[petsc-users] SLEPc: smallest eigenvalues
Varun Hiremath varunhiremath at gmail.com
Thu Jul 1 04:58:47 CDT 2021
Sorry, no both A and B are general sparse matrices (non-hermitian). So is
there anything else I could try?
On Thu, Jul 1, 2021 at 2:43 AM Jose E. Roman <jroman at dsic.upv.es> wrote:
> Is the problem symmetric (GHEP)? In that case, you can try LOBPCG on the
> pair (A,B). But this will likely be slow as well, unless you can provide a
> good preconditioner.
> Jose
> > El 1 jul 2021, a las 11:37, Varun Hiremath <varunhiremath at gmail.com>
> escribió:
> > Hi All,
> > I am trying to compute the smallest eigenvalues of a generalized system
> A*x= lambda*B*x. I don't explicitly know the matrix A (so I am using a
> shell matrix with a custom matmult function) however, the matrix B is
> explicitly known so I compute inv(B)*A within the shell matrix and solve
> inv(B)*A*x = lambda*x.
> > To compute the smallest eigenvalues it is recommended to solve the
> inverted system, but since matrix A is not explicitly known I can't invert
> the system. Moreover, the size of the system can be really big, and with
> the default Krylov solver, it is extremely slow. So is there a better way
> for me to compute the smallest eigenvalues of this system?
> > Thanks,
> > Varun
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210701/5e2b0b9b/attachment.html>
