4.3219e-0158.6 0.00e+00 0.0 0.0e+00 0.0e+00 5.0e+00 0 0 0 0 0 0 0 0 0 1 0
>> DMPlexStratify 118 1.0 6.2852e+023280.9 0.00e+00 0.0 0.0e+00 0.0e+00 1.6e+01 1 0 0 0 1 1 0 0 0 2 0
>> DMPlexSymmetrize 118 1.0 6.7634e-02 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> DMPlexPrealloc 1 1.0 2.3741e+01 1.0 0.00e+00 0.0 3.7e+06 3.7e+05 1.1e+01 1 0 0 7 1 1 0 1 22 1 0
>> DMPlexResidualFE 3 1.0 1.0634e+01 1.2 1.16e+09 1.0 0.0e+00 0.0e+00 0.0e+00 0 2 0 0 0 0 15 0 0 0 3569848
>> DMPlexJacobianFE 2 1.0 1.6809e+02 1.0 1.51e+09 1.0 6.5e+05 1.4e+06 0.0e+00 5 3 0 5 0 5 20 0 14 0 293801
>> SFSetGraph 87 1.0 2.7673e-03 3.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> SFReduceBegin 12 1.0 2.4825e-01172.8 0.00e+00 0.0 2.4e+06 2.0e+05 0.0e+00 0 0 0 2 0 0 0 1 8 0 0
>> SFReduceEnd 12 1.0 3.8286e+014865.8 3.74e+04 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 31
>> SFFetchOpBegin 2 1.0 2.4497e-0390.2 0.00e+00 0.0 4.3e+05 3.5e+05 0.0e+00 0 0 0 1 0 0 0 0 2 0 0
>> SFFetchOpEnd 2 1.0 6.1349e-0210.9 0.00e+00 0.0 4.3e+05 3.5e+05 0.0e+00 0 0 0 1 0 0 0 0 2 0 0
>> SFCreateEmbed 3 1.0 3.6800e+013261.5 0.00e+00 0.0 4.7e+05 1.7e+03 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> SFRemoteOff 2 1.0 3.2868e-0143.1 0.00e+00 0.0 8.7e+05 8.2e+03 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> SFPack 1023 1.0 2.5215e-0176.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> SFUnpack 1025 1.0 5.1600e-0216.8 5.62e+0521.3 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 54693
>> MatMult 1549525.4 3.4810e+00 1.3 4.35e+09 1.1 2.2e+08 6.1e+03 0.0e+00 0 8 8 7 0 0 54 62 21 0 38319208
>> MatMultAdd 132 1.0 6.9168e-01 3.0 7.97e+07 1.2 2.8e+07 4.6e+02 0.0e+00 0 0 1 0 0 0 1 8 0 0 3478717
>> MatMultTranspose 132 1.0 5.9967e-01 1.6 8.00e+07 1.2 3.0e+07 4.5e+02 0.0e+00 0 0 1 0 0 0 1 9 0 0 4015214
>> MatSolve 22 0.0 6.8431e-04 0.0 7.41e+05 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 1082
>> MatLUFactorSym 1 1.0 5.9569e-0433.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> MatLUFactorNum 1 1.0 1.6236e-03773.2 1.46e+06 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 897
>> MatConvert 6 1.0 1.4290e-01 1.2 0.00e+00 0.0 3.0e+06 3.7e+03 0.0e+00 0 0 0 0 0 0 0 1 0 0 0
>> MatScale 18 1.0 3.7962e-01 1.3 4.11e+07 1.2 2.0e+06 5.5e+03 0.0e+00 0 0 0 0 0 0 0 1 0 0 3253392
>> MatResidual 132 1.0 6.8256e-01 1.4 8.27e+08 1.2 4.4e+07 5.5e+03 0.0e+00 0 2 2 1 0 0 10 13 4 0 36282014
>> MatAssemblyBegin 244 1.0 3.1181e+01 6.6 0.00e+00 0.0 4.8e+06 2.5e+05 0.0e+00 0 0 0 6 0 0 0 1 19 0 0
>> MatAssemblyEnd 244 1.0 6.3232e+00 1.9 3.17e+06 6.9 0.0e+00 0.0e+00 1.4e+02 0 0 0 0 8 0 0 0 0 15 7655
>> MatGetRowIJ 1 0.0 2.5780e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> MatCreateSubMat 10 1.0 1.5162e+00 1.0 0.00e+00 0.0 1.6e+05 3.4e+05 1.3e+02 0 0 0 0 7 0 0 0 1 13 0
>> MatGetOrdering 1 0.0 1.0899e-04 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> MatCoarsen 6 1.0 3.5837e-01 1.3 0.00e+00 0.0 1.6e+07 1.2e+04 3.9e+01 0 0 1 1 2 0 0 5 3 4 0
>> MatZeroEntries 8 1.0 5.3730e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> MatAXPY 6 1.0 2.6245e-01 1.1 2.66e+05 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 33035
>> MatTranspose 12 1.0 3.0731e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> MatMatMultSym 18 1.0 2.1398e+00 1.4 0.00e+00 0.0 6.1e+06 5.5e+03 4.8e+01 0 0 0 0 3 0 0 2 1 5 0
>> MatMatMultNum 6 1.0 1.1243e+00 1.0 3.76e+07 1.2 2.0e+06 5.5e+03 0.0e+00 0 0 0 0 0 0 0 1 0 0 1001203
>> MatPtAPSymbolic 6 1.0 1.7280e+01 1.0 0.00e+00 0.0 1.2e+07 3.2e+04 4.2e+01 1 0 0 2 2 1 0 3 6 4 0
>> MatPtAPNumeric 6 1.0 1.8047e+01 1.0 1.49e+09 5.1 2.8e+06 1.1e+05 2.4e+01 1 1 0 2 1 1 5 1 5 2 663675
>> MatTrnMatMultSym 1 1.0 3.0221e+01 1.0 0.00e+00 0.0 2.4e+06 5.8e+05 1.1e+01 1 0 0 7 1 1 0 1 22 1 0
>> MatGetLocalMat 19 1.0 1.3904e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> MatGetBrAoCol 18 1.0 1.9926e-01 5.0 0.00e+00 0.0 1.4e+07 2.3e+04 0.0e+00 0 0 0 2 0 0 0 4 5 0 0
>> MatGetSymTrans 2 1.0 1.8996e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> VecTDot 176 1.0 7.0632e-01 4.5 3.48e+07 1.0 0.0e+00 0.0e+00 1.8e+02 0 0 0 0 10 0 0 0 0 18 1608728
>> VecNorm 60 1.0 1.4074e+0012.2 1.58e+07 1.0 0.0e+00 0.0e+00 6.0e+01 0 0 0 0 3 0 0 0 0 6 366467
>> VecCopy 422 1.0 5.1259e-02 3.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> VecSet 653 1.0 2.3974e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> VecAXPY 165 1.0 6.5622e-03 1.3 3.42e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 170485467
>> VecAYPX 861 1.0 7.8529e-02 1.2 6.21e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 1 0 0 0 25785252
>> VecAXPBYCZ 264 1.0 4.1343e-02 1.5 5.85e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 1 0 0 0 46135592
>> VecAssemblyBegin 21 1.0 2.3463e-01 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> VecAssemblyEnd 21 1.0 1.4457e-04 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> VecPointwiseMult 600 1.0 5.7510e-02 1.2 2.66e+07 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 15075754
>> VecScatterBegin 902 1.0 5.1188e-01 1.2 0.00e+00 0.0 2.9e+08 5.3e+03 0.0e+00 0 0 10 8 0 0 0 82 25 0 0
>> VecScatterEnd 902 1.0 1.2143e+00 3.2 5.50e+0537.9 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 1347
>> VecSetRandom 6 1.0 2.6354e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> DualSpaceSetUp 7 1.0 5.3467e-0112.0 4.26e+03 1.0 0.0e+00 0.0e+00 1.3e+01 0 0 0 0 1 0 0 0 0 1 261
>> FESetUp 7 1.0 1.7541e-01128.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> KSPSetUp 15 1.0 2.7470e-01 1.1 2.04e+08 1.2 1.0e+07 5.5e+03 1.3e+02 0 0 0 0 7 0 2 3 1 13 22477233
>> KSPSolve 1 1.0 4.3257e+00 1.0 4.33e+09 1.1 2.5e+08 4.8e+03 6.6e+01 0 8 9 6 4 0 54 72 20 7 30855976
>> PCGAMGGraph_AGG 6 1.0 5.0969e+00 1.0 3.76e+07 1.2 5.1e+06 4.4e+03 4.8e+01 0 0 0 0 3 0 0 1 0 5 220852
>> PCGAMGCoarse_AGG 6 1.0 3.1121e+01 1.0 0.00e+00 0.0 2.5e+07 6.9e+04 5.5e+01 1 0 1 9 3 1 0 7 27 6 0
>> PCGAMGProl_AGG 6 1.0 5.8196e-01 1.0 0.00e+00 0.0 6.6e+06 9.3e+03 7.2e+01 0 0 0 0 4 0 0 2 1 7 0
>> PCGAMGPOpt_AGG 6 1.0 3.2414e+00 1.0 2.42e+08 1.2 2.1e+07 5.3e+03 1.6e+02 0 0 1 1 9 0 3 6 2 17 2256493
>> GAMG: createProl 6 1.0 4.0042e+01 1.0 2.80e+08 1.2 5.8e+07 3.3e+04 3.4e+02 1 1 2 10 19 1 3 16 31 34 210778
>> Graph 12 1.0 5.0926e+00 1.0 3.76e+07 1.2 5.1e+06 4.4e+03 4.8e+01 0 0 0 0 3 0 0 1 0 5 221038
>> MIS/Agg 6 1.0 3.5850e-01 1.3 0.00e+00 0.0 1.6e+07 1.2e+04 3.9e+01 0 0 1 1 2 0 0 5 3 4 0
>> SA: col data 6 1.0 3.0509e-01 1.0 0.00e+00 0.0 5.4e+06 9.2e+03 2.4e+01 0 0 0 0 1 0 0 2 1 2 0
>> SA: frmProl0 6 1.0 2.3467e-01 1.1 0.00e+00 0.0 1.3e+06 9.5e+03 2.4e+01 0 0 0 0 1 0 0 0 0 2 0
>> SA: smooth 6 1.0 2.7855e+00 1.0 4.14e+07 1.2 8.1e+06 5.5e+03 6.3e+01 0 0 0 0 3 0 1 2 1 6 446491
>> GAMG: partLevel 6 1.0 3.7266e+01 1.0 1.49e+09 5.1 1.5e+07 4.9e+04 3.2e+02 1 1 1 4 17 1 5 4 12 32 321395
>> repartition 5 1.0 2.0343e+00 1.1 0.00e+00 0.0 4.0e+05 1.4e+05 2.5e+02 0 0 0 0 14 0 0 0 1 25 0
>> Invert-Sort 5 1.0 1.5021e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+01 0 0 0 0 2 0 0 0 0 3 0
>> Move A 5 1.0 1.1548e+00 1.0 0.00e+00 0.0 1.6e+05 3.4e+05 7.0e+01 0 0 0 0 4 0 0 0 1 7 0
>> Move P 5 1.0 4.2799e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 7.5e+01 0 0 0 0 4 0 0 0 0 8 0
>> PCGAMG Squ l00 1 1.0 3.0221e+01 1.0 0.00e+00 0.0 2.4e+06 5.8e+05 1.1e+01 1 0 0 7 1 1 0 1 22 1 0
>> PCGAMG Gal l00 1 1.0 8.7411e+00 1.0 2.93e+08 1.1 5.4e+06 4.5e+04 1.2e+01 0 1 0 1 1 0 4 2 4 1 1092355
>> PCGAMG Opt l00 1 1.0 1.9734e+00 1.0 3.36e+07 1.1 3.2e+06 1.2e+04 9.0e+00 0 0 0 0 0 0 0 1 1 1 555327
>> PCGAMG Gal l01 1 1.0 1.0153e+00 1.0 3.50e+07 1.4 5.9e+06 3.9e+04 1.2e+01 0 0 0 1 1 0 0 2 4 1 1079887
>> PCGAMG Opt l01 1 1.0 7.4812e-02 1.0 5.35e+05 1.2 3.2e+06 1.1e+03 9.0e+00 0 0 0 0 0 0 0 1 0 1 232542
>> PCGAMG Gal l02 1 1.0 1.8063e+00 1.0 7.43e+07 0.0 3.0e+06 5.9e+04 1.2e+01 0 0 0 1 1 0 0 1 3 1 593392
>> PCGAMG Opt l02 1 1.0 1.1580e-01 1.1 6.93e+05 0.0 1.6e+06 1.3e+03 9.0e+00 0 0 0 0 0 0 0 0 0 1 93213
>> PCGAMG Gal l03 1 1.0 6.1075e+00 1.0 2.72e+08 0.0 2.6e+05 9.2e+04 1.1e+01 0 0 0 0 1 0 0 0 0 1 36155
>> PCGAMG Opt l03 1 1.0 8.0836e-02 1.0 1.55e+06 0.0 1.4e+05 1.4e+03 8.0e+00 0 0 0 0 0 0 0 0 0 1 18229
>> PCGAMG Gal l04 1 1.0 1.6203e+01 1.0 9.44e+08 0.0 1.4e+04 3.0e+05 1.1e+01 0 0 0 0 1 0 0 0 0 1 2366
>> PCGAMG Opt l04 1 1.0 1.2663e-01 1.0 2.01e+06 0.0 6.9e+03 2.2e+03 8.0e+00 0 0 0 0 0 0 0 0 0 1 817
>> PCGAMG Gal l05 1 1.0 1.4800e+00 1.0 3.16e+08 0.0 9.0e+01 1.6e+05 1.1e+01 0 0 0 0 1 0 0 0 0 1 796
>> PCGAMG Opt l05 1 1.0 8.1763e-02 1.1 2.50e+06 0.0 4.8e+01 4.6e+03 8.0e+00 0 0 0 0 0 0 0 0 0 1 114
>> PCSetUp 2 1.0 7.7969e+01 1.0 1.97e+09 2.8 8.3e+07 3.3e+04 8.1e+02 2 2 3 14 44 2 11 23 43 82 341051
>> PCSetUpOnBlocks 22 1.0 2.4609e-0317.2 1.46e+06 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 592
>> PCApply 22 1.0 3.6455e+00 1.1 3.57e+09 1.2 2.4e+08 4.3e+03 0.0e+00 0 7 8 5 0 0 43 67 16 0 29434967
>> --- Event Stage 1: PCSetUp
>> BuildTwoSided 4 1.0 1.5980e-01 2.7 0.00e+00 0.0 2.1e+05 8.0e+00 0.0e+00 0 0 0 0 0 0 0 1 0 0 0
>> BuildTwoSidedF 6 1.0 1.3169e+01 5.5 0.00e+00 0.0 1.9e+06 1.9e+05 0.0e+00 0 0 0 2 0 28 0 10 51 0 0
>> SFSetGraph 5 1.0 4.9640e-0519.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> SFSetUp 4 1.0 1.6038e-01 2.3 0.00e+00 0.0 6.4e+05 9.1e+02 0.0e+00 0 0 0 0 0 0 0 3 0 0 0
>> SFPack 30 1.0 3.3376e-04 4.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> SFUnpack 30 1.0 1.2101e-05 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> MatMult 30 1.0 1.5544e-01 1.5 1.87e+08 1.2 1.0e+07 5.5e+03 0.0e+00 0 0 0 0 0 0 31 53 8 0 35930640
>> MatAssemblyBegin 43 1.0 1.3201e+01 4.7 0.00e+00 0.0 1.9e+06 1.9e+05 0.0e+00 0 0 0 2 0 28 0 10 51 0 0
>> MatAssemblyEnd 43 1.0 1.1159e+01 1.0 2.77e+07705.7 0.0e+00 0.0e+00 2.0e+01 0 0 0 0 1 26 0 0 0 13 1036
>> MatZeroEntries 6 1.0 4.7315e-0410.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> MatTranspose 12 1.0 2.5142e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> MatMatMultSym 10 1.0 5.8783e-0117.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> MatPtAPSymbolic 5 1.0 1.4489e+01 1.0 0.00e+00 0.0 6.2e+06 3.6e+04 3.5e+01 0 0 0 1 2 34 0 32 31 22 0
>> MatPtAPNumeric 6 1.0 2.8457e+01 1.0 1.50e+09 5.1 2.7e+06 1.6e+05 2.0e+01 1 1 0 2 1 66 66 14 61 13 421190
>> MatGetLocalMat 6 1.0 9.8574e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> MatGetBrAoCol 6 1.0 3.7669e-01 2.3 0.00e+00 0.0 5.1e+06 3.8e+04 0.0e+00 0 0 0 1 0 0 0 27 28 0 0
>> VecTDot 66 1.0 6.5271e-02 4.1 5.85e+06 1.0 0.0e+00 0.0e+00 6.6e+01 0 0 0 0 4 0 1 0 0 42 2922260
>> VecNorm 36 1.0 1.1226e-02 3.2 3.19e+06 1.0 0.0e+00 0.0e+00 3.6e+01 0 0 0 0 2 0 1 0 0 23 9268067
>> VecCopy 12 1.0 1.2805e-03 3.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> VecSet 11 1.0 6.6620e-05 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> VecAXPY 60 1.0 1.0763e-03 1.5 5.32e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 1 0 0 0 161104914
>> VecAYPX 24 1.0 2.0581e-03 1.3 2.13e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 33701038
>> VecPointwiseMult 36 1.0 3.5709e-03 1.3 1.60e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 14567861
>> VecScatterBegin 30 1.0 2.9079e-03 7.8 0.00e+00 0.0 1.0e+07 5.5e+03 0.0e+00 0 0 0 0 0 0 0 53 8 0 0
>> VecScatterEnd 30 1.0 3.7015e-0263.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> KSPSetUp 7 1.0 2.3165e-01 1.0 2.04e+08 1.2 1.0e+07 5.5e+03 1.0e+02 0 0 0 0 6 1 34 53 8 64 26654598
>> PCGAMG Gal l00 1 1.0 4.7415e+00 1.0 2.94e+08 1.1 1.8e+06 7.8e+04 0.0e+00 0 1 0 1 0 11 53 9 20 0 2015623
>> PCGAMG Gal l01 1 1.0 1.2103e+00 1.0 3.50e+07 1.4 4.8e+06 6.2e+04 1.2e+01 0 0 0 2 1 3 6 25 41 8 905938
>> PCGAMG Gal l02 1 1.0 3.4334e+00 1.0 7.41e+07 0.0 2.2e+06 8.7e+04 1.2e+01 0 0 0 1 1 8 6 11 27 8 312184
>> PCGAMG Gal l03 1 1.0 9.6062e+00 1.0 2.71e+08 0.0 1.9e+05 1.3e+05 1.1e+01 0 0 0 0 1 22 1 1 4 7 22987
>> PCGAMG Gal l04 1 1.0 2.2482e+01 1.0 9.43e+08 0.0 8.7e+03 4.8e+05 1.1e+01 1 0 0 0 1 52 0 0 1 7 1705
>> PCGAMG Gal l05 1 1.0 1.5961e+00 1.1 3.16e+08 0.0 6.8e+01 2.2e+05 1.1e+01 0 0 0 0 1 4 0 0 0 7 738
>> PCSetUp 1 1.0 4.3191e+01 1.0 1.70e+09 3.6 1.9e+07 3.7e+04 1.6e+02 1 1 1 4 9 100100100100100 420463
>> --- Event Stage 2: KSP Solve only
>> SFPack 8140 1.0 7.4247e-02 4.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> SFUnpack 8140 1.0 1.2905e-02 5.2 5.50e+0637.9 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 1267207
>> MatMult 5500 1.0 2.9994e+01 1.2 3.98e+10 1.1 2.0e+09 6.1e+03 0.0e+00 1 76 68 62 0 70 92 78 98 0 40747181
>> MatMultAdd 1320 1.0 6.2192e+00 2.7 7.97e+08 1.2 2.8e+08 4.6e+02 0.0e+00 0 2 10 1 0 14 2 11 1 0 3868976
>> MatMultTranspose 1320 1.0 4.0304e+00 1.7 8.00e+08 1.2 2.8e+08 4.6e+02 0.0e+00 0 2 10 1 0 7 2 11 1 0 5974153
>> MatSolve 220 0.0 6.7366e-03 0.0 7.41e+06 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 1100
>> MatLUFactorSym 1 1.0 5.8691e-0435.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> MatLUFactorNum 1 1.0 1.5955e-03756.2 1.46e+06 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 913
>> MatResidual 1320 1.0 6.4920e+00 1.3 8.27e+09 1.2 4.4e+08 5.5e+03 0.0e+00 0 15 15 13 0 14 19 18 20 0 38146350
>> MatGetRowIJ 1 0.0 2.7820e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> MatGetOrdering 1 0.0 9.6940e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> VecTDot 440 1.0 4.6162e+00 6.9 2.31e+08 1.0 0.0e+00 0.0e+00 4.4e+02 0 0 0 0 24 5 1 0 0 66 1635124
>> VecNorm 230 1.0 3.9605e-02 1.6 1.21e+08 1.0 0.0e+00 0.0e+00 2.3e+02 0 0 0 0 13 0 0 0 0 34 99622387
>> VecCopy 3980 1.0 5.4166e-01 4.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> VecSet 4640 1.0 1.4216e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> VecAXPY 440 1.0 4.2829e-02 1.3 2.31e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 1 0 0 0 176236363
>> VecAYPX 8130 1.0 7.3998e-01 1.2 5.78e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 2 1 0 0 0 25489392
>> VecAXPBYCZ 2640 1.0 3.9974e-01 1.5 5.85e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 1 1 0 0 0 47716315
>> VecPointwiseMult 5280 1.0 5.9845e-01 1.5 2.34e+08 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 1 1 0 0 0 12748927
>> VecScatterBegin 8140 1.0 4.9231e-01 5.9 0.00e+00 0.0 2.5e+09 4.9e+03 0.0e+00 0 0 87 64 0 1 0100100 0 0
>> VecScatterEnd 8140 1.0 1.0172e+01 3.6 5.50e+0637.9 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 13 0 0 0 0 1608
>> KSPSetUp 1 1.0 9.5996e-07 3.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
>> KSPSolve 10 1.0 3.9685e+01 1.0 4.33e+10 1.1 2.5e+09 4.9e+03 6.7e+02 1 83 87 64 37 100100100100100 33637495
>> PCSetUp 1 1.0 2.4149e-0318.1 1.46e+06 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 603
>> PCSetUpOnBlocks 220 1.0 2.6945e-03 8.9 1.46e+06 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 540
>> PCApply 220 1.0 3.2921e+01 1.1 3.57e+10 1.2 2.3e+09 4.3e+03 0.0e+00 1 67 81 53 0 81 80 93 82 0 32595360
>> Memory usage is given in bytes:
>> Object Type Creations Destructions Memory Descendants' Mem.
>> Reports information only for process 0.
>> Container 112 112 69888 0.
>> SNES 1 1 1532 0.
>> DMSNES 1 1 720 0.
>> Distributed Mesh 449 449 30060888 0.
>> DM Label 790 790 549840 0.
>> Quadrature 579 579 379824 0.
>> Index Set 100215 100210 361926232 0.
>> IS L to G Mapping 8 13 4356552 0.
>> Section 771 771 598296 0.
>> Star Forest Graph 897 897 1053640 0.
>> Discrete System 521 521 533512 0.
>> GraphPartitioner 118 118 91568 0.
>> Matrix 432 462 2441805304 0.
>> Matrix Coarsen 6 6 4032 0.
>> Vector 354 354 65492968 0.
>> Linear Space 7 7 5208 0.
>> Dual Space 111 111 113664 0.
>> FE Space 7 7 5992 0.
>> Field over DM 6 6 4560 0.
>> Krylov Solver 21 21 37560 0.
>> DMKSP interface 1 1 704 0.
>> Preconditioner 21 21 21632 0.
>> Viewer 2 1 896 0.
>> PetscRandom 12 12 8520 0.
>> Index Set 10 15 85367336 0.
>> IS L to G Mapping 5 0 0 0.
>> Star Forest Graph 5 5 6600 0.
>> Matrix 50 20 73134024 0.
>> Vector 28 28 6235096 0.
>> Index Set 5 5 8296 0.
>> Matrix 1 1 273856 0.
>> Average time to get PetscTime(): 6.40051e-08
>> Average time for MPI_Barrier(): 8.506e-06
>> Average time for zero size MPI_Send(): 6.6027e-06
>> #PETSc Option Table entries:
>> -benchmark_it 10
>> -dm_distribute
>> -dm_plex_box_dim 3
>> -dm_plex_box_faces 32,32,32
>> -dm_plex_box_lower 0,0,0
>> -dm_plex_box_simplex 0
>> -dm_plex_box_upper 1,1,1
>> -dm_refine 5
>> -ksp_converged_reason
>> -ksp_max_it 150
>> -ksp_norm_type unpreconditioned
>> -ksp_rtol 1.e-12
>> -ksp_type cg
>> -log_view
>> -matptap_via scalable
>> -mg_levels_esteig_ksp_max_it 5
>> -mg_levels_esteig_ksp_type cg
>> -mg_levels_ksp_max_it 2
>> -mg_levels_ksp_type chebyshev
>> -mg_levels_pc_type jacobi
>> -pc_gamg_agg_nsmooths 1
>> -pc_gamg_coarse_eq_limit 2000
>> -pc_gamg_coarse_grid_layout_type spread
>> -pc_gamg_esteig_ksp_max_it 5
>> -pc_gamg_esteig_ksp_type cg
>> -pc_gamg_process_eq_limit 500
>> -pc_gamg_repartition false
>> -pc_gamg_reuse_interpolation true
>> -pc_gamg_square_graph 1
>> -pc_gamg_threshold 0.01
>> -pc_gamg_threshold_scale .5
>> -pc_gamg_type agg
>> -pc_type gamg
>> -petscpartitioner_simple_node_grid 8,8,8
>> -petscpartitioner_simple_process_grid 4,4,4
>> -petscpartitioner_type simple
>> -potential_petscspace_degree 2
>> -snes_converged_reason
>> -snes_max_it 1
>> -snes_monitor
>> -snes_rtol 1.e-8
>> -snes_type ksponly
>> #End of PETSc Option Table entries
>> Compiled without FORTRAN kernels
>> Compiled with 64 bit PetscInt
>> Compiled with full precision matrices (default)
>> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 8
>> Configure options: CC=mpifccpx CXX=mpiFCCpx CFLAGS="-L /opt/FJSVxtclanga/tcsds-1.2.29/lib64 -lfjlapack" CXXFLAGS="-L /opt/FJSVxtclanga/tcsds-1.2.29/lib64 -lfjlapack" COPTFLAGS=-Kfast CXXOPTFLAGS=-Kfast --with-fc=0 --package-prefix-hash=/home/ra010009/a04199/petsc-hash-pkgs --with-batch=1 --with-shared-libraries=yes --with-debugging=no --with-64-bit-indices=1 PETSC_ARCH=arch-fugaku-fujitsu
>> Libraries compiled on 2021-02-12 02:27:41 on fn01sv08
>> Machine characteristics: Linux-3.10.0-957.27.2.el7.x86_64-x86_64-with-redhat-7.6-Maipo
>> Using PETSc directory: /home/ra010009/a04199/petsc
>> Using PETSc arch:
>> Using C compiler: mpifccpx -L /opt/FJSVxtclanga/tcsds-1.2.29/lib64 -lfjlapack -fPIC -Kfast
>> Using include paths: -I/home/ra010009/a04199/petsc/include -I/home/ra010009/a04199/petsc/arch-fugaku-fujitsu/include
>> Using C linker: mpifccpx
>> Using libraries: -Wl,-rpath,/home/ra010009/a04199/petsc/lib -L/home/ra010009/a04199/petsc/lib -lpetsc -Wl,-rpath,/opt/FJSVxos/devkit/aarch64/lib/gcc/aarch64-linux-gnu/8 -L/opt/FJSVxos/devkit/aarch64/lib/gcc/aarch64-linux-gnu/8 -Wl,-rpath,/opt/FJSVxtclanga/tcsds-1.2.29/lib64 -L/opt/FJSVxtclanga/tcsds-1.2.29/lib64 -Wl,-rpath,/opt/FJSVxtclanga/.common/MELI022/lib64 -L/opt/FJSVxtclanga/.common/MELI022/lib64 -Wl,-rpath,/opt/FJSVxos/devkit/aarch64/aarch64-linux-gnu/lib64 -L/opt/FJSVxos/devkit/aarch64/aarch64-linux-gnu/lib64 -Wl,-rpath,/opt/FJSVxos/devkit/aarch64/rfs/usr/lib64 -L/opt/FJSVxos/devkit/aarch64/rfs/usr/lib64 -Wl,-rpath,/opt/FJSVxos/devkit/aarch64/rfs/opt/FJSVxos/mmm/lib64 -L/opt/FJSVxos/devkit/aarch64/rfs/opt/FJSVxos/mmm/lib64 -Wl,-rpath,/opt/FJSVxtclanga/tcsds-1.2.29/lib64/nofjobj -L/opt/FJSVxtclanga/tcsds-1.2.29/lib64/nofjobj -lX11 -lfjprofmpi -lfjlapack -ldl -lmpi_cxx -lmpi -lfjstring_internal -lfj90i -lfj90fmt_sve -lfj90f -lfjsrcinfo -lfjcrt -lfjprofcore -lfjprofomp -lfjc++ -lfjc++abi -lfjdemgl -lmpg -lm -lrt -lpthread -lelf -lz -lgcc_s -ldl
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210307/92cf011c/attachment-0001.html>
