[petsc-users] Scatter parallel Vec to sequential Vec on non-zeroth process
Junchao Zhang
junchao.zhang at gmail.com
Wed Jun 30 09:34:38 CDT 2021
OK, then we should optimize this case. VecScatterCreateToZero() uses
MPI_Gather/Gatherv. But in your case, petsc will use individual MPI
send/recvs, though it is possible to use Gather/Gatherv.
I created a follow-up issue https://gitlab.com/petsc/petsc/-/issues/950
Thanks.
--Junchao Zhang
On Wed, Jun 30, 2021 at 9:07 AM Peder Jørgensgaard Olesen <pjool at mek.dtu.dk>
wrote:
> Dear Junchao Zhang
> I'm distributing a set of independent tasks over different processes, so
> I'm afraid sending everything to the zeroth process would rather
> thoroughly defeat the purpose of what I'm doing.
> Med venlig hilsen / Best regards
> Peder
> *Fra:* Junchao Zhang <junchao.zhang at gmail.com>
> *Sendt:* 30. juni 2021 16:00:25
> *Til:* Peder Jørgensgaard Olesen
> *Cc:* Matthew Knepley; petsc-users at mcs.anl.gov
> *Emne:* Re: [petsc-users] Scatter parallel Vec to sequential Vec on
> non-zeroth process
> That should work. But VecScatterCreateToZero() is more efficient. So if
> possible, better refactor your code in such a way.
> --Junchao Zhang
> On Wed, Jun 30, 2021 at 7:13 AM Peder Jørgensgaard Olesen via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Dear Matt
>> Thank you for your reply. I'm guessing that the line
>> if (rank) N = 0;
>> should be changed to something like
>> if (rank != target_rank) N = 0;
>> such that an empty SEQVEC and scatter are created on each rank other than
>> target_rank.
>> Peder
>> *Fra:* Matthew Knepley <knepley at gmail.com>
>> *Sendt:* 30. juni 2021 13:58:49
>> *Cc:* petsc-users at mcs.anl.gov
>> non-zeroth process
>> On Wed, Jun 30, 2021 at 6:49 AM Peder Jørgensgaard Olesen via petsc-users
>> <petsc-users at mcs.anl.gov> wrote:
>>> Hello
>>> I have a parallel vector, and I'd like to copy its data to a sequential
>>> vector located on a given process that is not necessarily the
>>> 0th process, so using VecScatterCreateToZero wouldn't do here.
>>> How might one approach this?
>> The function is very short:
>> https://www.mcs.anl.gov/petsc/petsc-current/src/vec/is/sf/interface/vscat.c.html#VecScatterCreateToZero
>> Just go in and replace '0' by the rank you want.
>> Thanks,
>> Matt
>>> Med venlig hilsen / Best Regards
>>> PhD Student, Turbulence Research Lab
>>> Dept. of Mechanical Engineering
>>> Technical University of Denmark
>>> Koppels Allé
>>> Bygning 403, Rum 105
>>> DK-2800 Kgs. Lyngby
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210630/92248679/attachment-0001.html>
