[petsc-users] output DMDA to hdf5 file?
Matteo Semplice
matteo.semplice at uninsubria.it
Thu Jul 15 07:53:43 CDT 2021
Il 15/07/21 14:26, Matthew Knepley ha scritto:
> On Thu, Jul 15, 2021 at 8:20 AM Matteo Semplice
> <matteo.semplice at uninsubria.it <mailto:matteo.semplice at uninsubria.it>>
> wrote:
> Il 15/07/21 14:15, Matthew Knepley ha scritto:
>> On Thu, Jul 15, 2021 at 6:39 AM Matteo Semplice
>> <mailto:matteo.semplice at uninsubria.it>> wrote:
>> Il 12/07/21 17:51, Matthew Knepley ha scritto:
>>> On Mon, Jul 12, 2021 at 11:40 AM Matteo Semplice
>>> Dear all,
>>> I am experimenting with hdf5+xdmf output. At
>>> https://www.xdmf.org/index.php/XDMF_Model_and_Format
>>> <https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.xdmf.org%2Findex.php%2FXDMF_Model_and_Format&data=04%7C01%7Cmatteo.semplice%40uninsubria.it%7C3a9815038ab445f8246b08d9478bd031%7C9252ed8bdffc401c86ca6237da9991fa%7C0%7C0%7C637619488512510053%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=e9a30wOMKKyHI2Ay5xFBaEFznwgzLg%2BxDCrQY75464c%3D&reserved=0>
>>> I read that "XDMF uses XML to store Light data and to
>>> describe the data Model. Either HDF5[3]
>>> <https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.hdfgroup.org%2FHDF5&data=04%7C01%7Cmatteo.semplice%40uninsubria.it%7C3a9815038ab445f8246b08d9478bd031%7C9252ed8bdffc401c86ca6237da9991fa%7C0%7C0%7C637619488512520008%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=0%2BwxLzRPRupk2klRoxuKSEHpzNVipjkF%2FVU0pq5jn%2B4%3D&reserved=0>
>>> or binary files can be used to store Heavy data. The
>>> data Format is stored redundantly in both XML and HDF5."
>>> However, if I call DMView(dmda,hdf5viewer) and then I
>>> run h5ls or h5stat on the resulting h5 file, I see no
>>> "geometry" section in the file. How should I write the
>>> geometry to the HDF5 file?
>>> Here below is what I have tried.
>>> The HDF5 stuff is only implemented for DMPlex since
>>> unstructured grids need to be explicitly stored. You can
>>> usually just define the structured grid in the XML
>>> without putting anything in the HDF5. We could write
>>> metadata so that the XML could be autogenerated, but we have
>>> not done that.
>> Thanks for the clarification. It shouldn't be hard to produce
>> the XML from my code.
>> Just another related question: if I call VecView in parallel
>> with the HDF5 viewer, I get a single output file. Does this
>> mean that data are gathered by one process and written or it
>> handles it smartly by coordinating the output of all
>> processes to a single file?
>> This is slightly more complicated than you would expect. We have
>> two implementations, one which uses MPI-IO, and one which sends
>> data from each process to 0, which writes it out. It turns out
>> that MPI-IO is sometimes poorly supported or badly implemented,
>> so you need
>> the fallback.
> Thanks!
> On my machine I am compiling from the git repo with
> --download-hdf5, so I have some control, but on clusters I prefer
> to use the available petsc.
> Is there a simple way to check which implementation is begin used
> in a run?
> You have to check the configure output. We never gather everything to
> one process, so you should not have to worry about it.
Thanks a lot!
Matteo
> Thanks,
> Matt
> Matteo
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.cse.buffalo.edu%2F~knepley%2F&data=04%7C01%7Cmatteo.semplice%40uninsubria.it%7C3a9815038ab445f8246b08d9478bd031%7C9252ed8bdffc401c86ca6237da9991fa%7C0%7C0%7C637619488512520008%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=73lAI16uLTsAuFedTXerJQ0jn63UspjPLLRRpb7Uw0E%3D&reserved=0>
Professore Associato in Analisi Numerica
Dipartimento di Scienza e Alta Tecnologia
Università degli Studi dell'Insubria
Via Valleggio, 11 - Como
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210715/d6dc9106/attachment.html>
