[petsc-users] Is it possible to keep track of original elements # after a call to DMPlexDistribute ?
Eric Chamberland
Eric.Chamberland at giref.ulaval.ca
Wed Jul 21 13:54:47 CDT 2021
Hi Matthew,
we did it with PetscSFCreateInverseSF !
It is working well without overlap, so we can go forward with this and
compute the overlap afterward with DMPlexDistributeOverlap.
Eric
On 2021-07-20 10:39 p.m., Eric Chamberland wrote:
> On 2021-07-14 6:42 p.m., Matthew Knepley wrote:
>> Ah, there was a confusion of intent. GlobalToNatural() is for people
>> that want data transformed back into the original
>> order. I thought that was what you wanted. If you just want mesh
>> points in the original order, we give you the
>> transformation as part of the output of DMPlexDistribute(). The
>> migrationSF that is output maps the original point to
>> the distributed point. You run it backwards to get the original ordering.
>> Thanks,
>> Matt
> Hi,
> that seems to work better! However, if I understand well the
> migrationSF is giving information on the originating process where the
> elements have been migrated from.
> Is there a PETSc way to either:
> 1) send back the information to the originating process (somewhat
> "inverting" the migrationSF) ? So I can retrieve the "partitioning
> array" (just like the "part" parameter in ParMETIS_V3_PartMeshKway)
> on the sender process.
> or
> 2) Have the pre-migrationSF: I mean I would like to extract the "where
> are the elements going to be sent?" (again like "part" parameter)
> If not, I can always build the communication myself...
> Thanks,
> Eric
Eric Chamberland, ing., M. Ing
Professionnel de recherche
GIREF/Université Laval
(418) 656-2131 poste 41 22 42
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210721/0700741a/attachment.html>
