[petsc-users] Scatter parallel Vec to sequential Vec on non-zeroth process
Junchao Zhang junchao.zhang at gmail.com
Wed Jun 30 09:00:25 CDT 2021
That should work. But VecScatterCreateToZero() is more efficient. So if
possible, better refactor your code in such a way.
--Junchao Zhang
On Wed, Jun 30, 2021 at 7:13 AM Peder Jørgensgaard Olesen via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Dear Matt
> Thank you for your reply. I'm guessing that the line
> if (rank) N = 0;
> should be changed to something like
> if (rank != target_rank) N = 0;
> such that an empty SEQVEC and scatter are created on each rank other than
> target_rank.
> Med venlig hilsen / Best regards
> Peder
> *Fra:* Matthew Knepley <knepley at gmail.com>
> *Sendt:* 30. juni 2021 13:58:49
> *Til:* Peder Jørgensgaard Olesen
> *Cc:* petsc-users at mcs.anl.gov
> *Emne:* Re: [petsc-users] Scatter parallel Vec to sequential Vec on
> non-zeroth process
> On Wed, Jun 30, 2021 at 6:49 AM Peder Jørgensgaard Olesen via petsc-users <
>> Hello
>> I have a parallel vector, and I'd like to copy its data to a sequential
>> vector located on a given process that is not necessarily the
>> 0th process, so using VecScatterCreateToZero wouldn't do here.
>> How might one approach this?
> The function is very short:
> https://www.mcs.anl.gov/petsc/petsc-current/src/vec/is/sf/interface/vscat.c.html#VecScatterCreateToZero
> Just go in and replace '0' by the rank you want.
>   Thanks,
>      Matt
>> Med venlig hilsen / Best Regards
>> PhD Student, Turbulence Research Lab
>> Dept. of Mechanical Engineering
>> Technical University of Denmark
>> Koppels Allé
>> Bygning 403, Rum 105
>> DK-2800 Kgs. Lyngby
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210630/0edb76d6/attachment.html>
