[petsc-users] Scatter parallel Vec to sequential Vec on non-zeroth process
Peder Jørgensgaard Olesen pjool at mek.dtu.dk
Wed Jun 30 07:13:13 CDT 2021
Dear Matt
Thank you for your reply. I'm guessing that the line
if (rank) N = 0;
should be changed to something like
if (rank != target_rank) N = 0;
such that an empty SEQVEC and scatter are created on each rank other than target_rank.
Med venlig hilsen / Best regards
Peder
Fra: Matthew Knepley <knepley at gmail.com>
Sendt: 30. juni 2021 13:58:49
Til: Peder Jørgensgaard Olesen
Cc: petsc-users at mcs.anl.gov
Emne: Re: [petsc-users] Scatter parallel Vec to sequential Vec on non-zeroth process
On Wed, Jun 30, 2021 at 6:49 AM Peder Jørgensgaard Olesen via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hello
I have a parallel vector, and I'd like to copy its data to a sequential vector located on a given process that is not necessarily the 0th process, so using VecScatterCreateToZero wouldn't do here.
How might one approach this?
The function is very short: https://www.mcs.anl.gov/petsc/petsc-current/src/vec/is/sf/interface/vscat.c.html#VecScatterCreateToZero
Just go in and replace '0' by the rank you want.
     Matt
Med venlig hilsen / Best Regards
PhD Student, Turbulence Research Lab
Dept. of Mechanical Engineering
Technical University of Denmark
Koppels Allé
Bygning 403, Rum 105
DK-2800 Kgs. Lyngby
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210630/cb958efc/attachment.html>
