[petsc-users] Scatter parallel Vec to sequential Vec on non-zeroth process
Peder Jørgensgaard Olesen pjool at mek.dtu.dk
Sun Jul 4 05:27:30 CDT 2021
I agree, using the loop you describe would definitely not be a clever way of doing it, nor is it at all what I was going for. The code with Matt's method indeed does what I needed. I'd be happy if it could be further optimized.
Med venlig hilsen / Best regards
Peder
Fra: Junchao Zhang <junchao.zhang at gmail.com>
Sendt: 4. juli 2021 05:36:29
Til: Peder Jørgensgaard Olesen
Cc: Jed Brown; petsc-users at mcs.anl.gov
Emne: Re: Sv: [petsc-users] Scatter parallel Vec to sequential Vec on non-zeroth process
VecScatterCreateToAll() scatters the MPI vector to a sequential vector on every rank (as if each rank has a duplicate of the same sequential vector).
If the sample code you provided is what you want, it is fine and we just need  to implement a minor optimization in petsc to make it efficient.  But if you want to put the scatter in a loop as follows,  then it is a very bad code.
for (p=0; p<size; i++) {
  loc_tgt_size = 0;
  if (rank == p){
    loc_tgt_size = n;
  ierr = VecCreateSeq(PETSC_COMM_SELF, loc_tgt_size, &tgt_vec); CHKERRQ(ierr);
  ierr = VecZeroEntries(tgt_vec); CHKERRQ(ierr);
  // Scatter source vector to target vector on one process
  ierr = ISCreateStride(PETSC_COMM_SELF, loc_tgt_size, 0, 1, &is); CHKERRQ(ierr);
  ierr = VecScatterCreate(src_vec, is, tgt_vec, is, &sctx); CHKERRQ(ierr);
  ierr = VecScatterBegin(sctx, src_vec, tgt_vec, INSERT_VALUES, SCATTER_FORWARD); CHKERRQ(ierr);
  ierr = VecScatterEnd(sctx, src_vec, tgt_vec, INSERT_VALUES, SCATTER_FORWARD); CHKERRQ(ierr);
--Junchao Zhang
On Sat, Jul 3, 2021 at 1:27 PM Peder Jørgensgaard Olesen <pjool at mek.dtu.dk<mailto:pjool at mek.dtu.dk>> wrote:
Yeah, scattering a parallel vector to a sequential on one rank was exactly what I wanted to do (apologies if I didn't phrase that clearly). A code like the one I shared does just what I needed, replacing size-1 with the desired target rank in the if-statement.
Isn't what you describe what VecScatterCreateToAll is for?
Peder
Fra: Junchao Zhang <junchao.zhang at gmail.com<mailto:junchao.zhang at gmail.com>>
Sendt: 3. juli 2021 04:42:48
Cc: Jed Brown; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
Peder,
  Your example scatters a parallel vector to a sequential vector on one rank.  It is a pattern like MPI_Gatherv.
  I want to see how you scatter parallel vectors to sequential vectors on every rank.
--Junchao Zhang
On Fri, Jul 2, 2021 at 4:07 AM Peder Jørgensgaard Olesen <pjool at mek.dtu.dk<mailto:pjool at mek.dtu.dk>> wrote:
Matt's method seems to work well, though instead of editing the actual function I put the relevant parts directly into my code. I made the small example attached here.
I might look into Star Forests at some point, though it's not really touched upon in the manual (I will probably take a look at your paper, https://arxiv.org/abs/2102.13018).
Peder
Sendt: 1. juli 2021 16:38:29
Til: Jed Brown
Cc: Peder Jørgensgaard Olesen; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
Peder,
  PETSCSF_PATTERN_ALLTOALL only supports MPI_Alltoall (not Alltoallv), and is only used by petsc internally at few places.
  I suggest you can go with Matt's approach. After it solves your problem, you can distill an example to demo the communication pattern. Then we can see how to efficiently support that in petsc.
  Thanks.
--Junchao Zhang
On Thu, Jul 1, 2021 at 7:42 AM Jed Brown <jed at jedbrown.org<mailto:jed at jedbrown.org>> wrote:
Peder Jørgensgaard Olesen <pjool at mek.dtu.dk<mailto:pjool at mek.dtu.dk>> writes:
> Each process is assigned an indexed subset of the tasks (the tasks are of constant size), and, for each task index, the relevant data is scattered as a SEQVEC to the process (this is done for all processes in each step, using an adaption of the code in Matt's link). This way each process only receives just the data it needs to complete the task. While I'm currently working with very moderate size data sets I'll eventually need to handle something rather more massive, so I want to economize memory where possible and give each process only the data it needs.
>From the sounds of it, this pattern ultimately boils down to MPI_Gather being called P times where P is the size of the communicator. This will work okay when P is small, but it's much less efficient than calling MPI_Alltoall (or MPI_Alltoallv), which you can do by creating one PetscSF that ships the needed data to each task and PETSCSF_PATTERN_ALLTOALL. You can see an example.
https://gitlab.com/petsc/petsc/-/blob/main/src/vec/is/sf/tests/ex3.c#L93-151
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210704/09d9da62/attachment.html>
