[petsc-users] Change Amat in FormJacobian
Anton Popov
popov at uni-mainz.de
Mon Jun 14 10:18:22 CDT 2021
On 14.06.21 15:02, Matthew Knepley wrote:
> On Mon, Jun 14, 2021 at 8:45 AM Anton Popov <popov at uni-mainz.de
> <mailto:popov at uni-mainz.de>> wrote:
> Hi Barry & Matt,
> thanks for your quick response. These options were exactly what I
> needed and expected:
> -pc_mg_galerkin pmat
> -pc_use_amat false
> I just assumed that it’s a default behavior of the PC object.
> So to clarify my case, I don't use nonlinear multigrid. Galerkin
> is expected to deal with Pmat only, and it's enough if Amat
> implements a matrix-vector product for the Krylov accelerator.
> Matt, the reason for switching Amat during the iteration is a
> quite common Picard-Newton combination. Jacobian matrix gives
> accurate updates close to the solution, but is rather unstable far
> form the solution. Picard matrix (approximate Jacobian) is quite
> the opposite – it’s kind of stable, but slow. So the idea is to
> begin the iteration with Picard matrix, and switch to the Jacobian
> later.
> If the assembled matrices are used, then the standard SNES
> interface is just perfect. I can decide how to fill the matrices.
> But I don’t bother with Jacobian assembly and want to use a
> built-in MFFD approximation instead. I did quite a few tests
> previously and figured out that MFFD is practically the same as
> closed-from matrix-free Jacobian for the later stages of the
> iteration. The Picard matrix still does a good job as a
> preconditioner. But it is important to start the iteration with
> Picard and only change to MFFD later.
> Is my workaround with the shell matrix acceptable, or there is a
> better solution?
> It is fine. However, I wonder if you have time to try out a slightly
> different solution. I experimented with this, and it worked as well
> for me as switching between
> Picard and Newton. I made a SNESCOMPOSITE with Picard and Newton as
> the two components. I made Newton take a single step, and then
> adjusted the
> Picard steps a little.The additiveoptimal variant always converged for
> me, and took the same or less time. I also used left preconditioning
> of Picard by Newton,
> but that is more involved, and for my simple problem was not a lot
> better. The advantage I see is that both solves are not plain vanilla,
> and you do not have any
> switching logic.
hmmm, this sounds really interesting. I will definitely look into this
possibility. Thanks Matt.
Anton
> Thanks,
> Matt
> Thanks,
> Anton
> On 13.06.21 20:52, Barry Smith wrote:
>> Anton,
>> Though it seems simple, there is some subtly in swapping out
>> matrices with SNES.
>> When using multigrid with SNES there are at least five distinct
>> uses of the Jacobian operator.
>> * Perform matrix-vector product in line search to check
>> Wolf sufficient decrease convergence criteria
>> * Perform the matrix-vector product for the Krylov
>> accelerator of the system
>> * Perform smoothing on the finest level of MG
>> * Perform the matrix-vector product needed on the finest
>> level of MG to compute the residual that will be
>> restricted to the coarser level of multigrid
>> * When using Galerkin products to compute the coarser grid
>> operator performing the Galerkin matrix triple product
>> when one swaps out the mat, which of these do they wish to
>> change? The first two seem to naturally go together as do the
>> last three. In your case I presume you want to swap for the first
>> two, but always use pmat for the last three? To achieve this you
>> will also need -pc_use_amat false
>> If you run with -info and -snes_view it will print out some of
>> the information about which operator it is using for each case,
>> but probably not all of them.
>> Note: if the pmat is actually an accurate computation of the
>> Jacobian then it is likely best not to ever use a matrix-free
>> product. It is only when pmat is approximated in some specific
>> way that using the matrix-free product would be useful to insure
>> the "Newton" method actually computes a Newton step.
>> Barry
>>> On Jun 13, 2021, at 11:21 AM, Matthew Knepley <knepley at gmail.com
>>> <mailto:knepley at gmail.com>> wrote:
>>> On Sun, Jun 13, 2021 at 10:55 AM Anton Popov <popov at uni-mainz.de
>>> Hi,
>>> I want a simple(?) thing. I want to decide and be able to
>>> assign the
>>> Jacobian matrix (Amat) on the fly within the FormJacobian
>>> function (i.e.
>>> during Newton iteration) to one of the following options:
>>> 1) built-in MFFD approximation
>>> 2) assembled preconditioner matrix (Pmat)
>>> I have not found this scenario demonstrated in any example,
>>> therefore
>>> I’m asking how to do that.
>>> Currently I do the following:
>>> 1) setup Amat as a shell matrix with a MATOP_MULT operation
>>> that simply
>>> retrieves a matrix object form its context and calls MatMult
>>> on it.
>>> 2) if I need MFFD, I put a matrix generated with
>>> MatCreateSNESMF in the
>>> Amat context (of course I also call MatMFFDComputeJacobian
>>> before that).
>>> 3) if I need Pmat, I simply put Pmat in the Amat context.
>>> 4) call MatAssemblyBegin/End on Amat
>>> So far so good.
>>> However, shell Amat and assembled Pmat generate a problem if
>>> Galerkin
>>> multigrid is requested as a preconditioner (I just test on 1
>>> CPU):
>>> [0]PETSC ERROR: MatPtAP requires A, shell, to be compatible
>>> with P,
>>> seqaij (Misses composed function MatPtAP_shell_seqaij_C)
>>> [0]PETSC ERROR: #1 MatPtAP()
>>> [0]PETSC ERROR: #2 MatGalerkin()
>>> [0]PETSC ERROR: #3 PCSetUp_MG()
>>> [0]PETSC ERROR: #4 PCSetUp()
>>> [0]PETSC ERROR: #5 KSPSetUp()
>>> [0]PETSC ERROR: #6 KSPSolve()
>>> [0]PETSC ERROR: #7 SNESSolve_NEWTONLS()
>>> [0]PETSC ERROR: #8 SNESSolve()
>>> It seems like PETSc tries to apply Galerkin coarsening to
>>> the shell Amat
>>> matrix instead of the assembled Pmat. Why?
>>> Pmat is internally generated by SNES using a DMDA attached
>>> to SNES, so
>>> it has everything to define Galerkin coarsening. And it
>>> actually works
>>> if I just get rid of the shell Amat.
>>> I can get around this problem by wrapping a PC object in a
>>> shell matrix
>>> and pass it as Pmat. This is a rather ugly approach, so I
>>> wonder how to
>>> resolve the situation in a better way, if it is possible.
>>> Hi Anton,
>>> You are correct that there is no specific test, so I can believe
>>> that a bug might be lurking here.
>>> I believe the way it is supposed to work is that you set the
>>> type of Galerkin coarsening that you
>>> want
>>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCMGSetGalerkin.html
>>> So I am thinking you want 'pmat' only, and you would be in
>>> charge of making the coarse MFFD operator
>>> and telling PCMG about it. I could imagine that you might want
>>> us to automatically do that, but we would
>>> need some way to know that it is MFFD, and with the scheme above
>>> we do not have that.
>>> What is the advantage of switching representations during the
>>> Newton iteration?
>>> Thanks,
>>> Matt
>>> Thanks.
>>> Anton
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to
>>> which their experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210614/77297cd9/attachment.html>
