[petsc-users] flux vector
Lawrence Mitchell
wence at gmx.li
Fri Jun 11 06:37:55 CDT 2021
> On 11 Jun 2021, at 11:29, Mark Adams <mfadams at lbl.gov> wrote:
> This is a Matt question, but You can set a "Boundary" label (https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMPLEX/DMPlexMarkBoundaryFaces.html) and that will label boundaries.
> Next you want the dual of that ...
Note that if you want this to be the _global_ boundary you must call it before mesh distribution.
You need to reduce the support size over the point SF, where you would make a contribution to the count only if the cell is in the owned part of your local cells.
So (pseudocode):
sf = DMGetPointSF(dm);
// since you're only going to reduce over facet points you could create an embedded sf here, but meh.
nroots, nleaves, ilocal, iremote = SFGetGraph(sf);
cstart, cend = DMPlexGetChart(dm);
count = PetscCalloc(nroots); // nroots should be == cend - cstart
fstart, fend = DMPlexGetDepthStratum(dm, 1); // codim 1 entities
for f = fstart; f < fend; f++ {
supportsize = DMPlexGetSupportSize(dm, f);
support = DMPlexGetSupport(dm, f);
for c in support {
if (c is owned) { // c not in ilocal
count[f]++;
gcount = PetscMalloc(nroots);
PetscSFReduceBegin(sf, count, gcount, MPI_SUM);
PetscSFReduceEnd(sf, count, gcount, MPI_SUM);
PetscSFBcastBegin(sf, gcount, count, MPI_REPLACE);
PetscSFBcastEnd(sf, gcount, count, MPI_REPLACE);
interior_faces = DMLabelCreate("interior_faces")
if count[f] == 2 {
DMLabelSetValue(interior_faces, f, 1);
(Obviously) untested.
Lawrence
