[petsc-users] MatNest with Shell blocks for multipysics
Thu Jul 1 14:36:40 CDT 2021
On Thu, Jul 1, 2021 at 11:44 AM Matteo Semplice <
matteo.semplice at uninsubria.it> wrote:
> Il 01/07/21 17:52, Jed Brown ha scritto:
> > I think ex28 is better organization of code. You can DMCreateMatrix()
> and then set types/preallocation for off-diagonal blocks of the MatNest. I
> think the comment is unclear and not quite what was intended and originally
> worked (which was to assemble the off-diagonal blocks despite bad
> preallocation).
> https://gitlab.com/petsc/petsc/-/commit/6bdeb4dbc27a59cf9af4930e08bd1f9937e47c2d
> https://www.mcs.anl.gov/petsc/petsc-current/src/snes/tutorials/ex28.c.html#line410
> Thanks! Yesterday I was unable to make it work, but I'll have another go
> with ex28 then...
> > Note that if you're using DMDA and have collocated fields, you can skip
> all this complexity. And if you have a scattered discretization, consider
> DMStag. ex28 is showing how to solve a coupled problem where there is no
> suitable structure to convey the relation between discretizations.
> The current discretization is in fact colocated with the variables on
> the same grid, and we might stick to that for a while.
> However, one key point in the design is that the jacobian will be
> [A00,A01;A10,A11] and we already have a taylor-made shell preconditioner
> for A00 and A00 implemented as a shell matrix; the preconditioner for
> the full Jacobian will be to neglect the A10 block and do a
> block-triangular solve inverting A00 approximately with the shell
> preconditioner.
Okay, if that is the case, then you should use DMDA to layout the Jacobian,
with DMCreateMatrix(),
and then PCFIELDSPLIT to preconditioner, since it will automatically split
things into your two pieces,
and you can use your custom PC for A00 and multiplicative to get your
upper triangular PC, or you
could use a Schur complement to see if stronger coupling was more effective.
     Matt
> I do not understand how creating a DMDA with n0+n1 dofs will let me
> easily reuse my shell preconditioner code on the top-left block.
> Matteo
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210701/74444d2a/attachment.html>
