[petsc-users] Change Amat in FormJacobian
Anton Popov popov at uni-mainz.de
Mon Jun 14 10:27:42 CDT 2021
On 14.06.21 15:04, Dave May wrote:
> Hi Anton,
Hi Dave,
> On Mon, 14 Jun 2021 at 14:47, Anton Popov <popov at uni-mainz.de
> <mailto:popov at uni-mainz.de>> wrote:
>     Hi Barry & Matt,
>     thanks for your quick response. These options were exactly what I
>     needed and expected:
>     -pc_mg_galerkin pmat
>     -pc_use_amat false
>     I just assumed that it’s a default behavior of the PC object.
>     So to clarify my case, I don't use nonlinear multigrid. Galerkin
>     is expected to deal with Pmat only, and it's enough if Amat
>     implements a matrix-vector product for the Krylov accelerator.
>     Matt, the reason for switching Amat during the iteration is a
>     quite common Picard-Newton combination. Jacobian matrix gives
>     accurate updates close to the solution, but is rather unstable far
>     form the solution. Picard matrix (approximate Jacobian) is quite
>     the opposite – it’s kind of stable, but slow. So the idea is to
>     begin the iteration with Picard matrix, and switch to the Jacobian
>     later.
>     If the assembled matrices are used, then the standard SNES
>     interface is just perfect. I can decide how to fill the matrices.
>     But I don’t bother with  Jacobian assembly and want to use a
>     built-in MFFD approximation instead. I did quite a few tests
>     previously and figured out that MFFD is practically the same as
>     closed-from matrix-free Jacobian for the later stages of the
>     iteration. The Picard matrix still does a good job as a
>     preconditioner. But it is important to start the iteration with
>     Picard and only change to MFFD later.
>     Is my workaround with the shell matrix acceptable, or there is a
>     better solution?
> Given what you write, it sounds like you already have a good heuristic
> for when to switch from Picard to Newton,
> Hence I think the simplest option is just to use two seperate SNES
> objects - one for performing Picard and one for Newton.
Yes, I considered this option initially. Sometimes it is necessary to
switch back and forth between the methods, so it becomes a bit messy to
organize this in the code.
But maybe if Newton fails after Picard, I should just reduce the time
step and restart, instead of switching back to Picard. Thanks, Dave.
Anton
> The stopping condition for the Picard object would encode your
> heuristic to abort earlier when the solution was deemed sufficiently
> accurate.
> Thanks,
> Dave
>     Thanks,
>     Anton
>     On 13.06.21 20:52, Barry Smith wrote:
>>       Anton,
>>       Though it seems simple, there is some subtly in swapping out
>>     matrices with SNES.
>>       When using multigrid with SNES there are at least five distinct
>>     uses of the Jacobian operator.
>>           * Perform matrix-vector product in line search to check
>>             Wolf sufficient decrease convergence criteria
>>           * Perform the matrix-vector product for the Krylov
>>             accelerator of the system
>>           * Perform smoothing on the finest level of MG
>>           * Perform the matrix-vector product needed on the finest
>>             level of MG to compute the residual that will be
>>             restricted to the coarser level of multigrid
>>           * When using Galerkin products to compute the coarser grid
>>             operator performing the Galerkin matrix triple product
>>     when one swaps out the mat, which of these do they wish to
>>     change? The first two seem to naturally go together as do the
>>     last three. In your case I presume you want to swap for the first
>>     two, but always use pmat for the last three? To achieve this you
>>     will also need -pc_use_amat  false
>>     If you run with -info and -snes_view it will print out some of
>>     the information about which operator it is using for each case,
>>     but probably not all of them.
>>     Note: if the pmat is actually an accurate computation of the
>>     Jacobian then it is likely best not to ever use a matrix-free
>>     product. It is only when pmat is approximated in some specific
>>     way that using the matrix-free product would be useful to insure
>>     the "Newton" method actually computes a Newton step.
>>     Barry
>>>     On Jun 13, 2021, at 11:21 AM, Matthew Knepley <knepley at gmail.com
>>>     <mailto:knepley at gmail.com>> wrote:
>>>     On Sun, Jun 13, 2021 at 10:55 AM Anton Popov <popov at uni-mainz.de
>>>         Hi,
>>>         I want a simple(?) thing. I want to decide and be able to
>>>         assign the
>>>         Jacobian matrix (Amat) on the fly within the FormJacobian
>>>         function (i.e.
>>>         during Newton iteration) to one of the following options:
>>>         1) built-in MFFD approximation
>>>         2) assembled preconditioner matrix (Pmat)
>>>         I have not found this scenario demonstrated in any example,
>>>         therefore
>>>         I’m asking how to do that.
>>>         Currently I do the following:
>>>         1) setup Amat as a shell matrix with a MATOP_MULT operation
>>>         that simply
>>>         retrieves a matrix object form its context and calls MatMult
>>>         on it.
>>>         2) if I need MFFD, I put a matrix generated with
>>>         MatCreateSNESMF in the
>>>         Amat context (of course I also call MatMFFDComputeJacobian
>>>         before that).
>>>         3) if I need Pmat, I simply put Pmat in the Amat context.
>>>         4) call MatAssemblyBegin/End on Amat
>>>         So far so good.
>>>         However, shell Amat and assembled Pmat generate a problem if
>>>         Galerkin
>>>         multigrid is requested as a preconditioner (I just test on 1
>>>         CPU):
>>>         [0]PETSC ERROR: MatPtAP requires A, shell, to be compatible
>>>         with P,
>>>         seqaij (Misses composed function MatPtAP_shell_seqaij_C)
>>>         [0]PETSC ERROR: #1 MatPtAP()
>>>         [0]PETSC ERROR: #2 MatGalerkin()
>>>         [0]PETSC ERROR: #3 PCSetUp_MG()
>>>         [0]PETSC ERROR: #4 PCSetUp()
>>>         [0]PETSC ERROR: #5 KSPSetUp()
>>>         [0]PETSC ERROR: #6 KSPSolve()
>>>         [0]PETSC ERROR: #7 SNESSolve_NEWTONLS()
>>>         [0]PETSC ERROR: #8 SNESSolve()
>>>         It seems like PETSc tries to apply Galerkin coarsening to
>>>         the shell Amat
>>>         matrix instead of the assembled Pmat. Why?
>>>         Pmat is internally generated by SNES using a DMDA attached
>>>         to SNES, so
>>>         it has everything to define Galerkin coarsening. And it
>>>         actually works
>>>         if I just get rid of the shell Amat.
>>>         I can get around this problem by wrapping a PC object in a
>>>         shell matrix
>>>         and pass it as Pmat. This is a rather ugly approach, so I
>>>         wonder how to
>>>         resolve the situation in a better way, if it is possible.
>>>     Hi Anton,
>>>     You are correct that there is no specific test, so I can believe
>>>     that a bug might be lurking here.
>>>     I believe the way it is supposed to work is that you set the
>>>     type of Galerkin coarsening that you
>>>     want
>>>     https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCMGSetGalerkin.html
>>>     So I am thinking you want 'pmat' only, and you would be in
>>>     charge of making the coarse MFFD operator
>>>     and telling PCMG about it. I could imagine that you might want
>>>     us to automatically do that, but we would
>>>     need some way to know that it is MFFD, and with the scheme above
>>>     we do not have that.
>>>     What is the advantage of switching representations during the
>>>     Newton iteration?
>>>       Thanks,
>>>          Matt
>>>         Thanks.
>>>         Anton
>>>     What most experimenters take for granted before they begin their
>>>     experiments is infinitely more interesting than any results to
>>>     which their experiments lead.
>>>     -- Norbert Wiener
>>>     https://www.cse.buffalo.edu/~knepley/
>>>     <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210614/647220e7/attachment-0001.html>
