[petsc-users] Is it possible to keep track of original elements # after a call to DMPlexDistribute ?
Matthew Knepley
knepley at gmail.com
Wed Jul 14 17:42:52 CDT 2021
On Wed, Jul 14, 2021 at 4:58 PM Eric Chamberland <
Eric.Chamberland at giref.ulaval.ca> wrote:
> Hi Matthew,
> Ok, I did that but it segfault now. Here are the order of the calls:
> DMPlexCreate
> DMSetDimension
> DMPlexBuildFromCellListParallel(...)
> DMPlexInterpolate
> PetscPartitioner lPart;
> DMPlexGetPartitioner(lDMSansOverlap, &lPart);
> PetscPartitionerSetFromOptions(lPart);
> DMSetUseNatural(lDMSansOverlap, PETSC_TRUE)
> DMPlexDistribute
> DMPlexGlobalToNaturalBegin
> DMPlexGlobalToNaturalEnd
> But it gives me the following error:
> 0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Petsc has generated inconsistent data
> [0]PETSC ERROR: DM global to natural SF not present.
> If DMPlexDistribute() was called and a section was defined, report to
> petsc-maint at mcs.anl.gov.
> [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.15.0, Mar 30, 2021
> [0]PETSC ERROR: MEF++.dev on a named rohan by ericc Wed Jul 14 16:57:48
> 2021
> [0]PETSC ERROR: Configure options
> --prefix=/opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7 --with-mpi-compilers=1
> --with-mpi-dir=/opt/openmpi-4.1.0_gcc7 --with-cxx-dialect=C++14
> --with-make-np=12 --with-shared-libraries=1 --with-debugging=yes
> --with-memalign=64 --with-visibility=0 --with-64-bit-indices=0
> --download-ml=yes --download-mumps=yes --download-superlu=yes
> --download-hpddm=yes --download-slepc=yes --download-superlu_dist=yes
> --download-parmetis=yes --download-ptscotch=yes --download-metis=yes
> --download-strumpack=yes --download-suitesparse=yes --download-hypre=yes
> --with-blaslapack-dir=/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64
> --with-mkl_pardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/..
> --with-mkl_cpardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/..
> --with-scalapack=1
> --with-scalapack-include=/opt/intel/oneapi/mkl/2021.1.1/env/../include
> --with-scalapack-lib="-L/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64
> -lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64"
> [0]PETSC ERROR: #1 DMPlexGlobalToNaturalBegin() at
> /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexnatural.c:245
> What did I missed?
> Ah, there was a confusion of intent. GlobalToNatural() is for people that
want data transformed back into the original
order. I thought that was what you wanted. If you just want mesh points in
the original order, we give you the
transformation as part of the output of DMPlexDistribute(). The migrationSF
that is output maps the original point to
the distributed point. You run it backwards to get the original ordering.
Matt
> Thanks a lot!
> Eric
> On 2021-07-14 3:09 p.m., Matthew Knepley wrote:
> On Wed, Jul 14, 2021 at 1:18 PM Eric Chamberland <
>> Hi,
>> I want to use DMPlexDistribute from PETSc for computing overlapping and
>> play with the different partitioners supported.
>> However, after calling DMPlexDistribute, I noticed the elements are
>> renumbered and then the original number is lost.
>> What would be the best way to keep track of the element renumbering?
>> a) Adding an optional parameter to let the user retrieve a vector or
>> "IS" giving the old number?
>> b) Adding a DMLabel (seems a wrong good solution)
>> c) Other idea?
>> Of course, I don't want to loose performances with the need of this
>> "mapping"...
> You need to call
> https://petsc.org/release/docs/manualpages/DM/DMSetUseNatural.html
> before call DMPlexDistribute(). Then you can call
> https://petsc.org/release/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.html
> to map back to the original numbering if you want. This is the same thing
> that DMDA is doing.
> Thanks,
> Matt
>> Thanks,
>> Eric
>> Eric Chamberland, ing., M. Ing
>> Professionnel de recherche
>> GIREF/Université Laval
>> (418) 656-2131 poste 41 22 42
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210714/66170a81/attachment.html>
