[petsc-users] PETSc with Julia Binary Builder
Kozdon, Jeremy (CIV) jekozdon at nps.edu
Fri Jul 2 15:46:23 CDT 2021
BTW:
> On Jul 2, 2021, at 9:45 AM, Barry Smith <bsmith at petsc.dev> wrote:
> NPS WARNING: *external sender* verify before acting.
>> On Jul 2, 2021, at 10:03 AM, Stefano Zampini <stefano.zampini at gmail.com> wrote:
>> Patrick
>> Should this be fixed in PETSc build system? https://nam10.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FJuliaPackaging%2FYggdrasil%2Fblob%2Fmaster%2FP%2FPETSc%2Fbundled%2Fpatches%2Fpetsc_name_mangle.patch&data=04%7C01%7Cjekozdon%40nps.edu%7Ce30e522e78d643e61c7d08d93d78ddf7%7C6d936231a51740ea9199f7578963378e%7C0%7C0%7C637608411608120561%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=q1T617kzxD9HsSoXQTl7N%2FRi%2B%2BoKHbOgZRy7KEnmZKY%3D&reserved=0
>   This line worries me.
>   How does the get work here? If the first argument is a list while the second seems to be a (n empty) string then what will the [0] do with the empty string? It seems possible the use of get in Configure has to be double checked everywhere it is used to ensure consistency between whether a list or some other type is returned. Perhaps a custom "get" is needed for configure to make the code clean and always handle lists etc properly?
>   Barry
For the Julia build it's unclear to me why this was put in the original build script since configure option is
   --with-blaslapack-suffix=""
which seems to just be the default anyway(?)
