[petsc-users] flux vector
Tue Jun 15 06:18:04 CDT 2021
On Mon, Jun 14, 2021 at 11:34 PM Adrian Croucher <a.croucher at auckland.ac.nz>
wrote:
> hi
> On 15/06/21 12:21 pm, Matthew Knepley wrote:
> I admit that it is becoming complicated, but this can also be handled.
> The corner case only shows up when we distribute with overlap. Thus we
> could,
> 1) Distribute the mesh without overlap
> 2) Mark the global boundary using the former algorithm
> 3) Distribute overlap = 1 using DMPlexDistributeOverlap().
> DMPlexDistribute() just does these two steps at once if you ask for overlap.
> 4) Use the former algorithm, with the boundary label we just made, to mark
> flux faces.
> That sounds like it might work. Do you think this perhaps slightly simpler
> version might also work?
> 1) distribute mesh without overlap
> 2) label boundary faces using DMPlexMarkBoundaryFaces()
> 3) DMPlexDistributeOverlap()
> 4) Un-label boundary faces with support size > 1 (i.e. the shared faces on
> the non-overlapped mesh- I think) - so the boundary label is now just the
> global boundary
> 5) loop over faces as in my original algorithm, labelling flux faces if
> they are either on the open boundary, or are not on the global boundary
> Unfortunately I can't test this at the moment - it looks like the Fortran
> interface for DMPlexDistributeOverlap() is missing?
Yes, that does sound simpler. I will get the Fotran interface up today. I
did not use the automatic version since we need to check for NULL.
     Matt
> - Adrian
> Dr Adrian Croucher
> Senior Research Fellow
> Department of Engineering Science
> University of Auckland, New Zealand
> email: a.croucher at auckland.ac.nz
> tel: +64 (0)9 923 4611
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210615/70f1b3e9/attachment.html>
