[petsc-users] Any workarounds for TAO in a complex scalar type code?
Lucas Banting bantingl at myumanitoba.ca
Thu Jun 24 14:44:43 CDT 2021
I have a complex valued optimization code that requires non-linear least squares curve fitting at each iteration. I wanted to use Tao to do the non-linear least squares problem, but just discovered that Tao can only be used with real scalar types. Is there any workarounds?
I was wondering if maybe I could somehow use two different Petsc installations at once, or is there any other ways to hack tao into working?
Lucas
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210624/51aaf4c4/attachment.html>
