[petsc-users] HDF5 DM and VecView with MPI :: Crash
Thibault Bridel-Bertomeu
thibault.bridelbertomeu at gmail.com
Tue Jul 6 01:51:25 CDT 2021
Hello Barry,
Thank you for your answer. And sorry I forgot those important details ...
Here is the complete error message for a DMView :
[1]PETSC ERROR:
[1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[1]PETSC ERROR: or see
https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
to find memory corruption errors
[1]PETSC ERROR: likely location of problem given in stack below
[1]PETSC ERROR: --------------------- Stack Frames
[1]PETSC ERROR: The EXACT line numbers in the error traceback are not
available.
[1]PETSC ERROR: instead the line number of the start of the function is
given.
[1]PETSC ERROR: #1 H5Dcreate2() at
/ccc/work/cont001/ocre/bridelbert/05-PETSC/src/vec/vec/impls/mpi/pdvec.c:690
[1]PETSC ERROR: #2 VecView_MPI_HDF5() at
/ccc/work/cont001/ocre/bridelbert/05-PETSC/src/vec/vec/impls/mpi/pdvec.c:594
[1]PETSC ERROR: #3 VecView_MPI() at
/ccc/work/cont001/ocre/bridelbert/05-PETSC/src/vec/vec/impls/mpi/pdvec.c:787
[1]PETSC ERROR: #4 VecView() at
/ccc/work/cont001/ocre/bridelbert/05-PETSC/src/vec/vec/interface/vector.c:576
[1]PETSC ERROR: #5 DMPlexCoordinatesView_HDF5_Internal() at
/ccc/work/cont001/ocre/bridelbert/05-PETSC/src/dm/impls/plex/plexhdf5.c:560
[1]PETSC ERROR: #6 DMPlexView_HDF5_Internal() at
/ccc/work/cont001/ocre/bridelbert/05-PETSC/src/dm/impls/plex/plexhdf5.c:802
[1]PETSC ERROR: #7 DMView_Plex() at
/ccc/work/cont001/ocre/bridelbert/05-PETSC/src/dm/impls/plex/plex.c:1366
[1]PETSC ERROR: #8 DMView() at
/ccc/work/cont001/ocre/bridelbert/05-PETSC/src/dm/interface/dm.c:954
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Signal received
[1]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[1]PETSC ERROR: Petsc Development GIT revision: v3.15.1-558-g07f732cb94 GIT
Date: 2021-07-04 15:58:55 +0000
[1]PETSC ERROR: /ccc/work/cont001/ocre/bridelbert/EULERIAN2D/bin/eulerian2D
on a named r1login by bridelbert Mon Jul 5 18:45:41 2021
[1]PETSC ERROR: Configure options --with-clean=1
--prefix=/ccc/work/cont001/ocre/bridelbert/05-PETSC/build_uns3D_inti
--with-make-np=8 --with-windows-graphics=0 --with-debugging=1
--download-mpich-shared=0 --with-x=0 --with-pthread=0 --with-valgrind=0
--PETSC_ARCH=INTI_UNS3D
--with-fc=/ccc/products/openmpi-4.0.3/gcc--8.3.0/default/bin/mpifort
--with-cc=/ccc/products/openmpi-4.0.3/gcc--8.3.0/default/bin/mpicc
--with-cxx=/ccc/products/openmpi-4.0.3/gcc--8.3.0/default/bin/mpicxx
--with-openmp=0
--download-sowing=/ccc/work/cont001/ocre/bridelbert/v1.1.26-p2.tar.gz
--download-metis=/ccc/work/cont001/ocre/bridelbert/git.metis.tar.gz
--download-parmetis=/ccc/work/cont001/ocre/bridelbert/git.parmetis.tar.gz
--download-fblaslapack=/ccc/work/cont001/ocre/bridelbert/git.fblaslapack.tar.gz
--with-cmake-dir=/ccc/products/cmake-3.13.3/system/default
--download-hdf5=/ccc/work/cont001/ocre/bridelbert/hdf5-1.12.0.tar.bz2
--download-netcdf=/ccc/work/cont001/ocre/bridelbert/netcdf-4.5.0.tar.gz
--download-pnetcdf=/ccc/work/cont001/ocre/bridelbert/pnetcdf-1.12.1.tar.gz
--download-exodusii=/ccc/work/cont001/ocre/bridelbert/v2021-01-20.tar.gz
--download-zlib=/ccc/work/cont001/ocre/bridelbert/zlib-1.2.11.tar.gz
[1]PETSC ERROR: #1 User provided function() at unknown file:0
[1]PETSC ERROR: Checking the memory for corruption.
MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
with errorcode 59.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
Here is the complete message for a VecView :
[1]PETSC ERROR:
available.
given.
[1]PETSC ERROR: #4 VecView_Plex_Local_HDF5_Internal() at
/ccc/work/cont001/ocre/bridelbert/05-PETSC/src/dm/impls/plex/plexhdf5.c:132
[1]PETSC ERROR: #5 VecView_Plex_HDF5_Internal() at
/ccc/work/cont001/ocre/bridelbert/05-PETSC/src/dm/impls/plex/plexhdf5.c:247
[1]PETSC ERROR: #6 VecView_Plex() at
/ccc/work/cont001/ocre/bridelbert/05-PETSC/src/dm/impls/plex/plex.c:391
[1]PETSC ERROR: #7 VecView() at
[1]PETSC ERROR: #8 ourmonitor() at
/ccc/work/cont001/ocre/bridelbert/05-PETSC/src/ts/interface/ftn-custom/ztsf.c:129
[1]PETSC ERROR: #9 TSMonitor() at
/ccc/work/cont001/ocre/bridelbert/05-PETSC/src/ts/interface/tsmon.c:31
[1]PETSC ERROR: #10 TSSolve() at
/ccc/work/cont001/ocre/bridelbert/05-PETSC/src/ts/interface/ts.c:3858
on a named r1login by bridelbert Tue Jul 6 08:46:43 2021
--with-openmp=0
with errorcode 59.
I am currently on the "main" branch, my HEAD being at commit id.
07f732cb949ae259de817d126d140b8fa08e2d25
I have the same issue with the "master" branch actually, that's why I went
with the "main", hoping something might have been fixed meanwhile.
I cannot provide you with a MWE yet unfortunately because it's part of a
bigger solver and I have to extract the workflow from it. I'll work on it
so you have everything you need.
Thanks !!
Thibault
Le mar. 6 juil. 2021 à 01:08, Barry Smith <bsmith at petsc.dev> a écrit :
> Please send the error message that is printed to the screen.
> Also please send the exact PETSc version you are using. If possible
> also a code that reproduces the problem.
> Can you view other simpler things with HDF5? Like say just a vector?
> Barry
> On Jul 5, 2021, at 11:50 AM, Thibault Bridel-Bertomeu <
> thibault.bridelbertomeu at gmail.com> wrote:
> Dear all,
> I keep having this error on one of the supercomputers I have access to :
> available.
> given.
> The configure options are as follow :
> --with-openmp=0
> The piece of code that is responsible is that one :
> call PetscViewerHDF5Open(PETSC_COMM_WORLD,
> "debug_initmesh.h5", FILE_MODE_WRITE, hdf5Viewer, ierr); CHKERRA(ierr)
> call PetscViewerPushFormat(hdf5Viewer,
> PETSC_VIEWER_HDF5_XDMF, ierr); CHKERRA(ierr)
> call DMView(dm, hdf5Viewer, ierr); CHKERRA(ierr)
> call PetscViewerPopFormat(hdf5Viewer, ierr); CHKERRA(ierr)
> call PetscViewerDestroy(hdf5Viewer, ierr); CHKERRA(ierr)
> I tried with gcc, intel compiler, openmpi 2.x.x or openmpi 4.x.x ... same
> problems ... can anyone please advise ? It's starting to make me quite
> crazy ... x(
> Thank you !!!
> Thibault
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210706/b4f62079/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210706/b4f62079/attachment-0001.obj>
