[petsc-users] Gathering distributed dense matrix only on rank 0
Mon Jan 25 07:09:49 CST 2021
On Mon, Jan 25, 2021 at 4:40 AM Roland Richter <roland.richter at ntnu.no>
wrote:
> Hei,
> is there a way to gather a distributed dense matrix only on rank 0, not
> on the other ranks? My matrix processing/storage routines in my program
> currently are single-threaded and only operate on rank 0, and therefore
> I assume that I can ignore all other ranks. This should also save a bit
> time, I hope (MatCreateRedundantMatrix is currently the by far most
> expensive part of my program).
> When executing MatCreateRedundantMatrix(A, size, MPI_COMM_NULL,
> MAT_INITIAL_MATRIX, &B), usually all ranks get the full matrices,
> something I would like to avoid. Therefore, is there another way of
> handling this?
I am skeptical that it will save time, but you can do what you want using
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateSubMatrices.html
     Matt
> Thanks!
> Regards,
> Roland Richter
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210125/b7bda27a/attachment.html>
