[petsc-users] Copy stiffness matrix to jacobian matrix in form jacobian
Matthew Knepley
knepley at gmail.com
Mon Jun 14 07:27:13 CDT 2021
On Mon, Jun 14, 2021 at 7:21 AM Kaushik Vijaykumar <kaushikv318 at gmail.com>
wrote:
> Thanks for the suggestion Barry, I did do that by setting it in multiple
> ways first by setting
> Formfunction(snes,Vec x,Vec F,void* ctx)
> ierr = SNESGetJacobian(snes,&jac,NULL,NULL,NULL);CHKERRQ(ierr);
> ierr = MatZeroEntries(jac);CHKERRQ(ierr);
> ierr = MatGetOwnershipRange(jac,&istart,&iend);
> for(i=istart;i<iend;i++)
> val = 0.0;
> ierr = MatSetValue(jac, i, i, val, ADD_VALUES);CHKERRQ(ierr);
> ierr = MatAssemblyBegin(jac,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> ierr = MatAssemblyEnd(jac,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> I get the same error as before for a single processor run.
> "[0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Object is in wrong state
> [0]PETSC ERROR: Matrix is missing diagonal entry 0"
It must be that the matrix you are setting the diagonal for is not the same
matrix as referenced in the error message.
Matt
> Thanks
> Kaushik
> On Fri, Jun 11, 2021 at 11:33 AM Barry Smith <bsmith at petsc.dev> wrote:
>> When I execute this I get a Petsc error, object in wrong state missing
>> diagonal entry.
>> When do you get this error? During a TSSolve? While KSP is building a
>> preconditioner.
>> Some parts of PETSc require that you put entries (even if they are
>> zero) on all diagonal entries in the Jacobian. So likely you need to just
>> make sure that your populate jac routine puts/adds 0 to all diagonal
>> entries.
>> Barry
>> On Jun 11, 2021, at 10:16 AM, Kaushik Vijaykumar <kaushikv318 at gmail.com>
>> wrote:
>> Thanks Barry for your comments. Based on your suggestion I tried the
>> following
>> Main()
>> ierr = SNESSetFunction(snes,r1,FormFunction,&this_ctx);CHKERRQ(ierr);
>> ierr =
>> SNESSetJacobian(snes,jac,NULL,FormJacobian,&this_ctx);CHKERRQ(ierr);
>> ierr = SNESSetFromOptions(snes);CHKERRQ(ierr);
>> ierr = SNESSolve(snes, NULL, u);CHKERRQ(ierr);
>> In formfunction I populate the jacobian "*jac*"
>> ierr = SNESGetJacobian(snes,&jac,Null,NULL,NULL);CHKERRQ(ierr);
>> // "*Populate jac*"
>> FormJacobian(SNES snes,Vec x,Mat jac,Mat B,void *ctx)
>> ierr = MatAssemblyBegin(B,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>> ierr = MatAssemblyEnd(B,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>> diagonal entry.
>> I am not sure what I am missing here?
>> Thanks
>> Kaushik
>> On Thu, Jun 10, 2021 at 6:37 PM Barry Smith <bsmith at petsc.dev> wrote:
>>> > On Jun 10, 2021, at 3:29 PM, Kaushik Vijaykumar <kaushikv318 at gmail.com>
>>> wrote:
>>> > Hi everyone,
>>> > I am trying to copy the stiffness matrix that I generated in form
>>> function to the jacobian matrix jac in form jacobian. The piece of code for
>>> that:
>>> If you have created jac and B in your main program and passed them
>>> with SNESSetJacobian() then you should be able to just use
>>> > ierr = MatCopy(ptr->K,jac,SAME_NONZERO_PATTERN);CHKERRQ(ierr);
>>> Generally jac and B are the same matrix so you don't need the second
>>> copy.
>>> > ierr = MatCopy(ptr->K,B,SAME_NONZERO_PATTERN);CHKERRQ(ierr);
>>> If they are sometimes the same and sometime not you can do
>>> if (jac != B) {ierr =
>>> MatCopy(ptr->K,B,SAME_NONZERO_PATTERN);CHKERRQ(ierr); }
>>> The following won't work because you are creating new local matrices
>>> in your form jacobian that don't exist outside of that routine.
>>> > ierr = MatDuplicate(ptr->K,MAT_COPY_VALUES,&jac);CHKERRQ(ierr);
>>> > ierr = MatDuplicate(ptr->K,MAT_COPY_VALUES,&B);CHKERRQ(ierr);
>>> If the matrix you are creating in form function is the Jacobian then
>>> you don't need to use the memory and time to make copies. You can just form
>>> the matrix directly into the Jacobian you will use for SNES. You can obtain
>>> this with a call
>>> in your form function and just put the matrix values directly into jac.
>>> Then your form Jacobian does not need to do anything but return since the
>>> jac already contains the Jacobian.
>>> On the off-change you are using the iteration A(x^n) x^{n+1} = b(x^n}
>>> and not using Newtons' method (which is why you compute A in form function,
>>> then you might be better off using SNESSetPicard() instead of
>>> SNESSetFunction(), SNESSetJacobian().
>>> > Thanks
>>> > Kaushik
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210614/8c4a2a94/attachment.html>
