[petsc-users] SLEPc: HDF5 support for SVD/EPSValuesView?
Peder Jørgensgaard Olesen
pjool at mek.dtu.dk
Fri Jun 4 09:28:56 CDT 2021
What Matt suggests could perhaps be used as a workaround, though it appears neither elegant nor in my experience efficient. I may be wrong on this.
My attempted solution was to use a binary viewer instead, but I can't find a clear way to retrieve values thus stored with PETSc, as these do not lend themselves to be read using VecLoad. Again one might go about that by wrapping them inside a vector and send that to the viewer, which just brings us back around to the original problem.
- Peder
Fra: Jose E. Roman <jroman at dsic.upv.es>
Sendt: 4. juni 2021 16:01:04
Til: Matthew Knepley
Cc: Peder Jørgensgaard Olesen; petsc-users at mcs.anl.gov
Emne: Re: [petsc-users] SLEPc: HDF5 support for SVD/EPSValuesView?
The problem is that here I am writing PetscReal's not PetscScalar's, and in EPS I am writing PetscComplex even in real scalars. That is why I did not implement it as you are suggesting.
Jose
> El 4 jun 2021, a las 15:56, Matthew Knepley <knepley at gmail.com> escribió:
> On Fri, Jun 4, 2021 at 9:31 AM Jose E. Roman <jroman at dsic.upv.es> wrote:
> I could try and adapt the HDF5 code in PETSc for this, but I am no HDF5 expert. Furthermore I am busy at the moment, so it is faster if you could prepare a merge request with this addition.
> I think the easiest thing is to wrap a Vec around the values and just VecView() it into the same HDF5 file.
> THanks,
> Matt
> Jose
> > El 4 jun 2021, a las 13:10, Peder Jørgensgaard Olesen via petsc-users <petsc-users at mcs.anl.gov> escribió:
> > Hello
> > In SLEPc one may write singular vectors to an HDF5 file using SVDVectorsView(), but a similar option doesn't seem to work for singular values using SVDValuesView(). The values are viewed correctly using other viewers, but nothing is seemingly produced when using an HDF5 viewer. Looking at the source code seems to confirm this, and suggests that there is a similar situation with EPS.
> > Is this correct, and if so, might there be plans to include such functionality in future releases?
> > Med venlig hilsen / Best Regards
> > PhD Student, Turbulence Research Lab
> > Dept. of Mechanical Engineering
> > Technical University of Denmark
> > Koppels Allé
> > Bygning 403, Rum 105
> > DK-2800 Kgs. Lyngby
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210604/1e08c83a/attachment-0001.html>
