[petsc-users] Loading external array data into PETSc
Thu Mar 4 07:52:30 CST 2021
On Thu, Mar 4, 2021 at 1:10 AM Smit Thijs <thijs.smit at hest.ethz.ch> wrote:
> Hi Matt, Roland and others,
> @ Roland, I can create the Vec in Petsc, but want to load it with external
> data. I can arrange that data in what ever way with Python. It is about two
> vectors, each of length 4.6 x10^6 entries.
> I have created a hdf5 file with Python and try to load it into PETSc which
> gives me some errors. I added the small test script I am using. The error I
> am getting is:
> error: ‘PetscViewerHDF5Open’ was not declared in this scope; did you mean
> ‘PetscViewerVTKOpen’?
> Am I using the wrong header
Did you configure PETSc with HDF5? If so, the configure.log will have an
entry for it at the bottom. If not, reconfigure with it:
  ${PETSC_DIR}/${PETSC_ARCH}/lib/petsc/conf/reconfigure-${PETSC_ARCH}.py
--download-hdf5
or you can use
  --with-hdf5-dir=/path/to/hdf5
if it is already installed.
    Matt
> Best,
> Thijs
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* 03 March 2021 23:02
> *To:* Smit Thijs <thijs.smit at hest.ethz.ch>
> *Cc:* petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] Loading external array data into PETSc
> On Wed, Mar 3, 2021 at 4:23 PM Smit Thijs <thijs.smit at hest.ethz.ch> wrote:
> Hi All,
> I would like to readin a fairly large external vector into PETSc to be
> used further. My idea was to write a hdf5 file using Python with the vector
> data. Then read that hdf5 file into PETSc using PetscViewerHDF5Open and
> VecLoad. Is this the advised way or is there a better alternative to
> achieve the same (getting this external array data into PETSc)?
> I think there are at least two nice ways to do this:
> 1) Use HDF5. Here you have to name your vector to match the HDF5 object
> 2) Use raw binary. This is a specific PETSc format, but it is fast and
> simple.
>   Thanks,
>     Matt
> Best regards,
> Thijs Smit
> PhD Candidate
> ETH Zurich
> Institute for Biomechanics
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210304/841bbf08/attachment.html>
