[petsc-users] [petsc-dev] headsup: switch git default branch from 'master' to 'main'
Wed Mar 3 16:22:29 CST 2021
An update: Looks like we have to do the following in our existing clones:
git remote set-head origin -a
Satish
balay at sb /home/balay/petsc (main=)
$ git gc
fatal: bad object refs/remotes/origin/HEAD
fatal: failed to run repack
$ cat .git/refs/remotes/origin/HEAD
ref: refs/remotes/origin/master
$ git remote set-head origin -a
origin/HEAD set to main
ref: refs/remotes/origin/main
$ git gc --prune=now
Enumerating objects: 942787, done.
Counting objects: 100% (942787/942787), done.
Delta compression using up to 4 threads
Compressing objects: 100% (213109/213109), done.
Writing objects: 100% (942787/942787), done.
Total 942787 (delta 725291), reused 942001 (delta 724664), pack-reused 0
Checking connectivity: 942787, done.
Expanding reachable commits in commit graph: 86669, done.
On Fri, 26 Feb 2021, Satish Balay via petsc-users wrote:
> Update:
> the switch (at gitlab.com/petsc/petsc) is done.
> Please delete your local copy of 'master' branch and start using 'main' branch.
> Satish
> On Tue, 23 Feb 2021, Satish Balay via petsc-dev wrote:
> > All,
> > This is a heads-up, we are to switch the default branch in petsc git
> > repo from 'master' to 'main'
> > [Will plan to do the switch on friday the 26th]
> > We've previously switched 'maint' branch to 'release' before 3.14
> > release - and this change (to 'main') is the next step in this direction.
> > Satish
