[petsc-users] petsc-users
Wed Jun 9 09:09:22 CDT 2021
I see you are already subscribed to the list now.
The list subscribe instructions are https://www.mcs.anl.gov/petsc/miscellaneous/mailing-lists.html
However one can also post to the list without subscribing [but this requires a one time approval by list-admin]
Satish
On Wed, 9 Jun 2021, VIGNOLLET Julien (SAFRAN) wrote:
> Hi there,
> I would like to be able to post questions to the petsc-users community, would you be able to add me to the list?
> Best regards,
> _________________________________
> Julien Vignollet
> Research Engineer
> Safran Tech
> M&S | Computational Solid Mechanics (CSM)
> T +33 (0)1 61 31 88 07
> Rue des Jeunes Bois
> Châteaufort CS08112
> 78772 Magny-Les-Hameaux Cedex
> France
> www.safran-group.com<http://www.safran-group.com>
> ____________________________________
> " Ce courriel et les documents qui lui sont joints peuvent contenir des informations confidentielles, être soumis aux règlementations relatives au contrôle des exportations ou ayant un caractère privé. S'ils ne vous sont pas destinés, nous vous signalons qu'il est strictement interdit de les divulguer, de les reproduire ou d'en utiliser de quelque manière que ce soit le contenu. Toute exportation ou réexportation non autorisée est interdite Si ce message vous a été transmis par erreur, merci d'en informer l'expéditeur et de supprimer immédiatement de votre système informatique ce courriel ainsi que tous les documents qui y sont attachés."
> " This e-mail and any attached documents may contain confidential or proprietary information and may be subject to export control laws and regulations. If you are not the intended recipient, you are notified that any dissemination, copying of this e-mail and any attachments thereto or use of their contents by any means whatsoever is strictly prohibited. Unauthorized export or re-export is prohibited. If you have received this e-mail in error, please advise the sender immediately and delete this e-mail and all attached documents from your computer system."
