[petsc-users] SLEPc: HDF5 support for SVD/EPSValuesView?
Peder Jørgensgaard Olesen
pjool at mek.dtu.dk
Fri Jun 4 06:10:12 CDT 2021
Hello
In SLEPc one may write singular vectors to an HDF5 file using SVDVectorsView(), but a similar option doesn't seem to work for singular values using SVDValuesView(). The values are viewed correctly using other viewers, but nothing is seemingly produced when using an HDF5 viewer. Looking at the source code seems to confirm this, and suggests that there is a similar situation with EPS.
Is this correct, and if so, might there be plans to include such functionality in future releases?
Med venlig hilsen / Best Regards
PhD Student, Turbulence Research Lab
Dept. of Mechanical Engineering
Technical University of Denmark
Koppels Allé
Bygning 403, Rum 105
DK-2800 Kgs. Lyngby
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210604/feeef817/attachment.html>
