[petsc-users] DMPlex tetrahedra facets orientation
Nicolas Barral
nicolas.barral at math.u-bordeaux.fr
Sun Mar 7 07:51:57 CST 2021
Matt,
Thanks for your answer.
However, DMPlexComputeCellGeometryFVM does not compute what I need
(normals of height 1 entities). I can't find any function doing that, is
there one ?
So far I've been doing it by hand, and after a lot of experimenting the
past weeks, it seems that if I call P0P1P2P3 a tetrahedron and note x
the cross product,
P3P2xP3P1 is the outward normal to face P1P2P3
P0P2xP0P3 " P0P2P3
P3P1xP3P0 " P0P1P3
P0P1xP0P2 " P0P1P2
Have I been lucky but can't expect it to be true ?
(Alternatively, there is a link between the normals and the element
Jacobian, but I don't know the formula and can find them)
Nicolas
On 08/02/2021 15:19, Matthew Knepley wrote:
> On Mon, Feb 8, 2021 at 6:01 AM Nicolas Barral
> <nicolas.barral at math.u-bordeaux.fr
> <mailto:nicolas.barral at math.u-bordeaux.fr>> wrote:
> Hi all,
> Can I make any assumption on the orientation of triangular facets in a
> tetrahedral plex ? I need the inward facet normals. Do I need to use
> DMPlexGetOrientedFace or can I rely on either the tet vertices
> ordering,
> or the faces ordering ? Could DMPlexGetRawFaces_Internal be enough ?
> You can do it by hand, but you have to account for the face orientation
> relative to the cell. That is what
> DMPlexGetOrientedFace() does. I think it would be easier to use the
> function below.
> Alternatively, is there a function that computes the normals - without
> bringing out the big guns ?
> This will compute the normals
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMPLEX/DMPlexComputeCellGeometryFVM.html
> Should not be too heavy weight.
> THanks,
> Matt
> Thanks
> Nicolas
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
