[petsc-users] SLEPc: HDF5 support for SVD/EPSValuesView?
Fri Jun 4 08:56:06 CDT 2021
On Fri, Jun 4, 2021 at 9:31 AM Jose E. Roman <jroman at dsic.upv.es> wrote:
> I could try and adapt the HDF5 code in PETSc for this, but I am no HDF5
> expert. Furthermore I am busy at the moment, so it is faster if you could
> prepare a merge request with this addition.
I think the easiest thing is to wrap a Vec around the values and just
VecView() it into the same HDF5 file.
  THanks,
    Matt
> Jose
> > El 4 jun 2021, a las 13:10, Peder Jørgensgaard Olesen via petsc-users <
> petsc-users at mcs.anl.gov> escribió:
> > Hello
> > In SLEPc one may write singular vectors to an HDF5 file using
> SVDVectorsView(), but a similar option doesn't seem to work for singular
> values using SVDValuesView(). The values are viewed correctly using other
> viewers, but nothing is seemingly produced when using an HDF5 viewer.
> Looking at the source code seems to confirm this, and suggests that there
> is a similar situation with EPS.
> > Is this correct, and if so, might there be plans to include such
> functionality in future releases?
> > Med venlig hilsen / Best Regards
> > PhD Student, Turbulence Research Lab
> > Dept. of Mechanical Engineering
> > Technical University of Denmark
> > Koppels Allé
> > Bygning 403, Rum 105
> > DK-2800 Kgs. Lyngby
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210604/52b25939/attachment.html>
